Alarm going off while charging battery, need help!
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tundrafan23, Jan 5, 2022.
  1. Jan 5, 2022 at 3:17 PM
    Tundrafan23
    Tundrafan23 [OP] New Member
    I recently had ankle surgery and have not been able to drive my truck for over 2 months. I knew the battery would be dead but when I hooked up my CTEK charger to it the taillights started flashing and the alarm started going off. I think the reason why is because I had to use the physical key to open the door to pop the hood and when I tried to use the Fob to deactivate the alarm the battery did not have enough juice yet for the key fob receiver. Has this happened to anybody else? Any way I can turn off the alarm besides the key fob? Thanks
  2. Jan 5, 2022 at 3:21 PM
    Does putting the key in the ignition and trying to start the truck shut it off? What year?
  3. Jan 5, 2022 at 3:22 PM
    Tundrafan23
    2020 I have push to start
  4. Jan 5, 2022 at 3:22 PM
    Also until you get if off, you can unplug the horns to kill the noise at least.
    Bob and 1lowlife like this.
  5. Jan 5, 2022 at 3:25 PM
  6. Jan 6, 2022 at 10:20 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    disconnect the battery cables. Leave them disconnected. Charge the battery, once changed, reinstall the cables.
  7. Jan 6, 2022 at 10:23 AM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    ^ this
    NewImprovedRon and Dr Doobie like this.
  8. Jan 6, 2022 at 9:24 PM
    2020Platinum
    2020Platinum www.youtube.com/NitroZ18Fishing
    Patrick
    Northeast PA
    2022 TRD Pro (Lunar Rock)
    A lot. See my channel for all installs/mods!
    As mentioned above, I would disconnect battery, charge, and reconnect…I’ve never seen that happen before but that should get ya squared away!
    NewImprovedRon likes this.
  9. Jan 6, 2022 at 10:22 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    This is genius and I never would have thought of doing that..
    Kudos to you Sir..
    frichco228[QUOTED] likes this.
  10. Jan 7, 2022 at 2:28 AM
    handyman
    handyman New Member
    2016 Crewmax Limited in Sunset Bronze Mica
    BFG All-Terrain TA KO2 Tires, Pillar Grab Handle, Curt Front Hitch & Winch Mount, Smittybilt XRC-8 Winch, Escort Solo S3 Radar Detector, Tekonsha P3 Brake Controller, Galaxy DX 2547 CB Radio, Center Console Organizer & Tray, ESP Rear Seat Storage, SumoSprings, Pop & Lock Tailgate Lock, AMP Bed Step, AMP Side Steps, BacFlip G2 Tonneau Cover, and more pending.
    I've never let the batteries in my vehicles go completely dead. If I'm going to be away for any length of time, I leave a small trickle charger hooked to the batteries. Even have one hooked to my lawn mower over the winter.
    hagrid likes this.
  11. Jan 7, 2022 at 5:04 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    The easiest way to destroy a lead acid battery is to let it sit in a deep state of discharge. Even if you can recover it you've suffered a permanent penalty to capacity.
    RitcheyRch likes this.
  12. Jan 7, 2022 at 7:50 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    My truck has been sitting at the dealership for 2 months.
    I know the battery is dead because it won't connect to my drone mobile app.
    Good thing the battery is under Interstate warranty..
  13. Jan 9, 2022 at 9:50 PM
    Tundrafan23
    It's a Northstar AGM, they claim it can be discharged to 10% over 400 times before causing any long term damage.
  14. Jan 9, 2022 at 10:07 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    Oh no an AGM. :eek2:
    Should have had that CTEK trickle charging if you weren't going to be using the truck for a few days/weeks. :rolleyes:
    It's a widely discussed issue on the forum with AGMs that they need to be topped off monthly..:thumbsup:
    My Batteries Plus PowerX2 (allegedly a Northstar) died twice when it was new.
    They refused to honor the warranty.
    I traded it in on a core charge for an Interstate..:D
  15. Jan 10, 2022 at 2:44 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Did they state how long it can sit at 10%? Because that's where the damage is done... time.
  16. Jan 10, 2022 at 5:46 AM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    Oh noes.....
    Based on your post I got concerned, so I checked on my truck battery.
    CRAP...Just found two lumps on my battery
    Tested them, one came back positive.
    I hope it's not terminal.
    hagrid[QUOTED] likes this.
