Alignment Help...
Discussion in 'Suspension' started by CaptTyler, May 14, 2016.
  1. May 14, 2016 at 4:30 PM
    CaptTyler
    CaptTyler [OP] Life’s too short to have an ugly boat.
    Tyler
    2018 Ram 2500 Cummins
    So I'll try to keep this short. I have a '12 CM and just about to install some 5100's all around with a CB shim on the driver strut to help with the "driver lean".
    Also throwing some CB +2 shackles on rear.
    The shocks
    will be on the top setting.
    I've always had bad luck with tire wear and alignment. I need help figuring out where to go and how to get it right the first time.
    Anything in particular I should tell them? Not sure if it should just be within spec or what.
    Thanks in advance.
  2. May 14, 2016 at 4:37 PM
