Airbag and Seatbelt lights...
Discussion in '2.5 Gen Tundras (2014-2021)' started by brian41527, Dec 28, 2016.
  1. Dec 28, 2016 at 5:13 PM
    brian41527
    brian41527 [OP] New Member
    2014 Tundra Limited
    My seatbelt and airbag light in my 2014 Tundra have been on the past month. I called the dealer and they said it would be $90 to hook it to the computer. I was just wondering if it could be a sensor under the seat that could have been kicked or some other easy fix problem.. I will do my best to explain what it is doing.
    Passenger sitting in passenger seat with both driver and passenger seatbelt unbuckled the lights are solid.
    While driving chime will not come on when passenger seatbelt is unbuckled, but will if driver seatbelt is unbuckled.
    While driving with seatbelts buckled seatbelt light flashes and airbag light stays solid.
    Passenger Airbag off light never goes off, even with a passenger.
  2. Dec 28, 2016 at 5:34 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Isn't a 2014 still under warranty?
  3. Dec 28, 2016 at 5:37 PM
    brian41527
    2014 Tundra Limited
    No, It has 47,000 miles on it.. Only comes with a 3 year/36,000 mile warranty...
  4. Dec 28, 2016 at 5:53 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Are you certain those items aren't under warranty? Those are some critical safety items.
  5. Dec 28, 2016 at 5:58 PM
    brian41527
    2014 Tundra Limited
    I spoke with the maintenance scheduler at my local dealership, I told him the problem, he ran my vin number.. He said it would be $90 to put it on the computer.. Should this still be under warranty?
  6. Dec 28, 2016 at 6:05 PM
    gdiep
    gdiep I like cookies
    Syracuse, New York
    2014 Red Tundra CM SR5
    Seatbelts and airbags are covered under the powertrain warranty - the last time I checked. Go look in your owners manual.
    ColoradoTJ likes this.
  7. Dec 28, 2016 at 6:09 PM
    Just because a service advisor says it will be 90.00, doesn't mean anything. They are more wrong then right in my experiences.
    FlashCulprit likes this.
  8. Dec 28, 2016 at 6:11 PM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    I'd go check another dealer.
  9. Dec 28, 2016 at 6:40 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    When I went in for an oil leak I was initially charged for them to have a look. When it was determined that the Cam Tower leak was covered under warranty, I was reimbursed in full.
  10. Mar 15, 2019 at 3:12 PM
    Vince
    Vince New Member
    Vincent
    Terre du lac, Missouri
    2011 White DBL cab 5.7
    K&N intake, Air bags
    Did you get this fixed?
    If so what was it.
