Air Intake Tube Alternative
Discussion in 'Performance and Tuning' started by JeffMac, Feb 26, 2021.
  1. Feb 26, 2021 at 3:33 PM
    JeffMac
    JeffMac [OP] 2 Words, 1 Finger
    Jeff
    South Florida
    2015 Black Tundra OVTUNE
    Suspension: Bilstein 6150 Front Max Setting CB Shim 2x Driver 1x Passenger Bilstein 5160 Rear CB +3 Shackles Firestone Airbags w/ Daystar Craddles Engine: OVTUNE - 87 w/ Torque Modifier SABM w/ K&N Filter TB Coolant Bypass Fumoto Drain Plug Wheels/Tires: ProComp Bandidos 0mm Offset Nitto Exo Grappler AWT 285/70/18 Exterior: TRD Pro Grille Spyder Headlights/Taillights Ecoological Bumpershellz LED everything Tinted windows Bakflip MX4 Tonneau Cover K-Source Tow Mirrors Interior: Pioneer AVH-W4500NEX Radio 2x 10” Pioneer Subwoofers 1200W Pioneer Mono Amp 2000W Pioneer 4 Channel Amp
    Does anybody have a cheaper alternative to replacing the Air Box to Throttle Body pipe other the purchasing K&N 57-9036 $199.99?
    Has anybody successfully removed their resonator? I’ve tried searching for it but cannot find much info.
    Rica25 likes this.
  2. Feb 26, 2021 at 5:24 PM
    JeffMac
    Jeff
    South Florida
    Okay so I’m thinking this should work. This total is $150. So $50 cheaper then the K&N. I already have a K&N filter if I didn’t I’d go the K&N route.
    TRD Intake Air Tube. Air Intake System
    Part Number: PTR0300140AC
    TRD Coupling Kit. Air Intake System
    Part Number: PTR0300140AB
    Part Number: PTR0300140AD
    Rica25 likes this.
  3. Feb 26, 2021 at 5:28 PM
    blackoutt
    blackoutt YEAH BUDDY!
    Indy
    07 DC Long Bed - Old Man Tan
    OEM+
    On 4th gen 4runners we just used silicone coupler, alum pipe, and a vacuum nipple kit to drill and add the lines. $50
    For 5.7s I've seen the AFE kits pop up used for $100 occasionally.
  4. Feb 26, 2021 at 5:59 PM
    Hobbesdsm
    Hobbesdsm New Member
    Eddie
    2016 crewmax limited
    TRD exhaust and rear sway bar, 2018 led headlights
    49E4E1E4-E0CE-4179-8827-F33B743CCBC5.jpg F8F526AD-A17C-41B6-8A20-2928800EE354.jpg This is what I’ve done.
    3 3/4” aluminum pipe 45* bend straight coupler and reducer coupler at the throttle. Brass fitting for crank case and vacuum lines, finished was black paint. $80~
  5. Feb 26, 2021 at 6:13 PM
    Vizsla
    Vizsla 2 = 2.5
    Don’t buy that K&N crap. I have it, not even close to fitting correctly. Had to modify, and still not great.8C28E12C-AC4B-494C-B6C5-F53817A09D9D.jpg
    Thought about that but doesn’t work without the TRD lid from what I know, so buying whole kit is cheaper for me.
    If not too much trouble, some more info on parts used would be helpful.
    reywcms, joonbug, 14burrito and 2 others like this.
  6. Feb 26, 2021 at 8:13 PM
    JeffMac
    Jeff
    South Florida
    Haven’t seen any AFE kits lately. Most people only want local pickup also.
    I like this idea but I just worry about the aluminum tube being such a great heat conductor.
    Isn’t the stock and TRD exactly the same besides Airflow accelerator, Filter, and tube? I’m going to see if Toyota does some Military Discount on parts tomorrow :fingerscrossed:
    worst case I return all the parts. I’ll probably bring my drill and check in the parking lot.
