Alignment question RE: camber
Discussion in 'Suspension' started by hdfanatic, Mar 21, 2017.
  1. Mar 21, 2017 at 8:54 PM
    hdfanatic
    hdfanatic [OP] New Member
    Kevin
    Pearland, TX
    2017 Barcelona Red Platinum Crewmax 4x4
    TRD Pro wheels, Nfab
    FYI, first lifted truck here, so if this is normal, just say so...
    So I installed Bilstein 5100s all around last week. I took the truck into Firestone for an alignment. The guy behind the counter talks me into the lifetime alignments if I am going to be changing the suspension around multiple times throughout my ownership of the truck. Sounds good.
    Once they are done with the alignment, they show me the numbers and the camber of the front left tire is not in the green (just outside green). He proceeds to tell me that they will not even attempt to fix the camber issue, as there is no way to fix this on a lifted truck. Normal?
  2. Mar 21, 2017 at 9:00 PM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
  3. Mar 21, 2017 at 10:16 PM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    Try your local off road guys for your alignment needs. That's what they do. Find the shops that specialize in off road vehicles and all drive jacked up badass trucks/jeeps/landcruisers.
  4. May 2, 2017 at 4:03 AM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
  5. May 2, 2017 at 4:24 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    what setting are your 5100's at? on the middle setting (1.57"), you should be able to get a proper alignment. if you have it on the top setting (2.25"), you might need aftermarket UCA's, but most don't need UCA's until they get to 2.5-3.0" of lift.
    Big Green Thing likes this.
  6. May 2, 2017 at 4:51 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Alignment problems with billies? Like @Netmonkey said you shouldn't need UCA's unless you go up to 2.5-3" of lift.
    I'd go to a local 4 wheel shop and if you can't get out of the lifetime alignment deal, bring the 4 wheel shop alignment sheet to them every time
  7. May 2, 2017 at 5:10 AM
    Les7311
    So a 6 inch lift will need an adjustable UCA?
  8. May 2, 2017 at 5:24 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    undoubtedly with enough of a lift on the suspension....some 6" lifts come with spacers, some with spindles to achieve proper height.
    some just use spacers (dangerous) and won't need UCA's.
    doesn't necessarily have to be "adjustable" just an aftermarket UCA that allows for wheel travel with such a big lift.
    Les7311[QUOTED] likes this.
  9. May 2, 2017 at 5:53 AM
    Les7311
    Best answer I have received so far.
    First truck and getting used to the difference
    Any dealer / shop / link / item number to the UCA I will need?
    Am on IMG_1228.jpg IMG_1205.jpg a RC 6 inch lift, replaced the front spacers with struts, 20 x 35 wheels.
    This is my kit and recent alignment - pulling left with the ghastly \ / in front wheels
    Dustydirt19 likes this.
  10. May 2, 2017 at 6:06 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    @Les7311 I'd say stay away from RC! good price point but not the best quality. Quality is what you really want when lifting your truck! Do it right the first time!
    I'd go BDS with Fox coilovers. Quite a bit more, but good quality. I'm not well versed in other lifts but @Hattori can help!
    Toytec has some good UCA's, as do Icon and Camburg.
    I'll be getting some Toytec SPC UCA's somtime in the future.
    Les7311 likes this.
  11. May 2, 2017 at 7:29 AM
    Hey @Les7311 i agree with @Law323 i came into tundra world blind...i bought a used '14 CM that came with a lift on it... a RC 6" believe me its rough alright stay away from a spacer lift you'll feel every bump n get whiplash n your neck!!! Yeah spacer lift looks cool but not good for off-roading very limited shock travel remember these our opinions its really up to you what you wanna do with your ride and how ya gonna use it good luck with your endeavor check out Toytec.com (boss kit) or fabtech.com believe the 4" kit or you can do coach builder shackles rear n shims up front
    Les7311 and Law323 like this.
  12. May 2, 2017 at 8:43 AM
    Les7311
    The shop I went to blindly days after buying truck suggested RC so I paid to get kit and 35's installed.
    I went for the 6 inches lifted height look ( prob won't go off-roading), andsnow in Maryland.
    I will be comfortable once this alignment issue is resolved
    Plan to rotate fronts to see if still pull to left
    Law323 likes this.
  13. May 4, 2017 at 7:01 PM
    mattc
    mattc New Member
    That's a joke. I was a Firestone mechanic long ago. A good or even decent alignment guy can get you set up right pretty easily.
    I just leveled the front of my truck with the toytec boss coilovers and was able to get my camber to 0.0 and caster to 2.5. I'd like to have more caster but that's all I can get without control arms.
