Air Lift bags made my 19 Tundra 4x4 ride hard
Discussion in 'Towing & Hauling' started by mike19sr5, Nov 24, 2021.
  1. Nov 24, 2021 at 12:56 PM
    mike19sr5
    mike19sr5 [OP] New Member
    I should have sent them back. I took them off after one use and they just sit in the garage collecting dust. The internal joust takes up most of the spring travel when unloaded. Are Firestone bags better when unloaded? No one offers air shocks for my 19 Tundra.
  2. Nov 24, 2021 at 2:07 PM
    Northbound Train
    Northbound Train Masshole
    Glenn
    Western MA
    Black 2016 SR5 Double Cab 4x4 5.7
    I have the Firestones and they don't noticeably stiffen the ride when at the minimum 5 pounds of air. I have heard AirLift has an internal bump stop which causes harder ride but have never ridden in a truck with them.
    mike19sr5[OP] likes this.
  3. Nov 24, 2021 at 2:26 PM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    Different application but I had the Firestone on a 2012 Tacoma. Loaded they were great at 5 PSI unloaded on the streets of NYC they were hell. I used Timbrens, Super Springs, heavy duty leaf spring and I came to the conclusion of buying a larger truck next time around hence the Tundra. ALL these products stiffened the ride to the point that I absolutely hated them.
  4. Nov 24, 2021 at 2:39 PM
    mike19sr5
    Hmm..the Firestones were bad too huh. I'd hope not having the internal snubber they'd been better.
    Oey12 likes this.
  5. Nov 24, 2021 at 2:41 PM
    mike19sr5
    That internal snubber only allows about an inch and a half travel. When unloaded I could feel them constantly bumping.
  6. Nov 24, 2021 at 2:48 PM
    Dillusion
    Dillusion New Member
    Kyle
    2019 SR5
    I have AirLift and keep it little over the 5 PSI unloaded and no issues.
    I actually think it feels a little bit better.
  7. Nov 24, 2021 at 2:57 PM
    Squeaky
    Squeaky New Member
    Wisconsin
    ‘19 White TRD Pro
    Ive been running firestones for a year now. With the 5psi minimum, the ride has definitely stiffened up. It’s not terrible, but is noticeable. I recently added daystar cradles and my plan is to add coachbuilder +2 shackles to hopefully lift them off the cradles enough that it smooths the ride back out closer to stock. If it doesn’t, I’ll still keep the bags as the towing benefits outweigh the slightly stiffer ride.
  8. Nov 24, 2021 at 2:57 PM
    Oey12
    Oey12 New Member
    Joey
    New York
    I honestly don’t know enough about the internal snubber…and like I said different vehicle so maybe it’s a different design. They were awesome loaded up but my wife really never wanted to ride in the truck after a while. I purposely went with the Tundra because I knew there would be minimal sag with the largest loads I would ever haul 4k ATV trailer or and ATV in the bed. But I realize that is not everyone’s case. I found the Timbrens to be the best semi solution. The problem with them is that if there is not enough weight in the bed it causes this weird rebound/bouncing sensation.
  9. Nov 29, 2021 at 9:08 AM
    BigSwole
    BigSwole New Member
    Tony
    2014 Tundra limited
    Wow, just reading all of your responses I am still as puzzled as ever as I have what I call light load sag and I dont like it at all. I have researched all of the above solutions. I want a solution that won't affect my truck ride or handling.
    Oey12 likes this.
  10. Nov 29, 2021 at 9:24 AM
    Squeaky
    Squeaky New Member
    Wisconsin
    ‘19 White TRD Pro
    I didn’t put this in my last post, but like Oey12 pointed out, the ride is good with a little weight in the bed.
    Not a cheap option, but in theory, the route I’m going should bring me back to a stock ride or possibly even better than stock (coachbuilder shackle poly bushings). But you would have to be ok with 1.25” lift from the shackle. With this setup, my bags won’t touch the frame unless loaded.
    I say “in theory” because I’m still waiting on my shackles, so I haven’t tested this yet. The only thing I’d need to verify is whether the shackle I ordered will lift the bags off the cradles or not.
    Oey12 likes this.
  11. Nov 29, 2021 at 10:23 AM
    Ericbike6
    Ericbike6 So we're doing this shit today?
    Eric
    Austin, TX
    2019 Tundra TRD 4X4 sport
    Air bags, ARK liners, misc bullshit added also
    I have the firestone air bags and daystar cradles also. Usually run 2-3 psi when empty, and adjust as needed for when loaded. Was not really able to tell much of a difference in ride quality from no air bags.
  12. Nov 29, 2021 at 10:42 AM
    Oey12
    Oey12 New Member
    Joey
    New York
    The cradles make a big difference because without them they greatly affect the down travel. I used to cringe when my truck was on a lift because they looked like they were going to rip off.
    Squeaky likes this.
  13. Nov 29, 2021 at 12:18 PM
    Ericsopa
    Ericsopa Old man and the sea
    I don't notice any more stiffness at all with Firestone bags at 5psi. I feel that the ride is improved a little. An additional slight damping effect from the bags.
  14. Nov 29, 2021 at 1:03 PM
    Ericbike6
    Eric
    Austin, TX
    I could see that, with the cradles, the bags are only mounted on the top, and are free floating, so it doesn't bother me to run super low air pressure, sometimes I have seen the gauge at 0psi. The cradles did give ma a little lift it seems. From this weekend, that's a half cord of oak firewood...
    Oey12[QUOTED] likes this.
  15. Nov 29, 2021 at 1:09 PM
    Oey12
    Oey12 New Member
    Joey
    New York
    I had about a 1/4 lift after installing them at 5 PSI…
  16. Nov 30, 2021 at 4:26 AM
    parkerbows
    parkerbows New Member
    Jack
    2017 crew max sr5 trd off road
    Firestone air ride air bags
    firestones at 5 pounds i dont notice anything
