All-New XTR License Plate REVERSE LIGHT SYSTEM!
Discussion in 'Lighting' started by Headlight Revolution, Feb 27, 2020.
  1. Feb 27, 2020 at 9:18 AM
    Headlight Revolution [OP] New Member Vendor
    Atlanta, GA
    Hey Tundra Guys!
    I wanted to run a new unique product by everyone because I feel like this is something you didn't know you needed until now.
    Up front we’ve already got bright low beams. High beams, and fog lights…But too often overlooked is our ability to see well while backing up in the dark. While there are plenty of LED bulb upgrades out there for stock reverse lights; when it comes to a backup light boost there’s simply no comparison to the XTR LP.
    ENGINEERED:
    The XTR LP is the only system on the market that leverages optical refinement over raw power to produce the perfect reverse light beam pattern. We started by understanding the most typical installation angles and then optimized the lens to distribute the most possible light in the most effective pattern. To pack a real punch, the XTR LP packs more than just a lot of LED’s into a line on the back of car. It’s a fully engineered product.
    WHAT’S INSIDE:
    54 CREE J Series 2835 LEDs rated at 4500K/80CRI. 180mA driver produces 29.9W of maximum power pumps out 2700 raw lumens that’s translated into 1950 real lumens after transmission through the optical lens.
    TECHNICALLY SPEAKING:
    At a 10-degree mounting angle, the vertical range is -20 to +25 degrees. At the most typical 0-degree mounting angle, the XTR LP provides a -30 to +15 degree vertical spread, which easily exceeds the illumination range of any standard backup for spread. Users should acknowledge that this product far exceeds the legal limit for output volume in a reverse light application.
    (This room was Pitch-Black! :eek2:)
    BOLT-ON:
    The XTR LP will bolt onto your vehicle’s top two license plate mounts. It’s die-cast aluminum housing is contoured according to the geometry of US-spec license plates for a flush fit, and the mounting points are positioned according to the same universal standard. The system is finished in a satin black powder coat.
    WIRING:
    The XTR LP is powered on with a simple +/- 12v circuit that’s intended to tap in to your stock reverse light wiring. The system includes 1.5 meters of integrated wiring that can be trimmed back according to your application, a quick-disconnect for ease of install, and an integrated rubber grommet to keep moisture and dust out of a pass-through hole if necessary.
    INSTALL VIDEOS:
    Youtube Video Review: https://www.youtube.com/watch?v=C29f1c8P1gs
    Review 2: https://www.youtube.com/watch?v=qTbe1vTBVcw
    Youtube Install: https://www.youtube.com/watch?v=nhLYveEVr48
    You can check these bad boys out on the Website!
    Link: https://headlightrevolution.com/xtr-lp-reverse-light-system/
    (Make sure to include Tundras.com in the Order Comments/Notes!)
  2. Feb 27, 2020 at 10:53 AM
    TheBeast The Beach
    this is nice. Doesn't draw too much current and ok to piggyback on reverse tail lights ?
  3. Feb 27, 2020 at 10:58 AM
    Atlanta, GA
    Yessir, This is designed to tap straight into your Reverse Light circuit! Hell, you could even bolt one onto the Bottom of your Plate and run 2 of them + your Reverse Lights!
    Ely010606 and TheBeast[QUOTED] like this.
  4. Feb 27, 2020 at 11:11 AM
    alwzdfiant
    alwzdfiant New Member
    2013 Tundra Crew Max
  5. Feb 27, 2020 at 11:15 AM
    Atlanta, GA
    Haha PM me and we'll get you set up my man! Be the First Tundra with one out there!
  6. Feb 27, 2020 at 11:29 AM
    alwzdfiant
    Thanks Caleb! Can’t wait to get these on my truck!
  7. Feb 27, 2020 at 11:30 AM
    Atlanta, GA
    No problem my man! Let me know if you have any Qs on that Install, you are going to LOVE that thing! :hattip:
    alwzdfiant[QUOTED] likes this.
  8. Feb 27, 2020 at 11:41 AM
    biebs96
    PA
    I like this
  9. Feb 27, 2020 at 11:43 AM
    Atlanta, GA
    It's a super slick design for sure! One of a kind and super super handy! Looks and fits just like if it were Factory. Let me know if you want to get an order in by shooting me a PM and I'll shoot you a Call directly! :)
  10. Feb 27, 2020 at 12:10 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    I'm no fortune teller, but I think these will move.
  11. Feb 27, 2020 at 12:36 PM
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    I’m interested! You guys running any kind of forum promo code right now by chance?
  12. Feb 27, 2020 at 12:36 PM
    Atlanta, GA
    Worth every penny my man, they are BRIGHT!
    MotoTundra[QUOTED] likes this.
