Alpine iLX F309TND Installed
Discussion in 'Audio & Video' started by RoadRacer19, Mar 10, 2019.
  1. Mar 10, 2019 at 2:53 PM
    RoadRacer19
    RoadRacer19 [OP] New Member
    2016 Tundra TRD Pro CrewMax
    -Magnum RT running boards -Revolver X2 cover
    AggiePhil, pvmike, Elduder and 6 others like this.
  2. Mar 10, 2019 at 2:58 PM
    CCTundra
    CCTundra New Member
    Seattle,WA
    2021 1794 Tundra
    Bilsteins 6112 top setting, 0.5" Coach builder shims, 5160 rear shock with 3" Coachbuilder shackle kit. RB20 Step bars, Forged TRD Pro wheels, Back flip cover, Kennwood 10" Head unit, 2JL 10" Subs, Alpine 6 channel Amp.
  3. Mar 10, 2019 at 2:59 PM
    RoadRacer19
    I had a stereo installer here in the Bay Area do it.
  4. Mar 11, 2019 at 8:08 AM
    bard0117
    bard0117 New Member
    This looks amazing! Would this render my DSR1 useless?
  5. Mar 11, 2019 at 8:10 AM
    00Tyler10
    00Tyler10 WETT Expeditions
    Tyler
    Bowling Green, Ky
    2020 MGM Tundra Plat 4x4
    PTM Mirror Caps Spray in Bed Liner Window Tint XD Buck 20x9 Wheels 275/65/20 BFG K02s Bamf 10" exhaust
    Yep
  6. Mar 11, 2019 at 8:10 AM
    Cement
    Cement ...
    2019 Cement Trundra TRD
    Wow nice. Zero loss of any functionality? All steering wheel controls work? Anything to know?
  7. Mar 11, 2019 at 8:23 AM
    RoadRacer19
    They have a Maestro interface. I still posses all steering controls and data from Toyota. I can connect to the unit via cord or Bluetooth., All good.
    I am also able to get real telemetry from the TPMS sensors w/ pressure and temp readings including Spare Tire.
    Ted4311, Sas and Cement like this.
  8. Mar 11, 2019 at 8:31 AM
    RoadRacer19
  9. Mar 11, 2019 at 9:00 AM
    phabej
    phabej New Member
    NO LONGER HAVE A TUNDRA... Waiting
  10. Mar 11, 2019 at 9:03 AM
    RoadRacer19
    Separate
  11. Mar 11, 2019 at 9:53 AM
    TxLock21
    TxLock21 Bought a truck, got bit by the bug.
    Awesome upgrade. I read somewhere that with this headunit you can watch videos such as Youtube, Netflix, etc...is this true?
  12. Apr 30, 2019 at 9:36 PM
    CARLHEIZER
    CARLHEIZER New Member
    San Diego
    2019 TUNDRA 1794 EDITION
    LINE-X, BAK MX4 WITH BAK BOX, UPGRAGED SOUND SYSTEM BY OEM AUDIO + AND CERAMIC WINDOW TINT - ALL SIX WINDOWS.
    While I do not have this unit in my Tundra, in my FJ Cruiser I had the Pioneer unit with Apple Car Play and yes, if wired correctly, with HDMI and lightening/USB, you can watch Netflix even while driving. Although that is not recommended right?
    Watt maker likes this.
  13. May 13, 2019 at 7:41 AM
    tinyt1553
    tinyt1553 New Member
    Tom
    Cypress, TX
    2017 1794 CM - Magnetic Gray
    Exterior: POP & Lock Power Tailgate lock BakFlip MX4 Tonneau Cover Rhino Bed Liner Swapped OEM Halogen Fogs with Formula-J87 LED 6000k bulbs Rough Country 60" Tailgate LED lightbar 6" rubber stub antenna Interior: Front Emblem Camera with anytime backup cam, Crux Vimty-05 for Vehicle in Motion Override Center console wireless charging Verizon Hotspot in center console Chromecast to OEM head-unit display ESP Rear Seat 3 Compartment Storage 5% Ceramic tint on rear window and rear doors 18% Ceramic tint on front doors Weathertech rear seat cover (try to take Hank (boxer/pointer mix) with me everywhere I can) In The Works: Upgrade to 2018 OEM LED Headlights VLEDs throughout the rear (turns, brakes, highmount 3rd brake and cargo) GRT Lighting LED's to replace all interior bulbs Future Wishlist: Swap OEM Head-unit with Kenwood DNX994S and use iDataLink Maestro RR to integrate OEM backup cam, OEM USBs, OEM Aux input, etc AMP-Research Power Sidesteps Train (air) horn
    I just installed this in my '17 1794 and am not getting any TPMS info. Did you have to purchase anything special to see TPMS?
  14. Jul 4, 2019 at 5:52 AM
    rawn027
    rawn027 New Member
    2019 Black Tundra Limited
    It comes with an OBDII adapter (http://support.alpine-usa.com/products/documents/iLX-F309TND_IM_FNL.pdf) -- you should see something plugged into the ODBII port, my guess is you need this for all vehicle details.
