Air Conditioning Not So Good
Discussion in '3rd Gen Tundras (2022+)' started by tcap23, May 26, 2023.
  1. Jun 26, 2024 at 2:56 PM
    #121
    Tomnola
    Tomnola New Member
    2024 Tundra SR5
    I did Carista change. I guess it helped. What I have figured out is that it works best using Auto on a/c. The bad thing about it is that when you first get in truck, it's not blowing any air. You have to wait on the super duper technology...lol..(you know.The stuff that got us in space). Thats the part that sucks, But it does get ICE cold once it starts blowing and you are rolling down the road. I'm not paying Carista to change it back just to see..lol. BTW on long drives with it hot outside and my a/c on auto, I have to turn it to 75 because it's too cold.. Gook luck with yours.
  2. Jun 26, 2024 at 2:58 PM
    #122
    Breathing Borla
    Northern Illinois
    every toyota with auto climate I have ever been in works this way until you do to the really old ones
  3. Jun 26, 2024 at 3:04 PM
    #123
    Tomnola
    Tomnola New Member
    2024 Tundra SR5
    I had a 2006 Titan. No auto a/c control.. I was use of getting in with air circulating as soon as I started my truck. When it is 100 degrees outside, you kind of get use of have some air hitting you fast...
    Take care
  4. Jun 26, 2024 at 3:13 PM
    #124
    Breathing Borla
    Northern Illinois
    I get that, I have had vehicles that worked that way as well. toyota for some reason waits for that 5-10 seconds for it to turn on, I think all my tundras have been like that with perhaps my gen 1s which were just the dail knob.
    Tomnola[QUOTED] likes this.
  5. Jun 27, 2024 at 8:41 PM
    #125
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    lol, thought I was the only crazy keeping truck at 75
  6. Jun 27, 2024 at 9:05 PM
    #126
    ShutterFlare
    ShutterFlare New Member
    2024 Tundra 1794
    This describes every truck I have driven. Trucks like the open road, they are not designed to sit idle. I do mostly highway driving in my 24 and the AC will run you out of the cabin it's so cold, even on 90+ degree days. Also, I found these awesome little window covers on Amazon, they do a great keeping the cabin from getting too hot when your truck is sitting outside
    https://www.amazon.com/dp/B0CZ9G6LCV?ref=ppx_yo2ov_dt_b_product_details
    Tomnola likes this.
  7. Jun 29, 2024 at 11:32 AM
    #127
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    2022 CMLB TRD OR Prem. 4X4 and 2002 RCLBV65Spd
    Seems like I'm the only cold natured, over weight Tundra driver. LoL I keep mine on Lo and fan speed on 2. The output of these vents and lacking.
  8. Jun 29, 2024 at 11:40 AM
    #128
    Tomnola
    Tomnola New Member
    2024 Tundra SR5
    Vents blow harder on auto. Don't know why..
    BlackNBlu likes this.
  9. Jun 29, 2024 at 11:45 AM
    #129
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    When in auto, does it override the fan setting you had it on? If so, I'd say it's trying to get to the target temp that's set in auto. Kinda like the radar cruise accelerating rapidly after it slows down a lot from a car in front of you turn off. I know, no matter your fan setting, Lo kicks the speed up a notch vs 60°.
  10. Jun 29, 2024 at 11:19 PM
    #130
    dagooaz
    dagooaz New Member
    Dave
    2024 Tundra TRD Off-Road Limited Solar Octane
    I just got my Carista yesterday and made the change to -2 degrees and what a difference. I'm in hell, I mean Phoenix, and the AC in my Hybrid was ok at best, but I never felt cold in the truck like my wife's 4Runner. Now, I made about a 15 mile round trip, with temps around 110 degrees, and my daughter and I were freezing after about 10 minutes. Still not as good as the 4Runner, but much better, I'm happy with it. I also have ceramic tint all the way around, including my windshield, which also makes a big difference due to its heat rejection properties.
    Midnight Rider, Paul499 and Tomnola like this.
  11. Jun 30, 2024 at 10:25 AM
    #131
    901tundra
    901tundra New Member
    Memphis, TN
    2023 Magnetic Gray Limited TRD Off-road
    - Color-matched grille and rear bumper insets - 1-inch Cornfed front spaces - TRD grille with light bar and amber marker lights - Debadged
    Ceramic tint is next on my list.
  12. Jun 30, 2024 at 10:38 AM
    #132
    PNW Tundra Mike
    Southern Cal
    MX4 Tonneau, Talon's Trans/Cat Shield
    If you want max AC run the system manually. Not in Auto. Make sure you’re not running the truck in ECO mode as it shortens compressor cycles.
    - Set your own fan speed
    - Set AC compressor to ON
    - Set temp initially to LO then adjust
    - Set input to Fresh (first 5 min) then recirculate
    - Set output to whatever you prefer other than anything with defrost
    *You will notice a world of difference.
    Our past two Toyotas (Venza & Tacoma) had this same “Auto” system which is fine on average days but when it’s hot, go manual.
    Malinois38 likes this.
  13. Jun 30, 2024 at 10:42 AM
    #133
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    This is odd. I've experimented with the manual vs. auto settings in mine, and I don't notice any difference in cooling performance. Auto seems to cool just as quickly as manual, so I set mine to 70 auto and forget about it.
    jhtram, c&wsinbad and Midnight Rider like this.
