Air pressurized portable shower inside camper shell ?
Discussion in '2nd Gen Tundras (2007-2013)' started by koday0196, Oct 7, 2021.
  1. Oct 7, 2021 at 1:15 AM
    koday0196
    koday0196 [OP] New Member
    Hello fellow Tundra Owners,
    I recently purchased an air pressurized portable off road shower that holds about 10 gallon of water, and was wondering if anyone here installed it inside the camper shell rather than installing on the roof? I want to install it inside if possible to prevent theft and for convenience (I won’t have to climb onto a tire to refill the tank). If there are any other ways to keep it secured, I am all ears.
    Greatly appreciated for any advice.
  2. Oct 7, 2021 at 3:56 AM
    worktruckwhite
    worktruckwhite bryceCtravels.com
    Charleston, SC
    2010 White Crewmax
    That's a lot of weight. You'd probably want to reinforce the shell first.
    koday0196[OP] and Black Wolf like this.
  3. Oct 7, 2021 at 5:31 AM
    timsp8
    NY
    You’d just need a mount and have to open the rear door or side windows if you have them to use it, unless you want to drill through the camper. Should be the same as mounting it on the outside.
  4. Oct 7, 2021 at 6:28 AM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Mounting it outside has benefits…. the sun warms up the water inside the tank to make showers nicer.
  5. Oct 7, 2021 at 7:14 PM
    koday0196
    @worktruckwhite makes sense. I wonder how that process works. YouTube seems to give little insight.
    @mountainpete I live in Arizona where it gets 110F+ . I actually don’t want the sun to heat up the water. I want it to stay cooler.
  6. Oct 7, 2021 at 8:05 PM
    mountainpete
    Gotcha. Canadian here with frost on the grass in the morning already.
  7. Oct 8, 2021 at 11:53 AM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
