Air rides like crap
Discussion in '3rd Gen Tundras (2022+)' started by Joshuak175, Jun 26, 2022.
  1. Jun 26, 2022 at 5:53 PM
    Joshuak175
    Joshuak175 [OP] New Member
    Hey folks, I have a 2022 limited with the rear air suspension (non-AVS). I think it rides like crap. I have taken it back to the dealer a few times who swear the tires are balanced, also adjusted the rear linkage so it doesn’t hit the bump stops over every hole and still I feel a lot of vibrations in the cabin from what seems like fairly smooth roads. Anyone else have this same feeling about the rear air suspension? Tires are right at 34 psi all around.
  2. Jun 26, 2022 at 6:02 PM
    catalac
    catalac New Member
    Ah interesting, I’ve had a couple Rams with oem air bags and didn’t really like how they rode, was hoping Toyota had it figured as was considering for next 22+. My 22 1794 rides like an 80s caddy, really plush with the rear coils.
    Joshuak175[OP] likes this.
  3. Jun 26, 2022 at 6:12 PM
    Joshuak175
    And this is what bugs me: I have heard so many people comment on how great the ride is when I certainly don’t concur based on how my truck rides. Frustrating.
  4. Jun 26, 2022 at 6:15 PM
    AZTundra
    Paul
    Phoenix, AZ
    Have you test driven another truck at the dealer to compare?
    GODZILLA, Blue Thunder and RookieEP like this.
  5. Jun 26, 2022 at 6:27 PM
    Blue Thunder
    Washington
    This!
    GODZILLA likes this.
  6. Jun 26, 2022 at 7:05 PM
    mannyg84
    mannyg84 New Member
    I love the air feel. But I do need to drive one without it.
  7. Jun 26, 2022 at 7:21 PM
    Gene5253
    Gene5253 New Member
    Gene
    Boise ID
    2020 Tundra CM Limited
  8. Jul 5, 2022 at 3:26 PM
    Wintersun
    Wintersun New Member
    Air suspension has been available for some time with the Ram trucks and when they fail they are very expensive to repair or replace components. Many unhappy Ram owners of trucks with the air suspension.
    Most people use their trucks like a station wagon and so the suspensions have gotten softer and softer over the years. I prefer pickups that have rear leaf springs so I can upgrade the payload capacity if I want or need to do so.
  9. Jul 5, 2022 at 8:07 PM
    Jkwolfe09
    Jkwolfe09 New Member
    Jerren
    10 year 100k will take care of my issues lol
  10. Jul 5, 2022 at 9:56 PM
    Tac-undra
    Tac-undra New Member
    2022 Tundra Limited
    I’ve got a Limited Crewmax with 6.5’ bed and the rear air suspension. I’ve got to say I really enjoy the drive. I test drove a few trucks without it, the difference on most roads isn’t much, but your issues sound worse than normal. Hope they get it figured out for you.
  11. Jul 6, 2022 at 5:21 AM
    pursuit2550
    pursuit2550 New Member
    2020 Tundra SR5 Maggie 1900
    I will never understand why Toyota, being the most reliable truck, would put a non-reliable suspension. I can’t think of any vehicle manuf that has a reliable air suspension. To me, it’s not a long term suspension component that will last as long as a regular suspension and as cheap to fix. I have had 3 Trailblazer SS with the same system as Toyota. Has a lever arm to adjust, blah, blah, blah. It was garbage. Luckily the TBSS guy’s had a solution, remove air bags, switch the shocks and add springs. No more issues, ever. Hope they get it right for you.
  12. Jul 6, 2022 at 5:46 AM
    Jagator
    Jagator New Member
    2022 Blueprint Tundra Platinum 4x4
    You can adjust the rear AVS default height yourself with a 10MM wrench near both of the rear tires under the truck. You have to loosen a nut and then slide the bar down a bit then tighten it back. This will add an inch or two to the rear ride height and make it so you don't feel it hitting the bump stops all of the time over small bumps. I've seen quite a few posts on here about it, with pictures. I'm planning to do the same to mine once I have a front leveling kit installed. It doesn't affect warranty as the height is still within designed range and still allows the AVS to adjust as necessary depending on load.
    Take a look at this thread: https://www.tundras.com/threads/leveling-22-platinum-with-avs-air.99893/
