Airbag sensor discontinued?
Discussion in '1st Gen Tundras (2000-2006)' started by RogerGC, Mar 19, 2024.
  1. Mar 19, 2024 at 7:49 PM
    RogerGC
    RogerGC [OP] New Member
    Roger
    2003 Toyota Tundra SR5 AC
    Softopper
    I'm diagnosing an airbag light on my 2003, getting codes 62 and 31. This is leading me to believe I have a bad front right airbag sensor.
    Looking in to the part needed (89173-49165), I can't find any available. The left side sensor (89174-49065), however, is available.
    Has anyone run in to this issues? Is there a recall or something so it needs a new part? Could the LH sensor be modified to go on to the RH? Is there a suitable aftermarket replacement?
    Thanks in advance
  2. Mar 19, 2024 at 10:23 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Call your local dealer have the last 8
    number of your vin and they will give you the updated part number and email you the diagram(s)
    you can also try the junk yard
    RogerGC[OP] likes this.
  3. Mar 20, 2024 at 5:41 AM
    shifty` In South Dakota Trouble ain't hard to find
    Amayama is another source out of Japan where you can sometimes manage to get parts that are out-of-stock, and also spend significantly less money on OEM authentic parts, you just gotta wait a few more days for it to reach us from Japan. www.amayama.com
    It appears they may have it in stock: https://www.amayama.com/en/part/toyota/8917349165
    For the record, plenty of others here have used their service. I haven't yet heard a complaint other than, "took a week longer than I expected to get the part".
  4. Mar 20, 2024 at 2:28 PM
    RogerGC
    Roger
    Softopper
    Thanks, I'll call the dealer and see if they have a recommendation, otherwise I guess I'll wait on the part from japan
