Alarm going off after replacing battery 2018 4x4 offroad SOLVED
Discussion in 'General Tundra Discussion' started by Tundra$, May 15, 2022.
  1. May 15, 2022 at 11:00 AM
    Tundra$
    Tundra$ [OP] White Trucks Matter
    Las Vegas
    2018 SR5 4x4 off-road CM 5.7 Super Fast White
    3/1 readylift, 35x11.5r20 ridge grapplers, 20’ fuel wheels, bakflip revolver bed cover, console safe, N-fab side rails, mini antenna, 2019 TRD Pro grill, color match hood bulge, front bumpershellz, baby car seat, to be continued...
    After replacing the battery when I turn the ignition my alarm goes off. I don’t have an aftermarket alarm. The only alarm is the standard alarm that came with the truck new. There is the Toyota dealer added alarm blue blinking light thing that was supposed to be disconnected and unusable due to me not wanting to pay the extra fee. It’s blinking but I don’t know if that’s the issue or it’s even activated. I have the standard 2018 tundra key with the lock / unlock / red panic horn button thing.
    Any idea what to do? It’s Sunday and dealers are closed.
    edit. I’ve tried unlocking and locking the doors while alarm was going off. I even drove it around the block with the alarm going off and problem persists. After I shut off the truck, lock the doors and wait for a few alarm cycles the alarm stops until the next time I turn the ignition
  2. May 15, 2022 at 11:05 AM
    Adam New Member
    Try unhooking the truck battery for 5 min. Also, try a different key
    Tundra$[OP] likes this.
  3. May 15, 2022 at 11:45 AM
    Tundra$
    Las Vegas
    Solved. On the blinking blue alarm thing above the e brake there’s a small button. Hit it once alarm shut off then turned back on, started truck hit the button again and alarm went off and stayed off.
  4. Jul 17, 2022 at 11:44 AM
    Gustavo
    Gustavo New Member
    Gustavo
    2015 Tundra SR5
    3” Lift. Bilstein shocks, SPC upper control arm, VLAND headlights
    I just replace the battery on my 15. Ran into the same issue. Wish I would have seen this post earlier because that’s exactly what I did to make it stop. I actually disconnected my hornds to troubleshoot without all that noice. Was not fun.
  5. Apr 3, 2023 at 8:56 PM
    justamon
    justamon New Member
    Justin
    2020 Tundra SR5
    Ram mount accessory dash bracket.
    Looks like I'm going to have to pay the dealership mechanics again. I tried the sequence of button pushing and starting the truck to no avail. It's interesting that the alarm only started going off after I reconnected the auxiliary ports after re-assembling the dash system.
