Airing down and snow chains?
Discussion in 'General Tundra Discussion' started by Cruzer, Jan 19, 2021.
  1. Jan 19, 2021 at 7:04 AM
    Cruzer
    Cruzer [OP] Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Planning to do a trail run and I’m expecting snow and ice. I’ve never used chains on the trail before and plan to put them on only if I’m consistently losing traction, which means I’ll already be aired down. Do I keep them aired down or air back up?
  2. Jan 19, 2021 at 7:10 AM
    How much do you air down to?
    This is actually a good question. I have always used tire chains in work situations that wouldn't allow me to air down (heavy hauling). Makes me wonder how the chains would fit.
  3. Jan 19, 2021 at 7:13 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    I have never used chains, but would think the instructions for the chains would specify. And I am going to guess they will recommend normal air pressure, vs air down for chain use due to fitment and liability.
  4. Jan 19, 2021 at 7:14 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    How would they stay tight if you air the tires down? Air down = trying to get better tire flex for contact patch. Chains need to be properly tensioned otherwise they slip/move?
    full disclaimer, I don’t know the answer i am asking as well
  5. Jan 19, 2021 at 7:37 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    I go down to 15lbs. The 13.5 wide tires make a wide footprint. We know the chains are not going to stretch. Will the chains make contact with the wheel and cause damage?
  6. Jan 19, 2021 at 8:07 AM
    frichco228
  7. Jan 19, 2021 at 9:20 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    Hbjeff likes this.
  8. Jan 19, 2021 at 9:24 AM
    That’s not real low, should be fine.
    Looks like the link that @frichco228 provided answered our questions on the topic. Learn something new everyday right?
    Hbjeff and Cruzer[QUOTED][OP] like this.
  9. Jan 19, 2021 at 11:00 AM
    DIYDad
    DIYDad New Member
    2020 Tundra 1794
    low pressure is for floatation, on sand, and DEEP snow.
    For less than a foot? of snow, with firm ground below, narrower tires, full inflation and a tire tread with lots of sniping is best. Likewise and as advised above, you'll want normal inflation when using chains.
    MTRock likes this.
  10. Jan 19, 2021 at 1:51 PM
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    Our tires have belts in them that keep the rubber stretching to a minimum. I would imagine that when aired down some of the sidewall chain will act as part of the tread as the tire rotates into contact with the ground.
  11. Jan 20, 2021 at 11:03 PM
    2mchfun
    I would run 30 psi with chains on any tire and take it slow and steady.
