Alignment issues after tie rod replacement
Discussion in 'Suspension' started by Trdprotundramason, Sep 21, 2023.
  1. Sep 21, 2023 at 1:14 PM
    Trdprotundramason
    Trdprotundramason [OP] New Member
    Mason
    2017 tundra trd pro
    Coachbuilder lift wheel spacers , bumpers,winch ,lights ,air bags
    2017 trd pro with coach builder shim tie rods bumpers spacers etc kit - won’t align - or stay in alignment after tie rod rebuild
    I ordered the tie rod rebuild kits from coachbuilder and replaced them now alignment shop can’t get truck to allign correctly it seemed like it was ok the first time I left shop as soon I hit some uneven road it’s back to being significantly off worse than it was before I went again they couldn’t get it aligned said maybe the steering bushings so I ordered a set of energy bushings another shop that I was going to have install them said the ones on the truck were fine and it was related to alignment not bushings anyone else have similar alignment issues after tie rod replacement? It seems pretty straightforward install so im a little confused why the shop couldn’t get it right