  14. Jun 30, 2024 at 10:57 AM
    #134
    PNW Tundra Mike
    Southern Cal
    I find the same on an average day. Auto is so easy. But if I want more air flow through the dash ducts or more cooling without the fan blasting on high I’ve gotta go manual.
  15. Jun 30, 2024 at 11:08 AM
    #135
    Matt2015Tundra
    2023 1794 CrewMax
    Have you done the -2C calibration adjustment using Carista or Tech Stream? That made the largest cooling difference in mine.
  16. Jun 30, 2024 at 11:14 AM
    #136
    PNW Tundra Mike
    Southern Cal
    I did not. Have never not had enough cooling to freeze me out. It did fine at 100° ambient last year. I’m keeping that hack in my back pocket (sort of speak). I have a white truck too without the green house roof which makes a huge difference. Out of all the colors it’s the only one you can place your bare hand on on a hot sunny day.
  17. Jun 30, 2024 at 11:54 AM
    #137
    Hella Krusty
    Hella Krusty New Member
    I put it on auto, once the vents start blowing hard I just kick it off auto and it continues to have high volume out of the vent.
  18. Jun 30, 2024 at 1:19 PM
    #138
    Paul499
    Paul499 Large Member
    Paul
    Sarasota, FL
    2024 Platinum Hybrid
    Weld 20x9, Toyo 285/60, RC N3 level, ceramic tint
    Carista. Carista. Carista. This is the answer. Changes everything.
    Midnight Rider likes this.
  19. Jul 1, 2024 at 4:01 PM
    #139
    Chin_lee
    Chin_lee New Member
    Chin
    23 Limited
    None..... yet.......
    Can I buy carista obd or do I need carista eco-friendly dongle? I have a 2023 tundra gas.
    Or can I use any previous old obd dongle, get the carista app trial, and change the temp setting?
  20. Jul 1, 2024 at 4:03 PM
    #140
    PGW85706
    PGW85706 Member
    Patrick
    Central VA
    '24 1794 HV 6.5' MGM w/ AVS-LL, HUD, RB
    The Carista app website has info which dongles it works with.
  21. Jul 1, 2024 at 4:29 PM
    #141
    lapoolboy
    lapoolboy New Member
    My loaner Carista is on the way to complete this very thing. But, what does it do exactly? "Trick" the truck into thinking the air inside the truck is warmer than it really is?
    Tomnola likes this.
  22. Jul 1, 2024 at 4:41 PM
    #142
    303Gen3
    303Gen3 Old enough to know better. Young enough to try
    Golden Colorado
    '23 MGM SR5 CrewMax 4x4
    Nitrogen filled tires!
    90's here and no issues. AUTO set to 70 degrees.
  23. Jul 1, 2024 at 7:41 PM
    #143
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    24 Limited CM 5.5 Blueprint TRD OR
    5100's, 285/75/18, Air Lift bags, bits and bobs
    Update from previous on mine:
    I've determined I have the same response with mine when I use Auto. That is, it's much better.
    I can be at 65 in manual, with the fan only a notch or two down from Max, and it's barely just cold enough.
    Switch it to Auto, and I have to bump it up to 70+ to not get frozen out.
    So, it definitely works, but like many things on these trucks, you have to figure out (and sometimes work around) the technology.
    Oh, for the simple days of a couple rotary knobs for temp and fan speed, and a manual slider telling the air where to go.
    And R12. :D
  24. Jul 1, 2024 at 9:47 PM
    #144
    dagooaz
    dagooaz New Member
    Dave
    Things sure seem like they've gotten unnecessarily complicated for no reason. If it ain't broke, don't fix it. Why we need sensors to adjust my AC output, wipers that sense when to wipe, and a myriad of other things, I don't know. I'm only 50 years old, but I'm already feeling my Grand Torino stage of life coming on, minus the racism. Believe me, I love the HP and torque technology brings, but the rest of this stuff I can do without.
    BlackNBlu and Tomnola like this.
  25. Jul 2, 2024 at 9:47 AM
    #145
    Tomnola
    Tomnola New Member
    2024 Tundra SR5
    Maybe the tech is moving so fast, it makes us get old faster..lol
  26. Jul 2, 2024 at 11:44 AM
    #146
    cmiles97
    cmiles97 New Member
    2018 Toytota Tundra SR5 4x4 XP
    XP package
    2018 Tundra, manual AC, cold immediately
    2020 Chevy Silverado, manual AC, delays AC for some reason. Being a GM product 1st thought on a 90+F day with the inside being over 110F is that the AC failed. A few minutes later it starts working and gets cold.
    This in hot humid Florida.
    PS 2022 Ford Edge ST traded in on Tundra, had auto AC and was cold immediately, usually set at 70F, worked great.
  27. Jul 3, 2024 at 2:34 PM
    #147
    BlackNBlu
    Rich
    MN
    Tomnola likes this.
  28. Jul 3, 2024 at 3:57 PM
    #148
    dagooaz
    dagooaz New Member
    Dave
    Hahaha, that’s me.
  29. Jul 3, 2024 at 9:06 PM
    #149
    PNW Tundra Mike
    Southern Cal
    Must be ELM327 compliant
  30. Jul 4, 2024 at 7:39 AM
    #150
    Yassi24
    Yassi24 New Member
    2024 Tundra Limited 4x4
    Would you guys recommend the Carista OBD or the Carista EVO?
