Alignment Question?
Discussion in '2.5 Gen Tundras (2014-2021)' started by 737fixer, Oct 23, 2021.
  1. Oct 23, 2021 at 5:04 PM
    737fixer
    737fixer [OP] New Member
    Does anyone have the actual Toyota Spec Alignment numbers for our trucks? If you search alignment on this forum you get a million pics of the spec sheet that we all get from whomever does the alignment. On that sheet they have a range to be in "the green" which one would assume is factory numbers. Problem is if you look a a dozen different sheets it seems everyplace has their own range. Seems the range should be set for our truck be it 2.0 or 2.5 gen.
    I realize lifting and such means we may adjust the range to whatever is best but I just was curious if anyone has the actual stock numbers set by Toyota.