  7. Feb 27, 2021 at 10:07 AM
    JeffMac
    Jeff
    South Florida
    Could you give me some more info on what you did. Size of pipe and length. Reducer size. Figured I could just heat wrap the pipe instead. Been looking at Autozone and other places and it’s slim pickings. Thanks.
  8. Feb 27, 2021 at 10:23 AM
    canadianguy
    canadianguy New Member
    Kevin
    Lloydminster Alberta
    2017 SR5 trd off-road
    All the usual stuff!
    I built my own just for it to sit in my tool box. I bought a K&n cai to replace it. image.jpg
    JeffMac[OP] and Vizsla like this.
  9. Feb 27, 2021 at 11:33 AM
    Hobbesdsm
    Eddie
    It’s a 3 3/4” id or 4” od 45* aluminum with 7” leg. 4” id by 3” length 4” to 3.25” reducer coupler from Amazon. Cut the pipe to fit. Drill and tap the hole for the brass fittings. You can find the fitting at Home Depot or your local auto supply store.
    4E137BBA-09CA-4BA2-B0EC-3C0C20D37FB1.jpg 3754A414-45A1-4D54-8260-E2DFD73E243A.jpg 30FA1F5B-1EFF-4BD4-A9AB-226E382DA448.jpg
    7ED0C29E-6081-4D71-9957-4453702C3EE5.jpg 6437B135-CA8C-49CD-9CA0-249F6DC2E5FC.jpg
    farnsrocket, chugs, Chrslefty and 7 others like this.
  10. Feb 27, 2021 at 11:48 AM
    dorton
    dorton #RockCreekOverland
    North Carolina
    2020 Black Tundra SR5
    CBI Off Road Front Bumper, Rock Sliders, Skids, and Bed Rack. Prinsu Designs Roof Rack, CVT Hybrid Rainier Tent, Old Man Emu lift, Fuel Vectors, Yokhama 305/70r18s
    Subscribed.
    this is relevant to my interest
  11. Mar 4, 2021 at 4:35 PM
    JeffMac
    Jeff
    South Florida
    Okay so I went with the TRD option like I said above. It worked perfectly. If I purchased the the aluminum pipe and brass fitting and all that jazz it was totaling $120ish.
    This is how I turned my stock airbox into a TRD Cold Air Intake for 50% off.
    6E4EA1E9-8E0F-4375-AF6A-30B87E1E4219.jpg 09D4C342-8683-4A6B-91EF-A3211C0F1131.jpg 24B6937B-A377-4710-ABBF-443AD6929473.jpg 58B31263-BE77-4CA1-8842-1075BC11A21E.jpg
    Price: $36.24
    Price: $65.48
    Price: $48.87
    TRD Air Flow Accelerator. Air Intake System
    Part Number: PTR03-34079
    Price: $15.33
    Total: $165.92
    chugs, bulldog93, Black Wolf and 7 others like this.
  12. Mar 4, 2021 at 8:00 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    How is the intake tube different than stock, other than color (from the air box to the intake)?
    Rica25 likes this.
  13. Mar 4, 2021 at 9:11 PM
    JeffMac
    Jeff
    South Florida
    It doesn’t have that resonator in there anymore. Probably slightly better performance. And it says TRD so easy 20+ HP. :benchpress:
  14. Mar 5, 2021 at 5:38 AM
    CaptainGrumpus
    CaptainGrumpus The Mailman
    Maine
    2018 Inferno Tundra TRD
    Whats the purpose of the resonator? Reduce sound or does it do something to the airflow?
  15. Mar 5, 2021 at 7:26 AM
    JeffMac
    Jeff
    South Florida
    It reduces sound by inducing a lower resonance frequency and will slow flow into the intake tube.
  16. Mar 5, 2021 at 7:44 AM
    CaptainGrumpus
    Maine
    Thanks, I just ordered one.
    JeffMac[QUOTED][OP] likes this.
  17. Mar 5, 2021 at 9:48 AM
    dorton
    North Carolina
    Thanks, I'm going to try some of these goodies.
  18. Mar 5, 2021 at 9:12 PM
    WSDMetal
    WSDMetal Motorsports Fabrication & Design
    Huntington Beach
    Very resourceful! Nice
    JeffMac[OP] likes this.
