Alignment needed after wheel offset change?
Discussion in 'Wheels & Tires' started by BTBAKER, Feb 7, 2018.
  1. Feb 7, 2018 at 11:03 AM
    BTBAKER
    BTBAKER [OP] .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    I’m going to be going from a +6 offset to a +20 offset. Is it wise to have an alignment done after making this change? I just had wheels/tires put on and had it aligned right after.
  2. Feb 7, 2018 at 11:17 AM
    chphilo
    chphilo Tundra addict
    Western PA
    What I swapped the wheels, I did not get an alignment. I did not notice any adverse effect.
    When I changed out the suspension, I did get an alignment. That's a must for suspension change.
    BTBAKER[OP] likes this.
  3. Feb 7, 2018 at 11:43 AM
    RickC
    RickC NOT a new member
    Rick
    Knoxville TN
    2017 CrewMax Platinum 4x4 5.7
    SCS Wheels, Line-X, WeatherTech, UnderCover Flex bed cover
    You won't need a new alignment when changing wheels.
  4. Feb 7, 2018 at 11:46 AM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    I went from 305/65 +12 to 295/70 +25. I had them rack it on the rack just to check my #’s after new setup and it was very close. It might have gone off by .1-.2 at most but I’m not sure if that’s cus of the new setup or just from driving it around.
    So my answer is it should be fine but if your ocd like me have them rack it to check your #’s.
    Watt maker, BTBAKER[OP] and Slayer like this.
  5. Feb 7, 2018 at 11:47 AM
    AxelsHumanDad
    AxelsHumanDad Get off my lawn.
    KAIG, NW of The Frozen Tundra
    2015 CM Platinum
    Some suspension tweaks
    Depends how anal you are about stuff like that. Sooner or later it would keep me awake wondering so I myself would have it done. I have exact numbers I want my alignment set at though, "in the green" isn't good enough.
    Probably not necessary though.
    Watt maker and Slayer like this.
  6. Feb 7, 2018 at 12:02 PM
    Slayer
    Slayer Member
    Slayer
    New wheels?
    Alinment cheap
    Tires not so much
    Agreed.. don’t know if I could sleep
    BTBAKER[OP] and AxelsHumanDad like this.
  7. Feb 7, 2018 at 5:50 PM
    BTBAKER
    BTBAKER [OP] .
    Brad
    Castle Rock
    Thanks. I took it to Brakes Plus on my last one because they said their state of the art equipment would allow them to tell the computer if you have a lift etc and the computer adjusts the setting accordingly. I don’t know enough about alignment to tell them what I want.
    AxelsHumanDad[QUOTED] likes this.
  8. Feb 7, 2018 at 6:04 PM
    If you decide to get an alignment, go to someone who will do it right. @ToyTec Lifts deals with lifted vehicles all day, let alone being one of the Tundras.com guys David will be sure it’s setup