  15. Jul 4, 2019 at 5:44 PM
    tAcomaPueblo
    tAcomaPueblo New Member
    Tampa Bay
    2014 SR5 TRD OR CM 4x4
    How adjustable is this unit? Its a single din and ive heard you can put it in the top or bottom and slide the screen up or down. Do you like how its placed?
    Do you mind taking a picture from the side? I heard its just open on the back and you could slide stuff on top of the unit like its unfinished. Looking to see if it looks bad from the side as you see it when you climb in the cab.
  16. Jul 24, 2019 at 5:29 AM
    tinyt1553
    Tom
    Cypress, TX
    It is single din, the adapter is double and has a little cubby that sits behind the face of the headunit. Great for a little extra storage, or if you're from Colorado (like me) a little green and a pipe. LOL.
    The face can slide up or down (but very loosely) there's a set screw once you pick where you want it, put the screw in to hold it where you want vertically (I think there are 5 to 8 different settings for vertical placement). It also tilts back and forth (so I set the vertical height of the screen in the middle so I can get full upward and downward tilt) (tilt tight and smooth) there is a set screw but I left it out as I frequently adjust based on sun glare. It also adjusts in and out (2 options to choose from and a setting plate for it). I have mine further out (away from the dash) so I can get the full range of the tilt, if set to be closer to the dash (which gives a bit of a cleaner look), I can not tilt up or down as far. I ended up putting an antiglare screen protector on that I ordered from eBay. They have a template for the halo9, it comes in a 2 pack, and precut to fit. Install is pretty simple.
    https://www.ebay.com/itm/Tuff-Prote...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
    some photos
  17. Jul 24, 2019 at 6:05 AM
    Yoda21
    Yoda21 New Member
    Hayward ,ca
    2022 limited Trd crew max
    How much did u pay for the install everything included
  18. Jul 24, 2019 at 6:12 AM
    Hammerdog
    Hammerdog YCMTSUP
    Robbie
    Louisa VA
    2018 tundra sport crew max
    Tint Bed cover Red Tow Hooks TRD Intake 7 inch BDS 22x12’s 35 Toyo’s Rigid ditch lights RC light bar in bottom grille One bad ass stereo
    That’s sweet!!!
    tinyt1553 likes this.
  19. Jul 24, 2019 at 6:15 AM
    tinyt1553
    Tom
    Cypress, TX
    I installed it. Install kit with adapters, vehicle in motion bypass and everything came out to about $250
  20. Jul 24, 2019 at 1:35 PM
    Yoda21
    Yoda21 New Member
    Hayward ,ca
    That is it that is a lot cheaper then the halo where in the bay did u get it
  21. Jul 24, 2019 at 1:39 PM
    tinyt1553
    Tom
    Cypress, TX
    Add the cost of the headunit to the $250
  22. Jun 25, 2020 at 5:47 PM
    WhiteTundra1794
    WhiteTundra1794 New Member
    White Tundra 1794
    none yet
    I got a turn key quote of $1895. Does that sound good? This includes SiriusXM
  23. Jun 25, 2020 at 6:13 PM
    tinyt1553
    Tom
    Cypress, TX
    Seems a bit high to me but im not an installer. Whats the break down on the charges?
  24. Jun 25, 2020 at 6:19 PM
    WhiteTundra1794
    White Tundra 1794
    none yet
    Don't know the breakdown yet. This is all done via email so far. What is a good price?
  25. Jun 25, 2020 at 6:32 PM
    tinyt1553
    Tom
    Cypress, TX
    Depends on what all they are doing. Just installing the stereo? $900-$1000 for the halo
    Headunit, $250.for install kit (should include all adapters) that leaves $600 for tax and install seems high to me. Are they installing any amps? Installing any optional equipment like the VIM (vehicle in motion) bypass https://smile.amazon.com/Bypass-Navigation-Parking-Harness-GOBGOD/dp/B07T545H2M or are they including the idatalink maestro? It's hard to say if it's a good price without knowing the breakdown
  26. Jun 25, 2020 at 6:40 PM
    WhiteTundra1794
    White Tundra 1794
    none yet
    No amp, just the Halo and with Sirius to my knowledge. He emailed me.what Alpine has it listed for which is $1495 and said I needed a Sirius module.
    Thanks fo the info. Hopefully tomorrow I will get an itemized list, I just sent him an email asking for one.
  27. Jun 25, 2020 at 6:48 PM
    tinyt1553
    Tom
    Cypress, TX
    The ilx-f309tnd is the plug n play version specifically for the tundra, but man, $500 more just for the plug n play. I'd find out what makes the ilx-f309tnd $500 more than the ilx-f309 (non plug n play) other than a few adapters. .... the non plug n play is listing for about $995 right now.
    AggiePhil likes this.
  28. Jun 25, 2020 at 6:53 PM
    WhiteTundra1794
    White Tundra 1794
    none yet
    Thanks tinyt1553
  29. Jun 25, 2020 at 7:42 PM
    LJOHNS
    LJOHNS New Member
    I think I will be doing this upgrade next year. Did it improve the sound quality and clarity any?
  30. Jun 25, 2020 at 8:49 PM
    havasuTRD
    havasuTRD New Member
    Brett
    2017 Tundra crewmax TRD 4X4
    Wow, I almost crapped my pants when I saw the sticker price!!!