  14. May 4, 2017 at 7:29 PM
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    2015 Blue Ribbon Metallic 5.7L 4WD SR5 TRD DC
    ProComp 6" stage 2 lift 18x9 Fuel Vapor -12 offset 35x12.5 Nitto Ridge Grapplers BullyDog Tuner Gibson Metal Mulisha cat-back exhaust, S&B cold air intake, Color matched TRD PRO Grille, Compustar Remote Start N-Fab Hooped Nerf Bars, AMI Big stick antenna, Salex organizer and tray, Weathertech laser cut floor mats, Weathertech window deflectors Black out badge Black out front and rear bumper Black out flags 24/7 black out TRD Off-road decals Spray in Line-X Bedliner Scosche phone mount Soft rolling tonneau cover TRD pedals and footrest
    You shouldn't need uca's because you have new spindles. Would definitely help but you don't NEED them
  15. May 4, 2017 at 7:41 PM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    Mines at 2 inches up front and the guy got it in at 0 camber and 2.6 caster.
    mattc likes this.
  16. May 4, 2017 at 8:20 PM
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    You mean / \ ?
  17. May 5, 2017 at 3:01 AM
    Les7311
    :annoyed::annoyed:I read almost all the 77 pages in the tundra link about alignment.
    I am spooked learning a truck. am great on cars, not truck., much less a lifted truck.
    I have a \ /, and pulling to the left.
    Some say I do, some say I don't need an adjustable UCA
  18. May 5, 2017 at 4:52 AM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    Does \ / mean you think you have positive camber? If so, it doesn't look like it to me from the pictures you provided, then again, it's hard to tell from just looking at it.
    What size lift are you running? Anything around 2.5 and above it is needed. Mines lifted 2 inches and doesn't need them. I have 0 degrees camber and 2.6 caster. If I wanted more caster I could get UCAs but it really isn't needed.
    As far as pulling, that could be from a lot of things including tire pressure. Here where I live, all of the roads are on a slant for some reason so my truck is always pulling to the passenger side until I get out of town and onto level roads.
    If it's bothering you, just get the alignment checked.
  19. May 5, 2017 at 2:20 PM
    Les7311
    Am on a 6 inch RC lift
    Rotated front tires yesterday and still pulls to left so not radial pull.
    The tires looks like a bow legged when looking at it .... if that's what you mean
  20. May 5, 2017 at 2:30 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    They probably made your camber go negative to get your caster in spec. If you don't get UCA's, it's probably better to get your camber to 0 to 0.2 and just have your caster out of spec.
    BlueFalconActual likes this.
  21. May 5, 2017 at 4:01 PM
    AKJ78
    AKJ78 New Member
    Aaron
    San Diego
    2016 Silver Platinum 4X4
    3/1.5 lift. TRD sway bar. Bakflip V1 cover. Fuel wheels w/BFG A/T.
    IMG_3496.jpg As I'm trying to get educated on alignment specs I decided to take a closer look at the printout I received after having my alignment done this past Monday. This was after installing 6112 and SPC UCA. 6112 on top setting with 1/2 inch shim (measured just over 3" lift up front). My truck drives straight and feels good but I just noticed several out of spec readings. Am I reading this correctly? I'd expect to see more green. Dealership told me everything was good!
  22. May 5, 2017 at 4:29 PM
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    I'm just learning about all this as well. This helped me out
    https://www.tirerack.com/tires/tiretech/techpage.jsp?techid=4
    From what I've heard, someone correct me if I'm wrong, but sometimes you need some of your specs slightly out of whack to track straight. This is the reason tire rotations are a must.
  23. May 5, 2017 at 4:33 PM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
  24. May 5, 2017 at 4:49 PM
    Les7311
    Spoke with toytek and they can't guarantee me installing the SPC UCA wil correct camber or pull. Grrrr
  25. May 5, 2017 at 9:34 PM
    AKJ78
    AKJ78 New Member
    Aaron
    San Diego
    Great article, thank you for sharing!
    Dustydirt19[QUOTED] likes this.
  26. Jun 8, 2017 at 8:24 AM
    Mejarrett9
    Mejarrett9 New Member
    Charlotte, NC
    16 Crewmax 1794 super white
    More on the way
    I just put a set of billy 5100s on (top setting) with new wheels and tires. Tires have a slightly more aggressive offset than stock (+25). I just took in for an alignment. They put it spot on perfect. +.1 or +.2 camber with a caster setting in the 2.5 to 3 range. with toe set at .08 on both sides. Dead center of the green on the measurements
  27. Feb 13, 2018 at 8:32 AM
    Big Green Thing
    Big Green Thing My cause is to have no cause.
    Dallas, TX
    '17 Limited White 4x4
    DAP Tune. 1.5" level on front. Revolver X2 Roll Back. Firestone 2445 air bags. TRD sway bar.
    @Netmonkey I see you are running 295/55 on what appears to be factory 20's. Did you have to make any adjustments to run that size with the 5100's on middle setting? I plan on taking out my 1.5" front spacer and installing the 5100's whenever it is time for a tire change and want to go with 285 or 295 on my factory 20's. Thanks in advance.
  28. Feb 13, 2018 at 8:58 AM
    Netmonkey
    Georgetown, TX
    With the 5100's set at middle (1.57") setting, I only had to remove the little front spat. no other adjustments or modifications were required. you can check out my build thread for pictures of how much clearance is left.
