Alternator ?
Discussion in '1st Gen Tundras (2000-2006)' started by Rex Kramer, Apr 7, 2020.
  1. Apr 7, 2020 at 5:12 AM
    Rex Kramer
    Rex Kramer [OP] Vinyl Spinner
    Georgia
    I noticed that my gauge is reading pretty high, is this normal?
  2. Apr 7, 2020 at 5:16 AM
    zombie
    zombie Master at Something
    paul
    Rhode Island
    2007 Black DC 4x4
    It's not in the Oh shit zone, but best to test at the battery itself just to be sure. While running should be between 13.6 to 14v. Make sure you have clean connections at the battery while there.
    Rex Kramer[OP] likes this.
  3. Apr 7, 2020 at 5:25 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    I personally don't view it as a high reading if we assume there are 5 marks from 9-18 and that those marks are approx. 1.8vdc, your reading is approx 14.4 vdc on an idiot gauge.
    BTW....that's where mine sits.
  4. Apr 25, 2020 at 9:18 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    20200425_234548.jpg I'll have to check mine when there is light out tomorrow. I noticed it starting to ride higher on the gauge with each LED I installed on the truck. I just assumed it was normal because there was minimal draw since I changed from incandescent.
    The gif is when I hit UP on both window switches with both being all the way up. I'm sure those motors draw some power!
    I did notice that my exterior lights, and all my cluster lights dimmed.
    Not so sure if this is normal.
    MrAristo and texasrho83 like this.
  5. Apr 26, 2020 at 10:34 AM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    Weird, mine doesn’t do that. I would get a multi meter and either have someone run the switches and you watch the display or if your solo use the min/max settings and see if your actually getting a large voltage draw from the window motors.
    Tundra2 likes this.
  6. May 2, 2020 at 5:24 AM
    Professional Hand Model
    Hand Protectors
    @Rex Kramer
    That needle reading is about where mine sits. Didn’t measure it prior to converting most all the trucks bulbs to LED, but feel the needle sits a tad higher since the LED’s.
    My battery is 1 year new and here are the readings when On and Off (cold). Seems acceptable from studies by others
