Air compressor confusion
Discussion in 'Home Improvement' started by Resnov1913, Aug 12, 2021.
  1. Aug 12, 2021 at 7:25 PM
    Resnov1913
    Resnov1913 [OP] New Member
    Southern Maryland
    2021 4x4 Tundra (mine) , 2023 TRD Offroad 4Runner, 2018 TRD Offroad (spouse)
    So I went through three cheap air compressors in past year. Basically I have a wheel on the old tundra that for some reason keeps getting low tires and tire pressure sensor errors. I even have new tires. So as result looking for a solid air compressor I can plug into wall power. If has a truck power option great but really looking for something can be plugged into the wall. Needs to not burn out quick.
    What are some of the brands that are recommended?
  2. Aug 12, 2021 at 8:38 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    I have a Makita mac5200. Things a beast! 6.5cfm, its a little heavy, and cumbersome so have some garage floor space ready.
    My brother and dad both have the Makita mac2400, its pretty damn quiet if you don't need over 4cfm, and a small footprint.
  3. Aug 12, 2021 at 8:47 PM
    Gravy
    Gravy Cat herder, ASCM #π
    Yucaipa, California
    2008 White DC 4x4, Limited TRD
    OME Nitrocharger/2612 (front), Bilstein 5100s (rear). Vanguard roll bar modified (by me) to fit over Patriot Stealth retractable tonneau. Aftermarket halo headlights with HID, various LED bulb replacements. 17" Fuel Blitz wheels with some 33" Nitto terra grapplers. Hoodscoop, nfab nerfbars, Bushwacker flares. No-name aftermarket grille, led fender extensions. Black Horse bambi-basher. Various offroad lights.
    Makita's are good, I like'm. If you want a forever compressor find an older one, most any brand, that isn't oil-less. Yes you have to have oil in it, but they last, and they're quieter to boot.
  4. Aug 12, 2021 at 9:25 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Are your wheels that hard to replace? You might have a leak in the wheel itself, I have seen that before. Replace the wheel and problem solved.
    On compressors I have had a viar for a few years that use pretty often. It connects direct to the battery and works really well.
    snivilous likes this.
  5. Aug 12, 2021 at 10:15 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Older wheels could be leaking around the paint or pin holed somewhere.
  6. Aug 13, 2021 at 2:37 AM
    Resnov1913
    Southern Maryland
    orginal TRD wheels from came with the 07 Tundra. Been wanting to get black wheels for my 2021 (crewmax cement :) ) wonder if could just swap. Your question got me thinking and being we have new tires, and they have been rotated, the fact it is the same passenger side front tire seems odd. During a tire rotation don't they just take the wheel off and mount it in a different spat? i.e leave the tire on the original wheel? If that is the case then shouldn't be having this problem on the front passenger but whatever spot the original wheel got moved to? Any other things that may be causing the issue to look for?
  7. Aug 13, 2021 at 2:39 AM
    Resnov1913
    Southern Maryland
    unless they just put the new tires on the front....teach me to post while on pain meds post surgery lol.
  8. Aug 13, 2021 at 3:20 AM
    T-Guy69
    T-Guy69 New Member
    Long Island
    Black 2020 Tundra SR5
    DEWALT 4.5-Gallon Single Stage Portable Electric Horizontal Air Compressor
  9. Aug 18, 2021 at 2:23 PM
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    I have a Makita MAC5200 and a MAC210Q. I have never had an issue with the bigger one. I bought the smaller one so that it is easier to do in-house projects like baseboard since it is light and quite. If you want one to last, it has to be oiled. Oil-less compressors are disposable, they only last a certain number of hours.
  10. Aug 18, 2021 at 2:25 PM
    ohreary
    ohreary Party!
    2020 Platinum
    I have an arb twin compressor mounted under my hood. Fills up tires quick and it’s built way better than whatever I have in my garage
  11. Aug 18, 2021 at 2:25 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
  12. Aug 18, 2021 at 5:45 PM
    SpyderRC
    SpyderRC New Member
    2021 Limited Nightshade
    I think I have permanent hearing loss from my craftsman oil-less compressor I had for years. Thankfully, I finally smartened up and sold it and bought a makita. Couldn't be happier how quite it is. Do yourself a favor and buy an oiled one.
    TucsonTundra1794 likes this.
  13. Aug 19, 2021 at 5:18 AM
    Resnov1913
    Southern Maryland
    eventually, I want to get a setup like this for my truck. Right now however looking for something that can be used for occasional tire filling for both our trucks and handle small tasks around the house for the meantime.
  14. Aug 19, 2021 at 5:37 AM
    Charvonia Design
    Charvonia Design Enthusiast-Owned Small Business Vendor
    Keith
    Huntersville, NC
    2024 Tacoma TRD OffRoad Bronze Oxide
