Alignment question?
Discussion in '2nd Gen Tundras (2007-2013)' started by ccam, Jul 31, 2019.
  1. Jul 31, 2019 at 6:44 PM
    ccam
    ccam [OP] New Member
    chris
    Fishers IN
    2011 Tundra Crewmax TRD
    1 in spacer lift on top of the coilovers and in rear, k&n cold air intake, toytec tunebcs coilovers up front, toytec boss 3in lift rear shocks, trd rear sway bar, straights from the cat. back (She purrs a little)
    Lifted 4 in. Front driver side ride height was .5 lower. I put a half in spacer on top.of the coil on that side. That leveled the truck. I got an alignment was told I was good however that front left wheel has really worn the tread down on inside of wheel exponentially more than other tires. Is that spacer the problem or camber off. If camber is right inwas thinking that spacer wouldnt matter. Any ideas?
