AJT CHROME DELETE DOOR HANDLE COVERS
Discussion in '2.5 Gen Tundras (2014-2021)' started by TommyTundra, May 17, 2021.
  1. May 17, 2021 at 5:05 PM
    TommyTundra
    TommyTundra [OP] Oh God the anger’s changing me
    Long Island NY
    2019 PRO
    Just got these in the mail today and put them right on. Very straight forward and simple. Much neater cleaner lines than the vinyl wrap that I had done. VINYL WRAP SUCKS SO BAD IT HURTS!!!39337B70-61C2-41AB-8E5A-9BF5F237A46C.jpg
  2. May 17, 2021 at 5:14 PM
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    '21 Cavalry TRD Sport CM
    I have these on order, but after watching the install video it looks like the covers hit/make contact on the trim that surrounds the handle. which looks like it leads to scuffs/ scratches.
    can you confirm if it clears or if it rubs?
  3. May 17, 2021 at 5:21 PM
    TommyTundra
    Long Island NY
    2019 PRO
    I dry fit them first because the install video said they may rub. Three of the four were fine. One rubbed ever so slightly so i wet sanded it slowly for a bit and it was all good. The key thing i discovered is when installing them when you slide them over the handle as they get about 3/4 of the way on i kinda hit them home with one hand and squeezed tightly around the base of the handle closest to where it attaches to the door to seat them and set the double back tape.
    donbun68 and Toe404 like this.
  4. May 17, 2021 at 5:22 PM
    donbun68
    donbun68 New Member
    Kentucky
    2017 Black Tundra
    TRD exhaust, cold air intake, interior mods.
    Got mine installed too.
  5. May 17, 2021 at 6:22 PM
    Taco-Spike
    Two Trucks
    Looks good
    donbun68 likes this.
  6. May 17, 2021 at 8:54 PM
    TunBrun
    TunBrun New Member
    Sunnyvale, CA
    2017 5.7L Crewmax Blazing Blue
    Installed mine today too. 3 of the 4 worked great. One was rubbing on the edge where the lock mechanism is. I wish I had dry fit all four ahead of time. Probably will (try to) take it off and sand it down a bit and then use my own adhesive.
  7. May 18, 2021 at 9:15 AM
    gtoninn
    gtoninn New Member
    Andy
    2015 Tundra Platinum
    Mine just came in yesterday! Gonna put them on after work today. Will report back about the rubbing if there is any. This just comes down to tolerances from Toyota when they make these handles, and AJT doing their best to stay within the average gap size. Can only make these covers so thin!
  8. May 18, 2021 at 9:23 AM
    RussellVaughan
    RussellVaughan New Member
    Houston
    2015 Gray TSS 5.7 CM SR5 4x4
    AMP Research PowerSteps; Katzkin leather seats (Nightrunner, all black, no perf/logo); TRD 18" BBS Forged rims; Nitto Terra Grappler G2 LT295/70R18) tires; LT295/70R18 spare tire; Rough Country speedo calibrator; Fox 2.0 IFP front & rear w/1" leaf blocks; TRD PRO black headlamps w/Headlight Revolution harness; TRD PRO grill w/color match hood bulge; RCI engine skid plate; BakFlip MX4 tonneau; Baja Design Squadron Sport fog lights w/clear wide lens; front/rear color match bumper covers; K&N CAI; Pedal Commander throttle controller w-trailer brake bezel; SE Toyota wireless charger tray; VLEDS interior and exterior LED lights; AJT Designs interior chrome delete; Sparks Parts driver side grab handle kit; Pop&Lock tailgate lock; ICS Fab dash mount w/support plate; ICS Fab center console mount; SNS Custom Design ABS sensor guards; TRD PRO shift knob; Undercover Swingcase bed storage; Rad Rubber Design engine splash guards; Bull Ring bed rail tie-downs; exterior debadge w/black & engine badge and black 4x4 badge; Charvonia Design billet bed tie-down anchors; rear console USB port; TRD rear sway bar; Fumoto Oil Pan Valve; Toyota metal oil filter assembly; Vexing R1 dash cam; X2Power 24F Battery.
    I got mine and installed one. I am not impressed. They are clearly not designed to fit without rubbing.
    https://youtu.be/fPSpPEyZiz0
  9. May 18, 2021 at 4:56 PM
    donbun68
    donbun68 New Member
    Kentucky
    2017 Black Tundra
  10. May 18, 2021 at 4:57 PM
    donbun68
    donbun68 New Member
    Kentucky
    2017 Black Tundra
    My drivers door does exact same thing. The rest don’t rub at all.
  11. May 18, 2021 at 5:21 PM
    Franco4x4
    Franco4x4 New Member
    2019 tundra CM
    I 4 of mine rub. I thought I did something wrong
  12. May 18, 2021 at 6:35 PM
    RussellVaughan
    Houston
    I just tried my rear left and it’s even worse. Door grab sticks out about a centimeter because it can’t close all the way.
  13. May 19, 2021 at 3:26 AM
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
    Was going to buy, but after watching the AJT install video and the mention of rubbing, I held off. Thanks for confirming everyone.
  14. May 19, 2021 at 8:31 AM
    RussellVaughan
    Houston
    Hopefully they go back to drawing board on these. I reached out to them today and they appeared to not be aware of the issue....but also acknowledged they rub...so who knows. I can return them, but have to pay shipping and 5$ restocking fee (unless they deem them defective).
