Alternator Issues
Discussion in '2.5 Gen Tundras (2014-2021)' started by will1668, Sep 19, 2021.
  1. Sep 19, 2021 at 11:03 AM
    will1668
    will1668 [OP] New Member
    I have a 2016 Tundra. It seemed at the time that it was slow cranking. Barely noticeable. I went and had it checked and the diagnostic check revealed a bad battery. I had it checked at three different AutoZone and O'Reilly Auto Parts. The battery was the original and five years old so I replaced it. After the new battery was installed I had them check it again. All three showed a good battery and that the alternator was bad. Not wanting to break down on the road I took it to Toyota and had them check it. They also agreed that the alternator was bad. I had it replaced and just to be safe I took it to O' Reilly's again...19 minutes after leaving Toyota. I had them check it again and again the battery was good and the alternator failed. Can anyone give me some advice on what you think might be happening? It is appreciated.
    Respectfully,
    Will
  2. Sep 19, 2021 at 2:27 PM
    TTund16
    TTund16 New Member
    based on what you are saying, I wouldn't rely on these diagnostic tests! Shouldn't the tests have detected the bad alternator to begin with?
    I ask the dealer and do another test there.
  3. Sep 19, 2021 at 2:35 PM
    I'd go back to the dealer and ask who signed off on the work performed........just sayin
  4. Sep 19, 2021 at 2:41 PM
    will1668
    Thank you! I agree and have already scheduled a follow-up. The Technician told the Service Rep that it is impossible that the alternator is bad...he checked everything and it was working properly...no idea why it would fail after 19 minutes. If anyone has any ideas please let me know what to look for...a knowledgeable friend told me I probably have a loose ground somewhere. For what its worth the truck is cranking and running great...Thanks again!
    Black Wolf likes this.
  5. Sep 19, 2021 at 2:41 PM
    ChattanoogaPhil
    ChattanoogaPhil New Member
    Toyota dealer said my 2000 Tundra alternator tested bad over 100,000 miles ago.
    Toyotoholic, TTund16 and Black Wolf like this.
  6. Sep 19, 2021 at 2:43 PM
    Sounds like it didn't fail if your tunny is running great........
  7. Sep 19, 2021 at 2:44 PM
    will1668
    lol...I had a friend who is a BWW mechanic who told me had the same problem on his...he to has put close to 100K on his. I am thinking I should have left well enough alone...
  8. Sep 19, 2021 at 2:46 PM
    Owning a decent digital multimeter and an Amp clamp is your friend.:thumbsup:
  9. Sep 19, 2021 at 2:46 PM
    will1668
    I think so but any idea on why it keeps failing on the diagnostic tests? Four failures to include the dealership...
  10. Sep 19, 2021 at 2:47 PM
    TTund16
    TTund16 New Member
    In old days maybe the regulator ... but I think the regulators have now been integrated into the alternator. Not sure. Either way they should test the whole system at the dealer.
    btw, surprised your 2016 battery lasted 6 years. Mine died after 2 years. My Tacoma battery lasted 9-10 years.
  11. Sep 19, 2021 at 2:49 PM
    Who replaced the alternator?
  12. Sep 19, 2021 at 2:50 PM
    will1668
    I have one...the numbers are 12.48 with everything turned off. With the truck running with the a/c off, the radio/nav off it is running at 13.45...I do not know if that is a problem but I am told that it should be around 14.2 and the service rep at Toyota agreed with me. Any thoughts? Thanks!
  13. Sep 19, 2021 at 2:51 PM
    will1668
    Centennial Toyota in Las Vegas
  14. Sep 19, 2021 at 2:52 PM
    will1668
    You are correct about the voltage regulator. I was pleased the battery lasted this long in the Vegas heat...
  15. Sep 19, 2021 at 2:55 PM
    Those voltage numbers aren't too bad. Did you go with lead acid or AGM battery out of curiosity?
  16. Sep 19, 2021 at 2:55 PM
    will1668
    I had the test ran at four different locations to include Toyota and all four had the alternator fail...two different AutoZones, O'Reillys and the dealership...I am not sure what to do or if I even have a problem.
  17. Sep 19, 2021 at 2:59 PM
    If the new alternator is keeping the new battery charged under a constant load.....you have no problem.
  18. Sep 19, 2021 at 3:00 PM
    will1668
    Lead acid
  19. Sep 19, 2021 at 3:01 PM
    ChattanoogaPhil
    I specifically asked why my alternator failed the test. Was told it was only putting out 13+ volts but was supposed to be 14+, and that was why the battery went bad. I told em to put in a new battery (battery was 7-8 years old) and we'll see. That 21 y/o alternator is still working just fine.
    will1668[OP] likes this.
  20. Sep 19, 2021 at 3:01 PM
    Your voltage values are good.
    will1668[QUOTED][OP] likes this.
  21. Sep 19, 2021 at 3:03 PM
    Voltage/current depends on load.
  22. Sep 19, 2021 at 3:03 PM
    will1668
    It is...I am probably concerned about nothing but cannot find the reason both the original and the new alternator has failed the diagnostic test. And the numbers are the same for the old and new alternator. I just don't want to break down on the road. I plan on driving to Georgia and back from Nevada in the next few months.
  23. Sep 19, 2021 at 3:07 PM
    ChattanoogaPhil
    The bed was empty.
    boostedtrdpro likes this.
  24. Sep 19, 2021 at 3:07 PM
    The dealer repair tech should have gon a post repair diagnostic check. Take it back and have them run another diagnostic check. They might charge you more $ if it passes...
  25. Sep 19, 2021 at 3:10 PM
    ChattanoogaPhil
    Sounds like you got the same bs diagnosis that I did years agp.
  26. Sep 19, 2021 at 3:11 PM
    You do understand when testing a power supply you have no load and load current checks and regulated voltage checks which has nothing to do with what's in the bed of your truck?
  27. Sep 19, 2021 at 3:13 PM
    ChattanoogaPhil
    Serious? :)
  28. Sep 19, 2021 at 3:19 PM
    No....ha! ;)
  29. Sep 19, 2021 at 3:20 PM
    rubberchicken48
    rubberchicken48 New Member
    2016 Toyota Tundra SR5, Black
    Pioneer HU and storage under the back seats
    When the alternator is truly failing you will notice a lot of strange electrical issues. Examples: Speedometer showing you are going way faster than you really are; using the wipers turns off the AC; random warning light go on and off.. Etc. Just remember, if the alt is bad then it can't replace power to the battery so you are running the truck with a finite amount of energy. Also, a bad alt CAN damage a perfectly good battery.
    Black Wolf, Mike59 and will1668[OP] like this.
  30. Sep 19, 2021 at 4:39 PM
    TTund16
    TTund16 New Member
    One of my other car voltage is 13.4-13.7v (per design) while running.
    i don't recall my Tundra volt gauge ever going above the center line (which is 14V) while running and I think scangauge shows 13.x also. I will have to double check.
    regarding my comment about the original diagnostic tests ... If the alternator and the battery were both bad, shouldn't the tests show both failures? Tests showed that the battery is bad and after you changed the battery, the tests showed that alternator is also bad. Maybe your alternator was bad and your battery was ok (good but weak) to begin with?
    In general, i am losing confidence in these diagnostic tests unless someone has a good explanation why the alternator failure was not detected to begin with.
