Alignment issues westcott lift
Discussion in '3rd Gen Tundras (2022+)' started by BW247!, Mar 20, 2023.
  1. Mar 20, 2023 at 3:18 PM
    BW247!
    BW247! [OP] New Member
    Bryant
    Louisiana
    2023 white SR5 TRD Offroad
    Westcott 3/1 lift 35” Nitto Ridge grapplers Fifteen52 Range HD 17” wheels JB4 tuner
    I had the westcott 3/1 collar lift with 35” tires installed on my 2023 sr5 Trd off road package tundra today and they couldn’t get the alignment right. This shop has installed several of these kits with no issues just not on tundras with red shocks like mine. Tried reaching out to Westcott but no reply yet.Anyone else have this problem? Any help would be greatly appreciated.
  2. Mar 20, 2023 at 3:34 PM
    Tbrandt
    Tbrandt I read it on an internet forum, it must be true.
    Tristan
    Kansas City
    2021 SR5 DC TRD Off-Road
    Kenwood DMX907S + Maestro iDatalink RR2 Kenwood DRV-N520 dash cam Kicker Door Speakers TRD rear sway bar Firestone airbags + Daystar cradles Setrab oil cooler, OEM thermostat and hard lines Century High-C topper Bedrug Helmholtz resonator on stock exhaust Sound deadened + insulated cab Platinum 20s, hwy tires Viair 400P
    What numbers are out of spec? Caster? Camber? Toe? Are you still on stock upper control arms? Was the truck aligned correctly before the lift went on?
    You’ll loose caster at a 3” lift which is why aftermarket upper control arms are recommended.
  3. Mar 20, 2023 at 3:52 PM
    Quick_23TundraPlat
    Quick_23TundraPlat New Member
    2023 Tundra Platinum MGM
    Westcott Lift AVS/Rear Air, 35/12.5/18 Toyo Open Country AT3, Method 305 NV 18x9 (+18 Offset), Extang Solidfold 2.0 Tonneau
    Westcott has a video on YouTube that has some tips on dialing in the alignment— not sure if that will help but it’s worth a shot if you can send it to your techs.
  4. Mar 21, 2023 at 1:32 AM
    dbrock34
    dbrock34 New Member
    Dean
    2023 Tundra Platinum I-Force Max
    My shop couldn't get it to work either. I took it to the dealership and they didn't have any trouble. I have the Platinum with AVS.
  5. Mar 21, 2023 at 7:12 AM
    jsf343
    jsf343 New Member
    jeff
    soon 2023 toyota TRD pro
    Is this actually with the Trd pro as well?
    if Aftermarket upper control arms are needed what is a good brand to look at? I really don’t want to dump more money into it right now but at the same time I want it to be right, if I need to be changing these out I will.