    TucsonTundra1794 and rons23 like this.
  15. May 22, 2021 at 3:03 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    Finally got my truck back and installed these. Mine rub, 3 of the 4 do. I slid them back as far as I could with the handle 1/2 open and they still hit on the handle side (not the side closest to the lock but the open side that is not connected to the door) I'll keep them on for now but would be interested in a replacement if they can get the fitment dialed in. On the same subject, my cup holder surround and shifter surround also had some minor issues with attaching the screws, some of the areas I was told to drill out had no plastic left to grab the screw afterwards and I think that's the reason they sit slightly loose after install. I'm not upset about it, I understand I'm choosing to modify my truck and I understand from his standpoint what he's trying to accomplish so if I want it to fit more snug maybe I'll glue them down. As for the doors, I'll keep these unless something better comes out, I still like them much more then chrome.
  16. May 22, 2021 at 4:48 PM
    token2k6
    token2k6 New Member
    2021 Tundra CM SR5
    Received my Cement set today. The driver's side set went on smooth, ever so slightly touch. Passenger side ... both make a popping noise when using the handle. They are definitely hitting/rubbing more. People are talking about sanding, but what part? Lol. I think this is always the case with first run AJT stuff. A year from now, should be smooth with kinks worked out, or maybe this was a tough area to tackle. The way I figure, if they scuff, that's fine, it will be covered up most of the time. If you use the heat gun trick, shouldn't it go away? But a noise or popping sound is not the greatest.
    And @TusconTundra - totally agree about the shift trim set. Did it on my 2017 when it first came out, all perfect for the install. Did it again on my 2021, and yeah, no meat for the screws to engage with, so a couple of mine are sitting cocked. Didn't know if Toyota changed the mold a little on the center console or what..it was way more difficult on the new truck.
  17. May 24, 2021 at 9:31 AM
    gtoninn
    gtoninn New Member
    Andy
    I got mine on and the driver side pushes out the door panel ever so slightly behind the handle. But I think they look great! It doesn't hurt the panel, and for this price I am super happy with the outcome.
    It is difficult to create a product to fit in the gap that a OEM never intended to be filled, so getting it to fit this well is an accomplishment.
    @TucsonTundra1794 I had the same problem with my shifter surround from AJT, no tab to screw through, I intend on adding a washer and a longer screw to grab onto the plastic near by to sure it up. I think this is just a variation in the center console from year to year. Toyota will make minor changes like that and AJT may have just designed it around one particular revision.
    the ER kid and TucsonTundra1794 like this.
  18. May 27, 2021 at 3:48 PM
    Lightning2186
    Lightning2186 New Member
    2018 Toyota Tundra SR5
    I really want to get the chrome handle deletes but I don’t know if they rub! Don’t want to scratch my interior!
  19. May 27, 2021 at 3:56 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    you can get the SR trim version that are grey, gonna be a lot more expensive though
  20. May 27, 2021 at 6:03 PM
    2mchfun
    Sometimes engineers chrome certain things for a reason. For example, light will reflect off a chrome door handle better to help you see it in the dark. Just an opinion, not an argument.
  21. May 28, 2021 at 6:17 AM
    Jkenn6
    Jkenn6 New Member
    NJ
    23 Tundra
    Interesting, glad I saw this thread before ordering - might wait a bit on these.
  22. May 28, 2021 at 6:24 AM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    1lowlife and 5150bronco like this.
  23. May 28, 2021 at 9:52 AM
    BLACKBEARD
    BLACKBEARD New Member
    Marvin
    2017 Tundra TRD Off Road
    so when I did my install on the chrome delete kit, I was able to make solid contact on plastic with all four corners. I still can’t figure out how people are missing plastic here.
    WILLINH likes this.
  24. May 28, 2021 at 9:58 AM
    gtoninn
    gtoninn New Member
    Andy
    So bottom left in your picture. There is not a solid piece of plastic there. There was only enough for the drilled out plastic weld. So because there isn't the plastic mine can lift ever so slightly. I plan on getting longer SHCS and replacing them (to make them all look the same) and adding a washer under the nut to widen where it can hold onto.
    This is due to different revisions of the center console plastic. In the manufacturing world something may look exactly the same to the outside, but get minor changes underneath to account for issues found in the field. Maybe cracking or problems found from car accidents, etc. You truck appears to be a 2017 and mine is a 2015. You also have the small coin holder behind the shifter and mine does not. So definitely a different revision.
  25. May 28, 2021 at 10:11 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    Mine does not have a full piece of plastic all the way around like yours, mine only has small pieces were the old piece attached.
  26. May 28, 2021 at 10:12 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    These thing sound like they suck!
    Too bad, as their other products all seem to work fine.
  27. May 28, 2021 at 10:14 AM
    Tundra18overland
    Tundra18overland Traversing the million mile road
    Jesse
    GA
    2018 SR5 CM Expedition Build
    looks good, those are completely new handles?
  28. May 30, 2021 at 4:36 PM
    5150bronco
    5150bronco New Member
    Justin
    Bay Area, Ca.
    Is there Toyota OEM black door handles?
  29. Aug 5, 2021 at 6:26 PM
    French Avocado
    French Avocado Double Entundra
    Utah / Wyo
    BUMP X2
  30. Aug 11, 2021 at 9:07 PM
    5150bronco
    Justin
    Bay Area, Ca.
    I have found some I believe and will post up part number soon.
