Alchohol percent on Scangauge
Discussion in '2.5 Gen Tundras (2014-2021)' started by SpooledReel, Jan 8, 2023.
  1. Jan 8, 2023 at 4:15 PM
    SpooledReel
    SpooledReel [OP] Insufficient Funds
    RickyP
    Spanish Fort, AL
    2015 Tundra CM Limited 4x4
    Been searching for a bit with no luck. I would like to set my scangauge up to monitor my alcohol content. Has anyone set this and know the Xcode?
    My 2015 flex fuel has been really giving me some grief lately. I am planning on monitoring and resetting manually as I am well past warranty and have no faith in the dealers resolving. I am aware that the scangauge can’t reset, but I’m going to give the eBay cable a shot. Just gotta track down an old windows based laptop for that. Based on this pic, I assume that this would be my underlying issue?
  2. Jan 8, 2023 at 4:24 PM
    biebs96
    PA
    It’s usually listed right on the can
    :cheers:
  3. Jan 8, 2023 at 4:37 PM
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    bulldog93 likes this.
  4. Jan 8, 2023 at 4:40 PM
    SpooledReel
    RickyP
    Spanish Fort, AL
    Yeah, but wouldn’t it be great to integrate it into your gauges?
    JMB likes this.
  5. Jan 8, 2023 at 4:43 PM
    SpooledReel
    RickyP
    Spanish Fort, AL
    There could even be a little icon on the dash to remind you again…
  6. Jan 8, 2023 at 5:20 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    You ain't the only Toyota FFV with this issue. It's been a mechanic's PITA for years. My mechanic is a Toyota Master and he's tried to play with the numbers just to see what the engine would do and it literally did nothing. Almost like the PCM is operating on a subliminal program unbeknownst to us.
  7. Jan 8, 2023 at 5:32 PM
    SpooledReel
    RickyP
    Spanish Fort, AL
    No doubt, it definitely seems to be a well documented issue. Just trying to take ownership and attempt to control my own destiny.
    53027_RW and texasrho83[QUOTED] like this.
  8. Jan 8, 2023 at 7:06 PM
    737fixer
    737fixer New Member
    I was so excited when I read the title.
    JMB likes this.
  9. Jan 11, 2023 at 3:12 PM
    SpooledReel
    RickyP
    Spanish Fort, AL
    I reached out to scangauge and got a positive response. Here is the code and it is correlating with my other scanner.
    bulldog93, endagon, JMB and 1 other person like this.
  10. Jan 11, 2023 at 3:13 PM
    SpooledReel
    RickyP
    Spanish Fort, AL
    The 4 spots I have are trans pan, torque converter, water and alcohol
  11. Jan 11, 2023 at 4:34 PM
    Is there a TSB update for the FFV trucks that addresses this? I know there’s a fuel pump TSB / recall for the FFV’s.
  12. Jan 11, 2023 at 7:09 PM
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    Thanks, been looking for this forever! Surprised it's reading only 2% right now. It'll be interesting to see how well the calculations track when I switch back to corn drink in the spring.
  13. Jan 12, 2023 at 8:44 AM
    Rocko9999
    Rocko9999 New Member
    Can that scan tool read transmission temperature?
  14. Jan 12, 2023 at 9:31 AM
    SpooledReel
    RickyP
    Spanish Fort, AL
    Possibly, I will have to check tomorrow. I keep my scan gauge hooked up for the readings
  15. Jan 12, 2023 at 9:43 AM
    2mchfun
    Yes, I use a scanguage 2 to monitor both pan and converter.
  16. Jan 12, 2023 at 10:03 AM
    Rocko9999
    I know Scanguage can but I was asking about the Autolink 319.
    2mchfun[QUOTED] likes this.
  17. Jan 14, 2023 at 10:47 AM
    Jeffro22
    Jeffro22 New Member
    2013 platinum crewmax 4x4
    i was able reset mine with the ebay cable. My truck was reading 86% and was having starting issues. SO far so good
    I was able to use the techstream program with a newer laptop no problem. Just follow the download instructions and use virtualbox
  18. Jan 14, 2023 at 7:14 PM
    SpooledReel
    RickyP
    Spanish Fort, AL
    Right on, sounds promising. What is virtual box? I have an older Dell Latitude 3440 tha\t I picked up from a friend. It’s running windows 10.
  19. Jan 15, 2023 at 7:49 AM
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    Virtualbox is free virtual machine software that lets you install an operating system to a file and emulates a computer to run it. The virtual machine only has as much access to the host system as you give it so if you run into malware it is separated from the host. A sandbox, so to speak
    SpooledReel[OP] and Jeffro22 like this.
  20. Jan 15, 2023 at 8:43 AM
    Jeffro22
    Jeffro22 New Member
    I was having issues with the CD and my older laptop. Never could get techstream to load correctly
    Followed the install instructions @ Ih8mud and am running virtual box on windows 10 laptop
  21. Feb 6, 2023 at 10:54 AM
    SpooledReel
    RickyP
    Spanish Fort, AL
    This method worked for me as well after a day of fumbling with the cd. After reset procedure done, truck runs like new.
    NewImprovedRon likes this.
  22. Feb 6, 2023 at 10:57 AM
    SpooledReel
    RickyP
    Spanish Fort, AL
    It’s also been a couple weeks and after the second refuel since reset, my scangauge shows I went from 0% to 11%. Truck still runs fine, but I expect this will be a routine thing to reset.
  23. Apr 7, 2023 at 5:30 PM
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    I can verify that scangauge xgauge works on a ffv that's working properly. I switched to corn swill a couple weeks ago and it went up each tank, first 40%, then 60%, now 67%. It doesn't just shoot the moon at 85% when it computes ethanol presence which is good.
  24. Jun 23, 2023 at 9:28 PM
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    Found a potential issue with the truck's programming for flex fuel with this gauge. UsualIy it calculates a close number. However I caught it staying at 32% alc across consecutive fills when i know for a fact it was over 70% actual from the pump. The old ultragauge still runs with the obd2 splitter so I switched that to display fuel trims and both a/f lambda outputs. The dumb thing must have been adding to the fuel trims during the alcohol learn sequence so ltft were around +25 to +28. That was good for keeping stoich in closed loop with no CEL but I didn't dare let it run open loop wot much because the lowest lambda I could read was .91. Comparing to gasoline numbers that would be like 13.5:1 afr. It apparently does not apply trims fully to open loop conditions so it was going lean. Usually in the past it maxed the lambda reading to what I assume is the limit of the sensor of about .82 in full rich open loop.
    You'd never know without the gauges.
    I filled with about 13 gallons of regular gas (so maybe 40% in there) and the alc number bombed straight to zero, but trims stayed huge. Burned thru that tank carefully and filled again. Still reads zero alc but ltft are down under 10. Gonna repeat again.
    That explains why the truck sometimes felt normal but maybe a little more gutsy with e85 and then other times its such a big difference it becomes very unfriendly to tire life. It can't be good for the engine in the long run.
    Just an fyi, I know I'm not the only one who has tried corn swill
