Air bags to prevent rear sagging? I haul 6 to 7000lbs often
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Worm, Nov 13, 2016.
  1. Nov 13, 2016 at 5:53 AM
    Worm
    Worm [OP] Worm187
    2015 Trd pro inferno
    ADD honeybadger winch bumper Super winch Rigid light bar Rigid rear bumper LED's 2 10 inch rigid running lights Hazard strobes DECKED Full bed slide out tool boxes Undercover flex bed cover Leer topper Leather seats Air bags 4 inch readylift Toyo 295/70/18 MT ADD honeybadger rear bumper
    I haul weight often and have a DECKED tool box with 2 full bed lenghth drawers full of tools
    My suspension is sagging and already had both front and rear brakes and rotors replaced. (Under warranty)
    Also an ADD honey badger front bumper with winch And just ordered the rear one to match
    I want to maintain rear ride height when hauling but not compromise articulation when off-road.
    Thank you in advance for any information
  2. Nov 13, 2016 at 6:31 AM
    Benni
    Benni New Member
    2016 Limited
    Just curious......what do you haul that weighs 6-7k lbs, can't be just a couple of toolboxes can it?
  3. Nov 13, 2016 at 7:53 AM
    Worm
    Worm [OP] Worm187
    I'm in the tree business
    Chippers, trailers,miniskids
  4. Nov 13, 2016 at 7:54 AM
    Worm
    Worm [OP] Worm187
    It's rated at 9800lbs ?
    I read that air bags are an option
    But I'm worried about losing performance
  5. Nov 13, 2016 at 8:43 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    I think airbags would be a great idea. I can't see how that would cause you to lose performance.
    NewImprovedRon likes this.
  6. Nov 13, 2016 at 9:47 AM
    I would just get some Firestone airbags.
  7. Nov 13, 2016 at 9:51 AM
    Worm
    Worm [OP] Worm187
    Those were what I was looking at
    I didn't think would be a problem but wanted confirmation
    Thanks again
  8. Nov 13, 2016 at 12:25 PM
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    Go with the firestone airbags and cradles. Firestone does not recommend the cradles but if you do any off-road with articulation, the cradles are a must. Check my build and you can see the cradles in use. My set-up is a little custom but you will get the idea. Good luck.........
    Worm[OP] likes this.
  9. Nov 13, 2016 at 12:57 PM
    Worm
    Worm [OP] Worm187
    Thanks
    Ill check it out
  10. Nov 13, 2016 at 1:04 PM
    Worm
    Worm [OP] Worm187
    Forgive my ignorance
    But how do I check out your build?
  11. Nov 13, 2016 at 1:12 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Yep air bags will help
  12. Nov 13, 2016 at 1:16 PM
    Worm
    Worm [OP] Worm187
    Should I go with the firestone compressor
    Or an ARB for added uses. airing tires
    Auxiliary tank? Impact tools
  13. Nov 13, 2016 at 6:17 PM
    CM-LENNY
    San Diego, CA
    Hey WORM I'm not to good on the computer but if you go to the Forums link and click on the 3rd gen builds you will find my " still under const build ". Also use the search engine and look up my "Frame mounted air tanks". Best of luck to you..........Yell if you have any questions.
  14. Nov 6, 2019 at 3:30 AM
    Dareckii
    Dareckii New Member
    2015 tundra trd pro
    Worm did you install the airbags and do they make the ride stiffer or bouncier I have the same problem with my pro tryin to find the solution
  15. Nov 6, 2019 at 5:28 AM
    WNY PAT
    WNY PAT New Member
    When I was pulling heavier trailers frequently, I had Timbrens on my 2500HD. It was a work truck so it was loaded down 90% of the time and the Timbrens were fine. The 10% of the time it was empty tho, the ride was a little choppy... they say no contact when unloaded but in mine there wasn’t much space empty. It might have been my suspension sagging tho... because I loaded it down for awhile before I had the Timbrens installed. They’re cheaper than air bags and simpler but not as nice I’d imagine.
  16. Nov 6, 2019 at 6:12 AM
    Dareckii
    Dareckii New Member
    2015 tundra trd pro
    Yeah I’m thinking about timber be as well am just trying to figure out which one would give me a better ride bacause I don’t tow that often but I’m going to do coach builder shackles and I don’t know which of this two will work the best with shackles
  17. Nov 6, 2019 at 9:13 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    An old thread, but at 6K-7K pounds, the OP was well into the zone of needing a weight distributing hitch to reduce the tongue weight on the rear suspension. Pushing some of the tongue weight forward to the front suspension will keep the truck leveled and the axles at close to equal loading for best control. But, when you're towing locally every day, I understand that the constant rigging of a WDH can be a PITA.