  13. Feb 27, 2020 at 12:37 PM
    Atlanta, GA
    Trying to get a code in the works as we speak, but I'm afraid we don't have anything running as of yet. Hoping soon though!
  14. Feb 27, 2020 at 2:43 PM
    SandyTRD
    SandyTRD New Member
    ‘16 Pro
    Dented bumper
    My cart is waiting
  15. Feb 27, 2020 at 2:47 PM
  16. Feb 27, 2020 at 3:18 PM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    alwzdfiant likes this.
  17. Feb 27, 2020 at 3:19 PM
    alwzdfiant
  18. Feb 27, 2020 at 3:24 PM
    biebs96
    PA
    I’d be curious how one would look/work hidden behind the grill
  19. Feb 27, 2020 at 6:09 PM
    chrisbusnut
    chrisbusnut New Member
    Pasadena, CA
    2020 Tundra Crew Max SR5 4x4 w/TRD Off Road pkg
    DiamondBack bed cover, SDHQ sliders, SwitchPro, Katzkin leather seats, TRD Pro grille, TRD Pro wheels w/Nitto Ridge Grappers, Toyota OEM leather steering wheel, SSO Slimline Hybrid Bumper w/Baja Designs S8 light bar, Warn Zeon Platinum 10-S winch, Baja Design rock lights & flush mount rear bumper lights
  20. Feb 27, 2020 at 6:13 PM
    vegas4x4
    vegas4x4 Blaaack
    Las Vegas
    2016 Black TRD CM 4x4
    This looks sweet. My led bulbs are plenty bright but more is always better :spending:
    Alexstundra likes this.
  21. Feb 27, 2020 at 7:22 PM
    Flyinryank
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    I like that they make a full plate frame that goes with it too
  22. Feb 27, 2020 at 8:12 PM
    What the!?
    What the!? New Member
    2017 Pro
  23. Feb 27, 2020 at 8:51 PM
    SARZYN
    SARZYN New Member
    Intercourse, PA
    2016 Tundra Crewmax Limited
    Tundra234 and 1lowlife like this.
  24. Feb 27, 2020 at 10:25 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    This is pretty nice, thanks for the link.
    Just curious wouldn't this be too bright in the reverse camera to see on the head unit, I replaced my license plate light with led and when i have it on reverse at night I could hardly see anything in the head unit from the glare of the light.
  25. Feb 27, 2020 at 10:48 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Sorry to discount @Headlight Revolution but I've had much better performance and reliability out of vleds..
    Bulbs, resistors, have never failed me.
    Headlight Revolution, I've had issues with their ultra thin contact wires breaking on license plate and parking light bulbs..
    Did they replace them? Yes.
    Did I use the replacements? Nope.
    Replaced them with vleds or Sirius leds.
    pdiddy and Tundra234 like this.
  26. Feb 28, 2020 at 4:33 AM
    SARZYN
    SARZYN New Member
    Intercourse, PA
    I also had this issue. After replacing my license plate bulbs, as well as the reverse lights on my Tundra...it was very bright when reversing. Almost too bright for the camera view. Thats when I discovered that the actual brightness of the back up camera view is adjustable, through the settings in the Tundra head unit.
    I turned the camera brightness down two clicks. So now when I put the Tundra in reverse at night (led reverse lights, led license plate reverse light, and led license plate bulbs (all VLEDS))...i have a clear rear view camera view that looks like daylight. Which is very much needed and helpful in the mostly rural/farm country area that I live in. And, like I mentioned earlier, VLEDS offers a three year warranty on everything they sell.
    pdiddy and Ely010606[QUOTED] like this.
  27. Feb 28, 2020 at 4:45 AM
    pdiddy and Jim LE 1301[QUOTED] like this.
  28. Feb 28, 2020 at 4:58 AM
    :hattip:
  29. Feb 28, 2020 at 5:28 AM
    Atlanta, GA
    Good morning my guys!
    Lots to reply to so I'm going to do it generally. The XTR LP and the VLEDs setup is very similar, but I assure you there is a difference! The XTR is brighter than the VLEDs model by a bit according to Xenon Depot. The lens is designed to create a more useful beam pattern for backing up, whereas the VLEDs model really is just a strip of LED Chips that spit light out the back for you.
    The VLEDs model does have a 3-Year Warranty, but the XTR Model supports a full 5-Year Warranty. So all in all, you're getting a Brighter light that installs the same way, and you get a better warranty for the exact same price. :)
    Trooper2, Tundyfundy, rons23 and 7 others like this.
  30. Feb 28, 2020 at 6:45 AM
    Ely010606
    SPARKS, NV
    Thanks for that info, greatly appreciated I'm definitely going to do that now.
