Air bag question.
Discussion in '2nd Gen Tundras (2007-2013)' started by Red Freighter, Feb 15, 2016.
  1. Feb 15, 2016 at 11:57 PM
    Red Freighter
    Red Freighter [OP] Red Freighter
    Oregon City
    2013 double cab sr5 trd red
    2014 TRD wheels and TRd pro center caps. Stock 2014 running boards. Stereo gps dvd deck two 12" subs w/amp. Dvd Headrests. Rear air bags with compressor and air tank.
    Where did you install your air tank?
  2. Feb 16, 2016 at 11:13 PM
    Mike Tread lightly.
    south carolina
    If you can under the bed of the truck. Some guys will make custom brackets for it..
    Red Freighter[OP] likes this.
  3. Feb 17, 2016 at 7:13 PM
    Red Freighter
    Oregon City
    Thanks Mike, I thought I could fit the compressor in the engine compartment but it won't fit without blocking a box behind the air box. So I'll be putting that under the bed also. I'll get a picture of the install and post it. Thanks again, Fred.
    MotoTundra likes this.
  4. Feb 17, 2016 at 8:49 PM
    Mike Tread lightly.
    south carolina
    If you do alot of offroading like water crossing or mudding anything like that don't place the pump under the truck if possible.
  5. Feb 17, 2016 at 11:08 PM
    Red Freighter
    Oregon City
    That's a good point, but I don't off road however I do live in Oregon City where it rains a lot. I was planning on installing the compressor with the filter at the bottom and not using it while driving on wet roads. I could also pipe the filter to a higher or to a better location. The instructions say to mount the filter below the compressor.
  6. Feb 18, 2016 at 9:24 AM
    Nor7
    Nor7 Chilton Manual Guy
    2007 Tundra Limited CM, 5.7L
    following, I want to see the pics when this is done.
  7. Feb 21, 2016 at 2:09 PM
    Red Freighter
    Oregon City
    This is what I came up with. This is 1/16" thick stainless steel. More coming later.
  8. Feb 21, 2016 at 3:21 PM
    Red Freighter
    Oregon City
  9. Feb 22, 2016 at 9:47 AM
    Mike Tread lightly.
    south carolina
    Looking good so far
  10. Mar 20, 2016 at 10:42 PM
    Red Freighter
    Oregon City
    Just a little update, I had some airlines melt on the right side from touching the Exhaust by the front wheel. I'm slowly getting around to rerouting them.
  11. Apr 11, 2016 at 9:16 PM
    Red Freighter
    Oregon City
    OK let's finish this. I redid the connections on the tank for better clearance and added a pressure relief valve.
  12. Apr 11, 2016 at 9:20 PM
    Red Freighter
    Oregon City
    Here is the finished project.
    Black Wolf likes this.
  13. Apr 11, 2016 at 9:25 PM
    Red Freighter
    Oregon City
    Still can improve the wiring and I can also raise the tank up for better ground clearance. Other than the center console and the plastic trim around the radiator I didn't have to drill a single hole in the Red Freighter.
    NewImprovedRon likes this.
  14. Apr 12, 2016 at 4:53 AM
    Mike Tread lightly.
    south carolina
    Watch that air tank.. Don't run over something you might sheer that fitting off that tank.
  15. Apr 12, 2016 at 8:43 AM
    Red Freighter
    Oregon City
    Got to leave room for parking brake adjustment.
  16. May 18, 2016 at 1:18 PM
    Dustin808
    Dustin808 New Member
    Dustin
    2008 Midnight blue Tundra Limited
    3" leveling kit 20" MOTO METAL wheels (MO961's) 305/55/20 (33") NITTO TRAIL GRAPPLERS True dual exhaust(custom built) Fabtech BullBar W/LED lights Custom Black Housing headlamps Custom LED tail lamps (Smoked) Fabtech Blacked out grill (Goes over existing grill not a replacement) PIONEER Head unit ( GPS,NAV,IPOD,Bluetooth,DVD,MP3,CD, etc...etc...) Tundra shadow light replacement for the standard door light. HID conversion on low beam side custom drilled and used LED button lights (amber) for the Bull BAR and used as a DRL (X4) 3" Recessed LED back up lamps custom fit into the rear bumper.
    Is this both front and rear? Or just rear airbag for towing/leveling? I see 2 switches on your gauge mount is why I'm asking
  17. May 18, 2016 at 2:02 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Looking good but i have to comment about it hanging so low as well. Im sure your already looking at how to get it up in there.
  18. May 18, 2016 at 3:29 PM
    Red Freighter
    Oregon City
    You should or must run separate air lines independent of each other. So when you go thru a curve and the outside airbag compresses and increases pressure it won't add pressure to the inside airbag and make your truck lean more.
