Aint nothing wrong but the radio
Discussion in 'General Tundra Discussion' started by MikenMike, Dec 5, 2019.
  1. Dec 5, 2019 at 9:34 PM
    MikenMike
    MikenMike [OP] New Member
    RACEtruck
    Ive said it before the first gens rock..even the stereo...i dont need a system just hope...i hate the fact i cant hear this junk stereo and i cant turn up a good tune or drown out the kids..or that annoying mystery glass noise...this is a mess...and the research leads nowhere with hope..i dont even have maps i cant afford 2k on a stereo...and a week of labor trying to install it...and even if i did..do i gotta put it in every tundra i may buy...is there something affordable someone had success with..can i get any volume out of a speaker or amp alone...ill take some distortion over this whisper...its not even a money thing as it is the point..please dont reply with tacobell
    SOB likes this.
  2. Dec 6, 2019 at 3:27 AM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Get in touch with @james@tech12volts
    He can get you to a better place as far as audio is concerned.
    You can replace just your factory amp which guys said does wonders.
    You could also just add a DSP.
    Either one used can be pretty cheap and easy to install on its own.
    You have some options...
  3. Dec 6, 2019 at 4:44 AM
    MikenMike
    RACEtruck
    Whats a dsp?
  4. Dec 6, 2019 at 4:58 AM
    Tundyfundy
    Bay Area, CA
    Digital signal processor. Basically an in-line box that doctors the signal coming from your head unit. The head unit signal is dirty and cheap and that contributes to a lot of the harshness of the sound. It’s akin to the difference between SD and HD TV, it’s a cheaper not quite as good as a new headunit but for the price it may just get you what you want out of the sound.
  5. Dec 6, 2019 at 5:54 AM
    ZPMAN
    Minnesota
    What year truck Mike? And model?
  6. Dec 12, 2019 at 5:18 PM
    MikenMike
    RACEtruck
    16 dc non
    Im so lost...im down to trying the kicker key i think...upgraged the door speakers not enough but much clearer and made dash sound better too...im just thinking this kicker might be low power but will correct the crap sound...
  7. Dec 12, 2019 at 5:26 PM
    Azblue
    The Dirty T ( ^_^)_且
  8. Dec 12, 2019 at 6:14 PM
    rebmo
    Rural SE Wisconsin
    2020 CM LImited 5.7L V8 4WD
    What year Tundra do you have that you added this amp? Will it work in a 2010 SR5 standard Stereo/CD/BT head unit?
  9. Dec 12, 2019 at 6:21 PM
    Azblue
    Not exactly. Mine is a 2014 and it's a direct swap with the factory amp. I'm sure you can wire one in but I'm not familiar with the 2nd Gens wiring. Hope it's OK to link to another site, but here is what I have done:
    https://www.tundratalk.net/threads/...n-a-budget-3-years-later.641289/#post-8052001
  10. Dec 12, 2019 at 6:29 PM
    ZPMAN
    Minnesota
    Why I asked is because after 2013 I believe the stock head units are junk (cheaper manufacturers) , I have a 2016 Platinum and after installing a Phoenix Android head unit I am very pleased with the sound. I also later added a $180 sub and am still using the stock speakers till they blow.
    My best advice is to start with replacing the stock head unit.
    pacer442 likes this.
  11. Dec 12, 2019 at 7:47 PM
    MikenMike
    RACEtruck
    All the stereos seem to be worse than the speakers...but my 1st gen seems to have best speakers...as i start looking into head units...seems to be more confusing than the amp situation...i want a good driod head unit that i can just hook up without a bunch of torture...i have a dasata im my 1st its gen...its affordable but not quality...just every angle of this seems to be days of research that still leaves me confused
  12. Dec 14, 2019 at 10:42 PM
    pacer442
    pacer442 New Member
    Robert
    2014 CM Platinum
    May I ask which Phoenix unit you installed?
  13. Dec 15, 2019 at 6:16 AM
    ZPMAN
    Minnesota
    I had installed the the first gen Phoenix and now have thave the second gen fast boot installed. Was going to make a custom bracket and mount the first gen in the rear of the center council for the boys but don't think time is on my side. I belive that Phoenix is now currently has a 4th gen out now. Just with the Phoenix HU makes the platinum sound like a $50,000 should sound like. They now do make a unit for 07 to 13 gen and there is this thread https://www.tundras.com/threads/android-headunit.16037/
    but now believe if you want current info to check on the Facebook page that you can find at the end of that thread.
  14. Dec 15, 2019 at 6:25 PM
    Beau
    Beau De gustibus non est disputandum
    Beau
    2008 Sequoia with a 2022 style
    I agree with ZPMAN. The first mod I did to my 08 sequoia was the stereo. Not because I wanted it to sound better, but because I needed a 2020 navigation, etc. I had BB install a Pioneer nex unit with wireless CarPlay and when I picked it up I was shocked. The speakers were no longer muddy and old sounding, they were crisp and clean. The 8" sub was awoken too, it is more than enough bass for me. Believe me when I say.....NIGHT and DAY difference. If you go with a CarPlay or android auto unit you won't have to worry about updating navigation maps or anything like that since it uses google and apple maps/navigation.
  15. Dec 15, 2019 at 8:21 PM
    Maddux10100
    Maddux10100 New Member
    Barry
    2007 Tundra 4x4
    What pioneer unit did you upgrade to? Thats my first "major" upgrade for the same reasons
  16. Dec 15, 2019 at 10:14 PM
    Beau
    Beau
