Air Chuck
Discussion in '2.5 Gen Tundras (2014-2021)' started by Pep, Jun 30, 2022.
  1. Jun 30, 2022 at 6:45 AM
    Pep
    Pep [OP] New Member
    Howard
    2021 Tundra Cement access cab
    My air chuck works on everything in the world EXCEPT my 21 Tundra. Just spent 20 min trying to get air in. Am I missing something?? Need special fitting?
  2. Jun 30, 2022 at 7:10 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
  3. Jun 30, 2022 at 7:12 AM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    The tire valves are standard Schrader.
    Taco-Spike likes this.
  4. Jun 30, 2022 at 7:16 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    Maybe he has his presta valve adapter on it...:eek::eek2::p:cool:
    bulldog93 and Taco-Spike like this.
  5. Jun 30, 2022 at 7:17 AM
    Pep
    Pep [OP] New Member
    Howard
    Running 32psi and want to get up to 40 for hauling coal.
    Leo's first likes this.
  6. Jun 30, 2022 at 7:33 AM
    mountainpete
    I admit to doing that once after filling bike tires. It was a selectable chuck. Why doesn’t this fit? Oh….
    bulldog93 and 1lowlife[QUOTED] like this.
  7. Jun 30, 2022 at 7:59 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    It's a standard fitting..
    Did you get it done?
    BTW your 2021 is either a crewmax or double cab.
    It isn't an access cab as stated in your custom title..:thumbsup:
  8. Jun 30, 2022 at 8:01 AM
    Taco-Spike
    Two Trucks
    1lowlife[QUOTED] likes this.
  9. Jun 30, 2022 at 8:16 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    I should probably mention mine is about 3 PSI off.
    I never realized it until I got an aftermarket HU in my 2014 that shows tire pressure.
    I never could figure out why the gauge read 42 but the HU read 39.
    The same thing happened in my rental 20201 Tacoma, so I pulled out the old reliable hand gauge.
    Sure enough, the inflator gauge was wrong.
    Wasn't worth buying another one, I just remember that it's off when I use it..
    Being off work, I have way too much time on my hands..
    Taco-Spike[QUOTED] likes this.
  10. Jun 30, 2022 at 8:18 AM
    Pep
    Pep [OP] New Member
    Howard
    Had an 04 access cab. At age 70 new things are tough to grasp. Can't get air in. Checked regulator and pushed in pin on chuck. Lots of air comes out. I quit for the time being.
  11. Jun 30, 2022 at 8:24 AM
    Taco-Spike
    Two Trucks
    Mines been showing almost perfect when I see it in my Tacoma.
    BUT, good thing to know, I'll keep an eye out for that and I'll know if somethings not right what the issue is. I'll probably do the same thing and use it knowing it's X amount off PSI if it ever gets to that point.
  12. Jun 30, 2022 at 8:31 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    I'll be 60 in 5 days, I hear ya.
    Good luck..
  13. Jun 30, 2022 at 8:31 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    For what it's worth on my 04 the TPMS sensors apparently can be different lengths. I have 2 wheels that I can't use the press style chuck on, only the screw on. It's quite annoying.
    1lowlife likes this.
