Air Bag dash light flashing
Discussion in '1st Gen Tundras (2000-2006)' started by bhorn0002, Jul 14, 2020.
  1. Jul 14, 2020 at 9:04 AM
    bhorn0002
    bhorn0002 [OP] New Member
    2002 Toyota Tundra SR5 AC
    Just bought a new to me 1 owner 2002 Tundra with 120k miles. The only issue I've noticed so far is the air bag light flashing. Needing info on what this may indicate along with suggestions on how to correct?
  2. Jul 14, 2020 at 9:15 AM
    jbar322
    jbar322 New Member
    Harmony, PA
    2002 Silver Tundra AC SR5 TRD
    Fuel Offroad Beast Rims-Black Machined with Dark Tint (17x9,-12 offset, 4.5 backspacing), Dick Cepek 285/70R17, Eibach Adjustable Front shocks with Eibach Springs w/Supreme Suspension Leveling spacer, SPC UCA, Toytec Progressive Add-a-leaf, Toytec Boss Rear Shocks, SuspensionMaxx Sway bar end links, Toytec Front Diff Drop, Toyota LBJ, Mevotch LCA, Proforged Tie Rod Ends, Carquest CV Axles, K&N Air filter, Rear Diff vent relocate, A/C Delco Rack and Pinion Assembly, Carquest Platinum Brakes/Rotors
    If the horn and cruise control do not work as well, then you need to replace the clockspring. If only the airbag light is flashing, you will need to get someone to read the codes and get a better idea of what the issue may be. From my understanding, even if your issue is only the light, it still could be the clockspring needs replaced, but it may be a problem with the airbag itself. The codes should direct you in the right direction.
    I had a similar issue. I replaced my clockspring and all is good now.
  3. Jul 14, 2020 at 9:19 AM
    bhorn0002
    Horn and cruise both function fine. I'll try checking for codes.
  4. Jul 14, 2020 at 11:23 AM
    sflips
    sflips New Member
    Middle Tn.
    2006 DC XSP
    Over a year ago my light came on. Scanner showed D squib circuit (clock spring) I removed the spring checked it for continuity, it checked out. I figured I would have to dig deeper so I put it back together. I cleared the code (again), light went off and has never come back on. My horn and cruise always worked.
  5. Jul 14, 2020 at 11:32 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Sometime just a reset will fix it like @sflips said
