Alignment Help
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by TRD PRO 17, Dec 5, 2017.
  1. Dec 5, 2017 at 8:08 AM
    TRD PRO 17
    TRD PRO 17 [OP] New Member
    Tyler
    2015 Inferno Crewmax TRD PRO
    2015 PRO with Coachbuilder's setup. Shims up front for 1" of lift and +3 shackles for an extra 1.75" in the rear with 295 70 STT PROS.
    Got it aligned immediately after (spec sheet attached) after some time I have noticed that my tires are wearing heavy on the outside and not really hitting on the inside much at all. I've run the chalk test a couple of times thinking it could have been tire pressure related, but haven't had any luck.
    I'm having it realigned at a different shop on Thursday to see if they get it figured out.
    Anyone have any suggestions or insight as to what I should have the shop aim for?
  2. Dec 5, 2017 at 8:12 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    yeah... the camber is causing the outter wear on the tire. get it down to 0.1 or even 0.05 and it will improve.
  3. Dec 5, 2017 at 11:34 AM
    TRD PRO 17
    Tyler
    Would you adjust the toe any? I've seen some say .07 per side and then others say .12 per side.
  4. Dec 5, 2017 at 11:38 AM
    Netmonkey
    Georgetown, TX
    your toe is good. between 0.07 and 0.12 is where you want to shoot for.
  5. Dec 5, 2017 at 12:10 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    My tires wear best at .05 w/.1 total toe. Anything more caused feathering.
