Air bag PSI
Discussion in 'Towing & Hauling' started by justcuz, Jun 16, 2023.
  1. Jun 16, 2023 at 6:01 AM
    justcuz
    justcuz [OP] 2.5 Gen Member
    How many lbs do I put in my air bags when towing? Trailer weighs 4300 lbs dry. IMG_1128.jpg
  2. Jun 16, 2023 at 6:35 AM
    Tbrandt
    Tbrandt I read it on an internet forum, it must be true.
    Tristan
    Kansas City
    2021 SR5 DC TRD Off-Road
    Kenwood DMX907S + Maestro iDatalink RR2 Kenwood DRV-N520 dash cam Kicker Door Speakers TRD rear sway bar Firestone airbags + Daystar cradles Setrab oil cooler, OEM thermostat and hard lines Century High-C topper Bedrug Helmholtz resonator on stock exhaust Sound deadened + insulated cab Platinum 20s, hwy tires Viair 400P
    25-30 PSI works good for me w/ a ~6000lb trailer and weight distribution hitch. Truck is always right at max payload capacity with my family, our stuff, and the trailer hitched up.
  3. Jun 16, 2023 at 6:41 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Get yourself a tape measure and keep airing up until the from the ground to the top of the fender is the same on front to back.
    You can do it twice if you want, once with no gear and just you (if you drive back and forth from a storage place) and once with everything in it.
    Our trailer is probably 6500lbs with everything in it, i run around 35psi in the bags and 5psi when not towing.
  4. Jun 16, 2023 at 6:47 AM
    bjohnson425
    bjohnson425 New Member
    Brandon
    Ideally you shouldn't use the bags at all to level. With a properly setup WDH you should be at level then air up bags enough to support/maintain level which for me is 22psi.
    Mattedfred likes this.
  5. Jun 18, 2023 at 10:11 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    After getting my WDH set up properly, I took my bags off. They were a band aid that hindered my rear shock performance more than they helped with the trailer after getting the WDH dialed in.
  6. Jun 19, 2023 at 12:19 AM
    blenton
    blenton New Member
    Similar to what most others have said, I run 25-35 psi in my bags with a trailer that size. However, I adjust them according to trailer weight, rear sag, and towing feel when driving down the road with the trailer attached. Even with a WD hitch dialed in, I still feel like the rear spring rate could be increased so I still air up the bags a bit. But that’s me.
    Most of my trailers don’t have provisions for a WD hitch, but they are usually less than 5k lbs so I’m used to the bags doing their fair share of work. Rarely do I exceed 40 psi without a WD hitch.
  7. Jun 19, 2023 at 2:44 AM
    KrOswalt
    KrOswalt New Member
    What kit are you running? I tow a boat often, have a decked system, and a camper shell. I think I need a little help when towing the boat
