Alignment out 3 times in 7 weeks
Discussion in 'Suspension' started by sdp5140, May 21, 2019.
  1. May 21, 2019 at 1:09 PM
    sdp5140
    sdp5140 [OP] New Member
    2018 Tundra Off Road
    Hi All!
    I've spent a long time reading but its finally time to post!
    I have a 2018 Tundra SR5 4x4 with the off road package all stock. Every since I bought the truck new last year I've had alignment issues and tire balancing issues. First alignment was at 5,000 2 months after buying the truck. I've dealt with it and complained every visit and service after that. They keep blaming the balance but finally forced them to check alignment.
    In the last 6 week's I've had it aligned 3 times. Toyota dealer telling me they have no clue, Corporate is telling me they won't do anything. Any advice or suggestions on what could be causing this? I've attached the most recent alignment specs below:
    Most Recent Alignment
    Middle Alignment
    First Alignment
    My tundra is scary to drive, it feels like I have no control over it and just drifts all over the road no matter what. I'll be trading it in shortly if I can't figure this out
    Thanks!
  2. May 21, 2019 at 1:18 PM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Something is evidently way wrong with it you are going to have to keep pushing until someone clicks and figures out what is wrong or take it to another dealer and hold the have someone there that has a little more going for him other than showing up and being on automatic and getting a check!! Good luck!! They should be going out of their way to figure it out!!
    Black Wolf likes this.
  3. May 21, 2019 at 1:19 PM
    sdp5140
    Thanks for your reply! I've actually been to two dealers now. The first day after it appears to be fixed but almost immediately after a few miles its all over the place again. Very annoying and customer care is doing very little to help resolve the issue.
  4. May 21, 2019 at 1:25 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Call up a couple of reputable off-road shops in your area and ask them where they go for alignments.
    Black@Blue19, TheBeast and 15whtrd like this.
  5. May 21, 2019 at 1:26 PM
    15whtrd
    15whtrd Mr. Blonde
    I wonder if they were torquing the LCA bolts to spec after alignment. If not it can go out of spec quick. 207 Ft lbs
    joonbug, Black Wolf and TheBeast like this.
  6. May 21, 2019 at 1:27 PM
    Mnorris1206
    08 tundra
    Something has to be coming loose some how. I wouldn't deal with the dealership even under warranty if they cant figure it out have a good mechanic check it over somewhere else as well.
    15whtrd likes this.
  7. May 21, 2019 at 1:28 PM
    TheBeast The Beach
    time to go see a legit alignment shop.
    Pinay, Mnorris1206 and 15whtrd like this.
  8. May 21, 2019 at 2:08 PM
    Black@Blue19
    Ken
    SE Texas
    And make the shop management get in there with you and ask him why they can’t figure out what is wrong with the truck they sold you. Find out who did the mods for them and take it there??! Other than that good luck let us know when they find that simple thing they are over looking and fix it for you!!:)
    Pinay and 15whtrd like this.
  9. May 21, 2019 at 4:01 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Would definitely take it to a bonafide alignment specialist then save whatever receipts you get and have Toyota reimburse once the culprit gets fixed.
    Have you looked up the local lemon laws for your state?
    Black@Blue19 likes this.
  10. May 21, 2019 at 4:14 PM
    JeremyGSU
    JeremyGSU New Member
    Jeremy
    2016 Tundra
    What are the symptoms you are experiencing? Are you sure you're not experiencing tire pull from the road crown? My '16 Tundra can do this pretty bad depending on how bad the road is crowned to the point it feels like your alignment is off and the wheels is crooked trying to go straight.
    In Florida it's difficult to find a completely flat road whereby I can test the alignment out but there happens to be one near where my dealer and house is. I drive on it once and awhile to verify it's still correct.
    I've also found different tire brands pull more than others. My Bridgestones tend to pull more to the sides than my Michelin ATX's.
    The Tundra steering also requires frequent input compared to other vehicles I've owned. You're always tinkering with it on the highway.
  11. May 21, 2019 at 4:17 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Looks like your toe keeps getting knocked out. I'd try a specialized alignment shop. Make sure they torque your cam bolts properly. Then mark your alignment cams with a sharpie to make sure they don't move after your alignment.
    GodlessPro and 15whtrd like this.
  12. May 21, 2019 at 4:33 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    What tires are you running? Stock Michelin LTX AT2s still?
    At what pressure?
  13. May 21, 2019 at 4:43 PM
    sdp5140
    The symptoms always make me think it’s road crown because it Will pull either way based on the road. The extreme lack of being able to track straight even on major highways like 95 always make me think something is wrong. I have to fight the wheel to go straight. Also yes, running Michelin’s Ltx at2 at roughly 40 psi. Any lower and I get extreme shake in the steering wheel as well. They just added 3.5-4 oz to each tire to balance, which seems to fix the shake issue. Still unsure why the alignment would constantly go out. Calling the 4x4 shop tomorrow to ask for an alignment specialist recommendation!
  14. May 21, 2019 at 4:47 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I’m not sure which angle does it, but isn’t it possible that an alignment is “too perfect” and thus causes the truck to follow every angle in the road?
  15. May 21, 2019 at 5:36 PM
    Js18tundra
    Js18tundra New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
    Tires can be bad as well, if it’s pulling a certain way, rotate the front tires side to side, the pull will follow the tire
    Keisuketak likes this.
