Already rear blocked, airbags too?
Discussion in '2.5 Gen Tundras (2014-2021)' started by bj46-taco-tundra, Jul 5, 2016.
  1. Jul 5, 2016 at 7:22 AM
    bj46-taco-tundra
    bj46-taco-tundra [OP] New Member
    Mark
    Bj46 taco and now a tundra
    I already have a ultimate boss kit with the rear block installed on my 2015 tundra, my question is:
    I would like to level out the truck more after a trailer is hooked up, and wondering if I added an air bag system to the rear is there any apparent problems with this logic? (Block + air bag )
    If so what do I do?
    If not what air bag kit do I go with?
  2. Jul 5, 2016 at 7:35 AM
    Bulhas
    Bulhas New Member
    Joe
    2007 Double Cab Limited
  3. Jul 5, 2016 at 8:00 AM
    No, u can run airbags just fine with the blocks. Firestone 2.0 is a solid brand to consider.
    Law323 likes this.
  4. Aug 14, 2016 at 6:24 AM
    Lee's rig
    Lee's rig Party naked
    Lee
    North nj
    2014 DC and 2014 single cab both 8' bed with 5.7
    To many
    I put the airlift bags in and haven't had a problem.
  5. Aug 14, 2016 at 6:36 AM
    Lee's rig
    Lee
    North nj
    To many
    Here are some more pics. Had my 3 yr old help put them together. Got the cheap compressor and mounted it in the cab. It is noisy but it isn't used that much so not a problem. Easy install once you get everything laid out and know where you are going g to run the lines. I also put the manual fills in the back bumper in case the compressor fails. I put the same ones in my single cab but only did the manual fill. You can get 2" rise out of the bags. You will notice a difference In The ride. At low psi I get more bounce, the higher the psi the more stiff the ride is. With my ladder rack and boxes on the truck I keep Mine at 20 psi.
  6. Aug 14, 2016 at 11:24 AM
    Tundra13jr
    Tundra13jr New Member
    concord nc
    2017 Toyota Tundra 4x4 magnetic grey
  7. Aug 14, 2016 at 12:18 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    I'm running firestone bags with a 1" block. No issues. With a taller block. you'd need to add spacers.
  8. Aug 14, 2016 at 12:29 PM
    Tundra13jr
    concord nc
    How much of a lift from stock ride does it give u? @bobeast
  9. Aug 14, 2016 at 12:31 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Yep like others have said there should be no issue. Others do it.
  10. Aug 14, 2016 at 12:32 PM
    Lee's rig
    Lee
    North nj
    To many
    Air lift is the brand. They at the time were a little cheaper
  11. Aug 14, 2016 at 2:47 PM
    bobeast
    Bob
    Hollister, CA
    2008 DC
    I get 1" lift from the rear block, but none from the airbags. When properly installed and used, airbags are not intended to provide lift to an unloaded truck. They are just there to compensate for suspension sag under load.
    Tundra13jr[QUOTED] likes this.
  12. Aug 14, 2016 at 2:51 PM
    Tundra13jr
    concord nc
    Ohh ok that makes sense @bobeast thanks a lot
  13. Aug 14, 2016 at 4:59 PM
    Lee's rig
    Lee
    North nj
    To many
    I guess to be clear my measurements were with 0 psi and then with 80 psi. The install of the bags did not change the ride height.
    Tundra13jr likes this.
