Alignment issues with 5100’s
Discussion in 'Suspension' started by Jsnake89, Jun 25, 2020.
  1. Jun 25, 2020 at 7:46 AM
    Jsnake89
    Jsnake89 [OP] New Member
    Dane
    2019 Tundra TSS SR5 8W2
    Bilstein 5100 3/1 Pro Comp 1" Blocks, 12Volt Remote start.
    I bought a new 2019 TSS and took it to an off rod shop and have some work done. I added Bilestein 5100’s all
    The way up and Rhino 1”blocks in the rear. I have had to get 3 alignments done answer because my Toe off out on the front. I’m getting terrible uneven ware on my tires. I really don’t want to go back to the same place a 3rd time as they just fix it and send me on down the road.
  2. Jun 25, 2020 at 7:58 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Cranked to 3 inch lift- you need adjustable UCAs to get alignment back to spec.
    Jsnake89[OP] likes this.
  3. Jun 25, 2020 at 5:08 PM
    Yep...throw on a set of SPC's.
  4. Jun 25, 2020 at 7:34 PM
    Jsnake89
    Dane
    Thx I have started looking , man these aren’t cheap
  5. Jun 26, 2020 at 10:33 AM
    jalam321
    jalam321 New Member
    2018 Tundra CM Platinum 4x4 and Sequoia Platinum 4x4
    The bilstein 5100 on top setting should only be around 2.25 -2.5. Did you add any spacers or shims? It should be able to align with no problems unless you added more height.
  6. Jun 26, 2020 at 10:41 AM
    Charvonia Design
    Charvonia Design Enthusiast-Owned Small Business Vendor
    Keith
    Huntersville, NC
    2024 Tacoma TRD OffRoad Bronze Oxide
    Next time ask for them to print out the alignment sheet and post it here. No way to tell if they're actually doing a good job without seeing the before and after numbers. It took me four tries, including two at the Toyota dealership to get them to align my truck properly after I installed 5100s on the middle setting. A lazy tech will "set the toe and let it go" but you need the caster and camber brought back within spec. Ideally they will put it at the MIDDLE of the spec, not right on the edge of acceptable numbers.
  7. Jun 26, 2020 at 10:56 AM
    ckkone
    ckkone New Member
    SLC, UT
    Umm you have a 2019 TSS, $600 for some UPC shouldn't be an issue.
