Alignment cost question
Discussion in 'Suspension' started by chunk, Mar 18, 2025.
  1. Mar 18, 2025 at 7:20 PM
    chunk
    chunk [OP] New Member
    110 miles north of Los Angeles, Ca.
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    Tunda in question is a 2001, stock height and tires truck, 2WD: Any idea for an average price? I was quoted $120.00, that seems pricey to me, but it could be I'm living in the past and it's an okay price. I'm in SoCal and this is the closest place that seems to have a decent reputation for good work. Just wondering, not a deal breaker either way. All the suspension bits are in good nic by the way, and before I reshoe it I want an alignment. Cheers.
  2. Mar 18, 2025 at 7:22 PM
    $125-225 is pretty normal here, with $125 being on the low end. That's for a standard alignment. Some places that specialize in offroad stuff will charge more for custom alignment.
  3. Mar 18, 2025 at 7:26 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    Going rate in my town is $160 give or take. I'd get the alignment after the new shoes, not before.
    G_unit3000 likes this.
  4. Mar 18, 2025 at 7:27 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Firestone is about 110 for a standard 4wheel alignment and also offers the Lifetime version for about $200. If you plan to keep it - this is cheaper long run.
    G_unit3000 and OldGuy03 like this.
  5. Mar 18, 2025 at 8:08 PM
    Fragman
    Fragman New Member
    TX
    2006 Tundra DC SR5 2WD V8
    My local mechanic is $85, which is super reasonable. They even test drive it after and make any necessary tweaks. Honestly think it's a loss leader for them, because it's not a 10 minute 'toe and go'. With the CA 'surcharge' you're paying, $120 is pretty good.
  6. Mar 18, 2025 at 8:26 PM
    RobertD
    Robert
    DFW, Texas
    Why would you alignment before new shoes??? Get the alignment with the new tires so they wear correctly. No point setting things up to the old tires.
  7. Mar 18, 2025 at 8:43 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    I paid $120 in SoCal - Monrovia at a Toyota off-road shop. They got me dialed in. They used the alignment rack and offered a digital printout. I will continue to go back there for alignments.
    before that I got a $90 alignment that was done by a shop in Inglewood that was ok/awful and done the old school way.
    get the new tires first then get an alignment right after
  8. Mar 19, 2025 at 6:16 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    100 bucks in Richmond VA
    Get an alignment whenever you get new tires or swap rims- AFTER they have been installed....or have any pull or tire wear issues.
    OldGuy03 likes this.
  9. Mar 19, 2025 at 7:58 AM
    Fedtime
    Fedtime New Member
    An alignment is $150 here in eastern Canada. But some shops will give you a break charging just $85 because, in reality, they are only aligning the front end. The rear axle is not much more than a reference point because there is nothing to align on it really.
  10. Mar 19, 2025 at 8:12 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    I've done my own alignment with SharkEye old school rack only once on every vehicle we have in the family. Much to my surprise, the alignments don't go anywhere, even on old Volvo with self-leveling rear suspension and 20 years old subframe bushings. In about 13 years I own this car no one did the alignment right. Every time something was off. Going back and complaining didn't yield any positive outcome.
    $200-250 is what a reputable tire shop or dealer were asking for alignment a few years back around here in Boston suburbs.
  11. Mar 19, 2025 at 4:56 PM
    wtrbrdm
    wtrbrdm New Member
    Ben
    Eastern VA
    2006 Tundra DC Limited
    Mounting, balancing and alignment are things I'll go to a good shop for. I've had far to many crappy shops do crappy work.... I think my last alignment was $200 at a really reputable shop.