  19. Mar 12, 2021 at 7:27 AM
    dorton
    North Carolina
    As an FYI. The TRD intake parts did not work on my 20' Tundra. It appears they only work on prior to 19' due to the
    airbox change. The TRD tube is too large to fit on the outlet of the factory airbox.
  20. Mar 12, 2021 at 7:35 AM
    RainMan_PNW
    Casey
    Clark County, WA
    No shit? Damn. Wonder if there’s just a different part number.
  21. Mar 12, 2021 at 9:14 AM
    JeffMac
    Jeff
    South Florida
    You’re not able to just clamp the coupler down? My coupler was slightly bigger but nothing insane.
  22. Mar 12, 2021 at 10:28 AM
    dorton
    North Carolina
    The throttle body fit well, but at the air box it was pretty loose. I was working in the dark, so I'll take another peak at it
    tomorrow in the daylight and post measurements if there was indeed a difference. If not I'll post up with a confirmation
    that i'm a dummy :D
    RainMan_PNW and JeffMac[OP] like this.
  23. Mar 15, 2021 at 4:57 AM
    dorton
    North Carolina
    [​IMG][/url]
    Confirmed: The TRD hose (PTR0300140AB) will not fit my 20' airbox
    Rica25 likes this.
  24. Mar 19, 2021 at 6:14 PM
    JeffMac
    Jeff
    South Florida
    Actually that’s what mine looked like and I just clamped it down. Didn’t bunch up and nice tight seal for me.
    bulldog93, KatoK and Rica25 like this.
  25. Mar 22, 2021 at 12:09 PM
    RainMan_PNW
    Casey
    Clark County, WA
    I ordered these parts, and attempted to install this weekend. The combined LENGTH of the parts are about 3/4" longer than the stock air intake tube on my 2021, so there is no way to get the air box lid back in place.
    I also missed the fact I would need to extend the larger vacuum line to make it connect to the inlet tube, so I didn't have parts for that. But the bigger issue was everything being too long.
    SO... Looks like I'll be offering up the parts in the market place and just leave things alone for now.
  26. Mar 24, 2021 at 6:51 PM
    mb66l79
    mb66l79 New Member
    Maybe a dumb question, but is the resonator in the tube in between the air box and throttle body? I looked in my 2021 and there aren't any internals, straight through and open.
  27. Mar 24, 2021 at 7:03 PM
    Sitting Sideways
    Sitting Sideways Probably stuck somewhere
    Beaverton, Oregon
    2021 White CM Tundra TRD Off Road
    Icon IR Coilovers, Icon Delta Joint tubular upper control arms, Icon PB CDC rear shocks, Icon Expansion Pack, Icon Hydraulic Bump Stops, Durobumps front bump stops, TRD dual exhaust black tips, TRD pro skid plate, TRD cold air intake system, TRD pro shift knob, TRD Pro Wheels, Falken Wildpeak AT3W tires, TRD radiator cap, ESP under seat storage, spray in bed liner, bed rail system, SDHQ abs guards, black tundra letter inserts, center console wireless charger, center console organizer/tray, charcoal filter removal, whistle screen removed, RCI Transmission/Transfer case skid plate, and ICON neoprene shock wraps
    Dealer installed the TRD intake on my 21 without issue. I have taken the tube off the a couple times and it fits snug. Weird.
  28. Mar 24, 2021 at 7:23 PM
    JeffMac
    Jeff
    South Florida
    Where did you order from? You’re not able to just return the parts?
    On my 2015 I had this hideous contraption.
  29. Mar 24, 2021 at 7:27 PM
    mb66l79
    mb66l79 New Member
    Yes I have that too, but there's nothing inside the tube going to the throttle body. What am I missing or not understanding?
  30. Mar 24, 2021 at 7:27 PM
    Vizsla
    Vizsla 2 = 2.5
    Purchased complete TRD intake, delivery scheduled for tomorrow. Going to measure everything and report back.
