Air compressor/jump start combo
Discussion in 'Recovery & Gear' started by alwzdfiant, Sep 24, 2019.
  1. Sep 24, 2019 at 7:58 PM
    alwzdfiant
    alwzdfiant [OP] New Member
    2013 Tundra Crew Max
    Anyone running an air compressor/jump start combo? Looking at one of these4BFC19EF-D45D-43F4-AD6E-23AB25FD6606.jpgany suggestions or feedback?
  2. Oct 2, 2019 at 1:34 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Tagged. Curious about this as well. I wonder how slow the compressor would be.
    alwzdfiant[OP] likes this.
  3. Oct 2, 2019 at 1:39 PM
    sundance
    sundance New Member
    No, but I did build a custom rig where I joined two Amazon compressors together with a 1/2 gallon tank for tires and my air horn. It will make you wet your pants and I only have one horn.
    You really need something fast with larger pistons to move air to get much of anything out of a DC air compressor.
    The larger Harbor Freight ones move air pretty good. The rig I built will take my 33 x 11.5 from 15 psi to 40 psi in about 4.5 to 5 minutes. I put a automotive fan on it to cool down the compressors.
    alwzdfiant[OP] and Mwray8909 like this.
  4. Oct 2, 2019 at 1:58 PM
    Mwray8909
    Mwray8909 New Member
    Chino Valley
    18 TRD offroad cement CM
    Show us.....:worthless:
  5. Oct 2, 2019 at 3:50 PM
    sundance
    sundance New Member
    1002191824a.jpg 1002191825a.jpg 1002191824_HDR.jpg 1002191824b.jpg 1002191823b.jpg Here are a few. I use the rig for my horn, tires and my air bags. The air dial has a precision bleeder on it that works well for setting the air bags. I probably have about $250 or so in it. I refused to pay what Viair and others wanted for their rigs. So I joined two cheap Amazon compressors together. Each with back flow valves. I also put a distribution block if/when I decide to put in air lockers. You can't see it in these pics but I have hard cut offs on top that I can get to easy if I have an issue and I wired in a cheap wireless remote. A toggles the air compressor and B toggles the fan on an off.
  6. Oct 2, 2019 at 4:13 PM
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    You guys make me feel stupid sometimes.
    I wish I knew 10% of what you forgot
    sundance likes this.
  7. Oct 2, 2019 at 4:15 PM
    alwzdfiant
    Yea that’s a sweet set up
  8. Oct 2, 2019 at 6:00 PM
    Mwray8909
    Chino Valley
    Welp, looks like I have a new project.... I'm going to have to run down and check out your setup.
    sundance[QUOTED] likes this.
