Air Filter
Discussion in '3rd Gen Tundras (2022+)' started by Maverick345, Jun 29, 2024.
  1. Jun 29, 2024 at 4:31 PM
    Maverick345
    Maverick345 [OP] New Member
    2024 SR5
    ARB1977 likes this.
  2. Jun 29, 2024 at 4:42 PM
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    24 Tundra CM SR5 4x4 CSM build date 05/24
    I ripped the charcoal filters out. They just pull out. Installed AFE ProDrys.
  3. Jun 29, 2024 at 4:58 PM
    Maverick345
    2024 SR5
    I really only bought them because I already have the K&N oil and for some reason I despise buying air filters. It's so much easier to clean them when I'm doing maintenance IMO.
  4. Jun 29, 2024 at 5:23 PM
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    Depending on environment. I let them go every 30K.
  5. Jun 29, 2024 at 10:52 PM
    dagooaz
    dagooaz New Member
    Dave
    2024 Tundra TRD Off-Road Limited Solar Octane
    I would verify those are genuine TRD filters. I bought mine directly from a Toyota dealer and filter media was a much different color. Red urethane surround, but the filter media was a yellowish color. Just want to make sure you're not getting a cheap knockoff or another cheap rebranded part.
    Tundrastruck91 likes this.
  6. Jun 30, 2024 at 8:31 AM
    Tom976
    Tom976 New Member
    Tom
    Interesting point about the color.... I have the ones like the OP has. Very similar to K&N filters.
    After about 10k miles, they had some good amount of dirt built up on them.
    I swap in the originals while I leave these out to dry for a day or two.
  7. Jun 30, 2024 at 10:23 AM
    brhodea
    brhodea New Member
    Michigan
    '24 CM Limited
    thats a great idea
  8. Jun 30, 2024 at 10:55 AM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    I live 7 miles from the nearest pavement, so my trucks see a lot of dusty miles. I've never had much luck with the K&N type filters.
  9. Jun 30, 2024 at 11:19 AM
    PNW Tundra Mike
    Southern Cal
    MX4 Tonneau, Talon's Trans/Cat Shield
    My truck came with the TRD filters. Urethane surround and filter media looks the same as all the K&Ns I’ve had. Once I washed them and and re-oiled with K&N oil (which is red) they now look identical to K&N.
  10. Jun 30, 2024 at 11:35 AM
    Dpoll995
    Dpoll995 New Member
    Houston TX
    2024 Tundra Limited
    How do you clean the ProDrys?
  11. Jun 30, 2024 at 12:22 PM
    Fatone
    Fatone New Member
    2022 Tundra TRD Sport Premium
    Be very careful on non OEM filters with anything with a turbo. If the filter is not identical to the OEM construction the turbo can suck it in and you get a $2k bill for a new turbo. Seen it happen several times with diesel engines when owners get tired of the high price of their filters and start going 3rd party to save a few buck.
  12. Jun 30, 2024 at 12:26 PM
    wtofd
    wtofd New Member
    ID
    2024 Tundra TRD OR
    Moving blanket over rear seat
    What's a good source for OEM filters?
  13. Jun 30, 2024 at 12:50 PM
    Fatone
    Fatone New Member
    Any Toyo dealer including some who discount online. Others here are better sources than me.
    My only experience with diesel filters was buying a $70 Fram filter instead of the $95 OEM filter. Few hundred miles at dealer in limp mode. The Fram had a piece of cardboard in the structure instead of a strip of metal like OEM. Dealer said I was a very close to new turbo time. Lessen learned for me
    wtofd[QUOTED] likes this.
  14. Jun 30, 2024 at 10:29 PM
    PNW Tundra Mike
    Southern Cal
    Your dealer! - The trick is NEVER walk in and buy parts over the counter. You’ll pay a premium retail price because they have to assist you and look up your parts. * Order your parts on-line from your dealers parts dept. for pick-up. They are then almost half price. Oil filter at the counter, $12.50. Pre-order $6.50.
  15. Jul 1, 2024 at 6:50 AM
    wtofd
    wtofd New Member
    ID
    2024 Tundra TRD OR
    Awesome. Thanks. I like the web option: https://www.willstoyota.com/parts/index.htm
