Alignment/suspencion advice
Discussion in 'Suspension' started by Cubano4v16, Oct 13, 2021.
  1. Oct 13, 2021 at 6:53 AM
    Cubano4v16
    Cubano4v16 [OP] New Member
    2007 toyota tundra
    Lifted 20x12 fuel hostage -44 33 12.5 tires a/t
    Hello, i have a 2007 tundra. It currently have.
    Front: 3.5" spindle lift, blistein 5100 lowest setting.(total around 4 1/4 lift)
    Rear: ome dakar 2.5" lift leafs and .625" lift couch builders shackle.
    (Total lift around 3" lift) also have blistein longer 5100 shocks.
    I had previosly my front 5100 on top setting with a cb shim. So i had 6" lift on front. When i had that setup i installed zone offroad UCA to correct angles.
    When i decided to drop from 6" lift and set my 5100 on front to lowest setting and removed the cb shim. I still left that zone offroad UCA there. But seems like is off angle now.
    I know that with an spindle lift the oem geometry amd angles stay the same. So should i install back my oem UCA s. I done 3 alignmens aready and truck pulls or seems to go to the right slowly. Also my UCAs now rub the side plastic piece.
    I will attach photos of the UCAs angle now when i dropped the 5100 to lowest setting. Also photo of last alignment done. My steering wheel is turned a bit to the left.
    Any advice or help will be appreciatted. Thanks guys.
  2. Oct 13, 2021 at 6:56 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    from the pics, looks like the UCA is now angled up? If so, then yes I would install the stock ones. UCA angle should be flat or have some slight downward angle I believe. I have never seen UCA angled up like that on a street driven truck.
    Cubano4v16[OP] likes this.
  3. Oct 13, 2021 at 4:18 PM
    Cubano4v16
    2007 toyota tundra
    Is not rubbing on the line, is rubbing on the plastic cover behind it. I will change to the stock ones. The only reson i had the zone is because i had my 5100 on top setting and a shim, and that created like 2.5" lift on the arms. But since i removed the shim and set the 5100 to lowest setting. Is only lifting the arms like less thatn an 1".
