Alignment
Discussion in 'Suspension' started by crewmaxlmt, Dec 28, 2020.
  1. Dec 28, 2020 at 2:00 PM
    crewmaxlmt
    crewmaxlmt [OP] How dare you!
    scott
    2020 Crewmax Limited
    I have the Toytech Ultimate Bilstein 5100 adjustable kit on my CM with SPC adjustable UCA's and I am still getting rubbing on the drivers side body mount. For those with a close relationship with your alignment shop, how did you tell them to properly dial in the alignment? Adjusting the lower control arm, upper ball joint, ETC.
    The shop that installed the lift had their own shop do the alignment and I am not entirely happy with it. By the way, I am running 285-75/18's with a +18 offset.
  2. Dec 28, 2020 at 2:48 PM
    crewmaxlmt
    scott
    Matictundra might have just answered my question in another thread.
    "Just tell the shop to keep toe and chamber within OEM spec but maximize the caster by pulling in the front LCA mount inward as much as possible and rear mount as far out as possible."
  3. Dec 28, 2020 at 8:14 PM
    Eleventeen
    Eleventeen New Member
    Louis
    2016 Black CM Tundra
    you still might get a little rub. look into getting a cmc or put a different front bumper on.
  4. Dec 29, 2020 at 7:24 AM
    crewmaxlmt
    scott
    I modified the fender liners, so no rubbing there. It only rubs on the drivers side body mount.
