Air not blowing through front vents
Discussion in '2.5 Gen Tundras (2014-2021)' started by Kung, Jul 15, 2020.
  1. Jul 15, 2020 at 10:04 AM
    Kung
    Kung [OP] [Insert Custom Title Here]
    KG, VA
    So, went to run into town today, and discovered that air is evidently not blowing through the dash vents.
    To clarify, it 'seems' as if the only vents air is being directed through are the defrost vents @ the top of the dash; nothing through the front of the dash, and I'm not feeling anything @ the feet, either. I verified the different modes via pushing the button (I've got the version that does Automatic climate control) with no change.
    Any thoughts? The truck has <5K miles on it, so I'm not worried about paying anything (aside from a deductible); but I'm hoping for either a fuse issue or PICNIC issue (problem in chair, not in car/truck).
  2. Jul 15, 2020 at 10:06 AM
    Kung
    KG, VA
    To update/add:
    I've verified (so far as I'm able to) that nothing else appears to be having any issues. Sound system, wipers, vehicle interior/exterior lights, etc. all appear to be working just fine.
  3. Jul 15, 2020 at 11:46 AM
    Kung
    KG, VA
    I guess it's a good thing that I'm getting no replies; better than getting a crap ton of them all saying "OMG yes that's happened to 232448 other people." LOL
  4. Jul 15, 2020 at 3:35 PM
    TRDThirstyPRO
    TRDThirstyPRO New Member
    Tom
    New York
    2020 TRD pro
  5. Jul 15, 2020 at 4:44 PM
    Kung
    KG, VA
    Yeah, but
    a) it's under bumper to bumper warranty and
    b) it's not super common for this to happen, from what I understand.
    Oh well - we buy them because they're MORE reliable than other vehicles, not because they're problem-free. :)
    On a side note - I *thought* (outside of warranty) this could be done without removing the dash?
  6. Jul 15, 2020 at 6:50 PM
    Kung
    KG, VA
    Update:
    Brought the wife outside to have her help me check symptoms (e.g., if it was both sides, if it was locked to just the defrost vents, etc.)
    Turned the truck on, and all works well. :confused:
    Ah well, I'll just keep an eye on it and let it slide, I suppose.
  7. Jul 15, 2020 at 6:55 PM
    TokerJoker
    TokerJoker ΜΟΛΩΝ ΛΑΒΕ
    Travis
    Nowhere, Specific
    2014 Black SR5 4.6 Dbl Cab
    None.....yet
    Good luck OP and maybe the truck was just having a bad day!:thumbsup:
  8. Jul 16, 2020 at 6:21 AM
    Kung
    KG, VA
    Could be; am wondering if it's not a gremlin somewhere in the HVAC controls.
    I'll just make sure it's set to dash everytime I turn the truck off, and not worry about it. I mean, as it is, it's not exactly a huge monster issue - searching 'blend door actuator' returns ONE page of results here, and 99% of them tie to the same 2 threads, with maybe 3 people reporting this issue.
  9. Jul 16, 2020 at 11:54 AM
    DaleDanTony
    DaleDanTony New Member
    14 SR5 CM
    there is a vent connection under the steering wheel that feeds the front vents i believe. i knocked mine loose when i installed my brake controller... maybe have a look and make sure it's tight? it's a rectangular plastic tube.
  10. Dec 17, 2020 at 6:06 AM
    Kung
    KG, VA
    Update:
    It's happened a handful of times since then. The last time it happened, I called the dealership; and while it didn't reproduce upon startup (of course lol), they DID see the issue, so they've got it documented. The service technician is pretty sure that what's going on is the HVAC system doing a self-check upon startup when it notices something's slightly hosed....and therefore the 'blank's screen on the HVAC display. Once it does kick in, it stays locked to the defroster vents because that's the default position.
    I don't like the fact that it happens, but I mean, it's literally happened less than about 8 times since I've had the truck. If it ever happens more reliably, I'll bring it to the dealer, and they've already said when it does, they'll research/replace whatever it is since it's documented while in warranty.
    Black Wolf likes this.
