Alarm System
Discussion in '1st Gen Tundras (2000-2006)' started by joseph_sal, Aug 22, 2019.
  1. Aug 22, 2019 at 6:15 PM
    joseph_sal
    joseph_sal [OP] New Member
    Joseph
    Memphis TN
    2000 Toyota Tundra 4WD SR5
    Hello everyone! My first post on this great forum.
    I purchased my 1st Toyota truck ever! I chose a 2000 Tundra 4WD SR5 Access Cab.
    I’m installing Avital 3100L for the security system & remote start and the installation was going well until I stumbled with the doors lock wires
    There are multiple Door Lock Systems in the installation manual and I have no idea which system my truck has (Type A; Positive pulsing, Type B; Negative Pulsing, Type C; Reverse Polarity.. etc)... Any help would be appreciated.
    Thank you.
  2. Sep 15, 2019 at 8:52 PM
    renkaliko
    renkaliko New Member
    2000 Black Tundra Limited
  3. Sep 16, 2019 at 4:36 PM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
  4. Sep 16, 2019 at 7:47 PM
    02goes
    02goes New Member
    2002 Tundra Limited 4X4
    [QUOTE="TX-TRD1stGEN[/QUOTE]
    TX-TRD1stGEN
    Is the 2003 wiring the same wiring used in the 2000 to 2003 Tundra trucks?
    Or is there a broader year range that the Tundra's electrical system is the same? Example, all of 1st gen the same, or different within 1st generation when body style changed in 2003?
  5. Sep 21, 2019 at 5:47 AM
    renkaliko
    2000 Toyota Tundra Car Alarm Wire Guide
    Battery Constant 12v+ Positive Wire (+): White And White/Red
    Battery Constant 12v+ Positive Wire Location: Ignition Switch Harness
    Starter Positive Wire (+): Green/Black
    Starter Positive Wire Location: Ignition Switch Harness
    Ignition Positive Wire (+): Black/Yellow
    Ignition Positive Wire Location: Ignition Switch Harness
    Second Ignition Positive Wire (+): Black/Red
    Second Ignition Positive Wire Location: Ignition Switch Harness
    Accessory Positive Wire (+): Blue/Red
    Accessory Positive Wire Location: Ignition Switch Harness
    Parking Light Negative Wire (-): Red/Black
    Parking Light Negative Wire Location: At Steering Column Harness
    Parking Light Positive Wire (+): Green
    Parking Light Positive Wire Location: In Drivers Kick Panel
    Power Door Lock Negative Wire (-): White/Green
    Power Door Lock Negative Wire Location: In Either Kick Panel
    Power Door Unlock Negative Wire (-): Red/Yellow
    Power Door Unlock Negative Wire Location: In Either Kick Panel
    Door Trigger Negative Wire (-): White/Blue
    Door Trigger Negative Wire Location: At Drivers Door Harness
    Domelight Supervision Wire: Use Door Trigger, Requires Relay
    Domelight Supervision Wire Location: N/A
    Horn Negative Wire (-): Green/Red
    Horn Negative Wire Location: At Steering Column Harness
    Tachometer Wire Negative Wire (-): On 6-Cylinder Engines, The Tach Wire Is A Black, On V-8 Engines, The Tach Wire Is A Blue/White, Both Wires Are At The Instrument Cluster In A Brown Plug. On The 6-Cylinder, The Black Wire Can Be Found At The Diagnostic Connector Drivers Side Of Engine And On The 4.7L V8 Engine, You Can Use The Black/Blue Wire At Coil #1 On The Drivers Side.
    Tachometer Wire Negative Wire Location: At Instrument Cluster, In A Brown Plug.
    Brake Light Positive Wire (+): Green/White
    Brake Light Positive Wire Location: At Switch Above Brake Pedal
    Factory Alarm Disarm Wire (-): Blue/Black
    Factory Alarm Disarm Wire Location: At Drivers Door Harness
    Factory Anti-Theft System: N/A
    Factory Anti-Theft System Location: N/A
    bmf4069 and TX-TRD1stGEN like this.
  6. Sep 21, 2019 at 5:47 AM
    renkaliko
    2003 Toyota Tundra Auto Alarm Install Diagram
    Second Starter Positive Wire (+): N/A
    Second Starter Positive Wire Location: N/A
    Second Ignition Positive Wire (+): Black/Yellow
    Third Ignition Positive Wire (+): N/A
    Third Ignition Positive Wire Location: N/A
    Second Accessory Positive Wire (+): N/A
    Second Accessory Positive Wire Location: N/A
    Key Sense Wire: N/A
    Key Sense Wire Location: N/A
    Parking Light Negative Wire (-): N/A
    Parking Light Negative Wire Location: N/A
    Parking Light Positive Wire Location: In Harness in Driver Kick Panel
    Power Door Lock Negative Wire Location: In Harness in Driver Kick Panel
    Power Door Unlock Negative Wire (-): Blue/Red (Requires Double Pulse)
    Power Door Unlock Negative Wire Location: In Harness in Driver Kick Panel
    Door Trigger Negative Wire (-): Black/White
    Door Trigger Negative Wire Location: Inside the Driver A Pillar
    Dome Light Supervision Wire (-): White
    Dome Light Supervision Wire Location: Pin #46 in Plug A at BCM Module in Passenger Kick Panel
    Trunk Release Negative Wire (-): N/A
    Trunk Release Negative Wire Location: N/A
    Sliding Power Door Wire: N/A
    Sliding Power Door Wire Location: N/A
    Horn Negative Wire Location: In Harness at Steering Column Harness
    Tachometer Wire Negative Wire (-): Blue/White
    Tachometer Wire Negative Wire Location: Pin #1 in Second Plug at ECM Module
    Wait To Start Wire: N/A
    Wait To Start Location: N/A
    Factory Alarm Disarm Wire (-): N/A
    Factory Alarm Disarm Wire Location: N/A
    TX-TRD1stGEN likes this.
  7. Sep 21, 2019 at 5:48 AM
    renkaliko
    2002 Toyota Tundra Car Alarm Wiring Instructions
    02goes and TX-TRD1stGEN like this.
