Alpharex Pro Rear and OEM Sequoia Front lights
Discussion in '2nd Gen Tundras (2007-2013)' started by Mattyc, Nov 25, 2021.
  1. Nov 25, 2021 at 7:10 AM
    Mattyc
    Mattyc [OP] <insert custom title>
    Matthew
    NY
    2008 Limited Rock Warrior
    Not stock
  2. Nov 25, 2021 at 7:20 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I tried a dozen “solutions” always returned to hyper flashing. Just gave up and put the regular bulbs in.
  3. Nov 25, 2021 at 7:33 AM
    Mattyc
    Matthew
    NY
    Not stock
    You put regular bulbs into what? Do you have the Alpharex rear lights? Any info appreciated
  4. Nov 25, 2021 at 8:10 AM
    e30cabrio
    Sorry, I have oem rear tails with 2018+ sequoia headlights and after most available bulbs (100 bux to 20) eventually always had hyperflashing again.
  5. Nov 25, 2021 at 8:59 AM
    TravisJr
    TravisJr New Member
    2001 AC SR5 4WD, 2010 DC SR5 4WD
    Lots o’ mods
    Where did you wire in the resistors? I can’t speak directly to the Sequoia lights, but I’m running Alpharex tails and Morimoto headlights, which I would presume are similar. I installed the Alpharex first, and they ran correctly with no issue. Once I added the Morimotos, I got hyperflash. I installed the resistors in the tails, and it fixed the issue all around.
    Also, could it be the resistors themselves? Don’t know if they’re all equal, or if there are differing levels of quality/resistance. Pretty sure I got mine from Headlight Revolution. I’m no electrician, but maybe you need to run two in a row to get the needed load? That doesn’t seem likely, but if you have an extra set around it might be something to try.
  6. Nov 25, 2021 at 9:45 AM
    Mattyc
    Matthew
    NY
    Not stock
    I wired them into the tails. White/black and green wires. The Sequoia lights worked flawlessly with the OEM tails. I got the 60 ohm resistors from superbright LED’s. Maybe I should try HR? Did you use 60ohm 25W?
  7. Nov 25, 2021 at 10:44 AM
    cwcore
    cwcore New Member
    2007 SR5 DoubleCab Long Bed
  8. Nov 25, 2021 at 10:48 AM
    Mattyc
    Matthew
    NY
    Not stock
    Is this what you used? Are you running the Alpharex tails too? I assume it fixed your issue?
  9. Nov 25, 2021 at 11:06 AM
    Ericsopa
    Ericsopa Old man and the sea
    I'm running the Sequoia LED headlights and VLED bulbs in OEM taillights. VLED supplied resistors for the turn signals, and they've worked flawlessly. I had a lot of trouble with Superbright LEDs brakelights in my wife's VW Beetle. On very dim all the time when the engine is running and light switch off. With the light switch on at night, you could not tell any difference between tail and brake intensity.
  10. Nov 25, 2021 at 11:23 AM
    cwcore
    cwcore New Member
    Yes sir it fixed my issue with the hyperflash
    with the alpharex taillights.
    I put electrical tape around the connectors to make sure they didn’t come loose from road vibrations9B7FC417-C95D-4C43-AF64-704030C4EB9F.jpg
    MTRock and Mattyc[OP] like this.
  11. Nov 25, 2021 at 1:00 PM
    TravisJr
    TravisJr New Member
    Lots o’ mods
  12. Nov 25, 2021 at 1:51 PM
    Mattyc
    Matthew
    NY
    Not stock
    Ordered. Thanks!!
  13. Nov 26, 2021 at 9:41 AM
    Slim Gym
    Slim Gym New Member
    2013 Tundra DC 4X4
    One of the videos I watched about resistor installs had a segment on common errors that occur.
    They show how to test the wires and install the resistor the best way so it stays installed and does not come lose or short.
    Think it was from Headlight Revolution or The Retrofit Source website.
    Then it goes over common errors people make putting the resistors on their trucks.
    I emailed them what I was putting on my truck. They responded that day with "50w 6ohm" resistor. Sold in pairs for $23.32.
    Common errors:
    Wiring the resistor to the ground and parking light of the tail lights. Use a voltage meter to make sure you are wiring it to the ground and the turn signal.
    Putting the resistor next to items that do not respond well to heat. Resistors get very hot when in use. Mount them to a metal area away from other wires and plastic.
    Using a resistor not strong enough to handle load or cheap resistor from Amazon you 1. Guessed was right voltage or 2. Hoped was not cheap Chinese fake item.
    From VLEDS Website:
    "Exclusive The VLR is by far the cleanest and safest way to add load to any vehicle lighting system. VLR resistors accomplish the same task as a common gold resistor but are easier to install, have a lower profile, and run 50% cooler (250°F MAX).
    One for One We get asked all the time, how many resistors will I need? The answer is simple: If you're removing a filament turn signal bulb add one VLR-6 in its place. It's like balancing a scale; if you remove weight, the scale will be unbalanced, so you're simply putting the same amount of weight (load) back on."
  14. Jan 30, 2022 at 12:12 PM
    Mattyc
    Matthew
    NY
    Not stock
    Just to update this thread. None of these worked on my truck. Hyper flashing regardless of which resistor I installed. The flashers work at a normal rate, so it’s definitely a draw issue. For now I’m living with the fast blinking as much as I hate it
  15. Jan 31, 2022 at 6:39 AM
    Slim Gym
    Slim Gym New Member
    2013 Tundra DC 4X4
    I would contact the company of the lights that are hyperflashing. They can give you advice on how to fix it. Headlight Revolution has a Youtube video that shows how to properly add a resistor.
    Email/Call them and tell them what you have on your truck and let them tell you which resistor on will need.
