Alignment
Discussion in 'Suspension' started by Icematt, Oct 10, 2019.
  1. Oct 10, 2019 at 1:36 PM
    Icematt
    Icematt [OP] Toyota4life
    Black 1794 TRD
    Fuel wheels
    I got my truck aligned it has Bilstein 6112s on the 1.3" setting. Here my current Alignment numbers, does this look right? Thanks
  2. Oct 10, 2019 at 2:03 PM
    thearborbarber
    thearborbarber New Member
    SoDak
    2018 Tundra SR5
    Almost exactly what mine is on the 0.75 setting.
  3. Oct 10, 2019 at 4:48 PM
    Icematt
    Black 1794 TRD
    Fuel wheels
    Hows your tire wear?
  4. Oct 11, 2019 at 1:12 PM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Caster numbers are backwards but if it doesn't pull it will be fine.
  5. Oct 11, 2019 at 1:39 PM
    Icematt
    Black 1794 TRD
    Fuel wheels
    Feels like it pulls to the right sometimes. Thank you
  6. Oct 11, 2019 at 4:18 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Caster is used to offset road crown. If its pulling right slightly it's because of the caster numbers. You want .5° difference between the left side and right so the left at .3 on the left and .8 on the right would have been better. Vehicles will pull to the side with the least amount of caster.
  7. Oct 11, 2019 at 4:19 PM
    Icematt
    Black 1794 TRD
    Fuel wheels
    Thank you so much.
  8. Oct 14, 2019 at 7:07 AM
    thearborbarber
    SoDak
    2018 Tundra SR5
    Only have a couple of hundred miles on the rig.
  9. Oct 14, 2019 at 6:28 PM
    Icematt
    Black 1794 TRD
    Fuel wheels
    Ok Cool, so far got about 5k on mine. So far so good.
    thearborbarber likes this.
