AGM Battery Charger and Tundra Electronics
Discussion in 'Electrical' started by Mr. Moto, Aug 15, 2022.
  1. Aug 15, 2022 at 2:04 PM
    Mr. Moto
    Mr. Moto [OP] SPIDERMAN, my 2019 Tundra TRD Sport-PRO
    Eastlake, OHio
    2019 Tundra TRD Sport (converted to PRO)
    TRD Pro Shocks (Fox 2.5 internal bypass w/ external reservoirs all around), TRD Pro dual exhaust; Nitto LT285/60R20, TRD off-road skid plates CBI Steel bumper, RC 20,000 lb. winch synthetic rope, BD S1 bush lights, rear floods.
    Looking to buy the Odyssey OBC-12A AGM battery charger from the maker of my ODX-AGM27F battery in my 2019 Tundra. Can anybody tell me if there are any dangers to the instruments and electronics i.e., things on standby power, alarm, etc. if I charge the battery while connected in the truck?
    Thanks.
    Trying to post to a larger audience but not sure how to do that on this site. Please feel free to broadcast to larger audience if you are savvy. Thanks again.
    YardBird likes this.
  2. Aug 15, 2022 at 2:09 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    I’ve got an agm battery in mine and sometimes it sits for a few weeks. I throw the charger on with everything hooked up and it’s fine. My charger says it’ll do regular and agm batteries.
  3. Aug 15, 2022 at 2:10 PM
    You can select forums at the top and then select which category you would like to browse or post in...electrical, suspension, lighting, etc. Since you already posted, I'm sure one of the moderators would be glad to move it for you. @ColoradoTJ @Squatting Pigeon
    ColoradoTJ likes this.
  4. Aug 15, 2022 at 2:34 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
  5. Aug 15, 2022 at 2:41 PM
    Moved to electrical.
    texasrho83 and Squatting Pigeon like this.
  6. Aug 15, 2022 at 3:01 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    I believe that the Odyssey charger goes through an absorption cycle that tops out at 14.8 volts on an AGM battery. That voltage is generally fine to leave everything connected. The exception can be some sensitive amateur radio equipment but if you have that type of equipment you will already be a power expert!
  7. Sep 11, 2022 at 4:48 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    I use an Odyssey OBC-20 charger and have zero complaints with it.
    Now, if I could only figure out a way to make Odyssey batteries last more than 2 years…. Daily driver, so it’s not sitting around.
    1lowlife likes this.
  8. Sep 11, 2022 at 5:02 PM
    Wallygator
    Mines on the charger now for its monthly top off. Ctek multi us 7002 model. Has an agm setting. Pigtail stays hooked up to the battery full time. Battery is four years old with no issues. Had it in a previous vehicleIMG_20220911_195920169.jpg
  9. Sep 11, 2022 at 6:11 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    You don't have to detach terminals with that charger?
  10. Sep 11, 2022 at 6:15 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Only time you need to pull the battery out is if you are doing a recovery mode with the charger. It uses higher voltage that sensitive components might not like.
  11. Sep 11, 2022 at 6:33 PM
    TheBeast The Beach
    all that covid time and more...
    NOCO GENIUS 5 set to AGM
    Quick Detach plug.
    Prostar 190, Wallygator and WVI like this.
  12. Sep 11, 2022 at 7:20 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    +1 on NOCO genius, except I use the 1 model. I have 5 of them for different on/off road machines. Amazon puts them on sale sometimes for $20.
    Prostar 190, Wallygator and TheBeast like this.
  13. Sep 11, 2022 at 8:35 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Wallygator[QUOTED] and WVI like this.
  14. Sep 11, 2022 at 8:44 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
  15. Sep 11, 2022 at 8:48 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    No, you can charge it with the clamps and battery connected, or can hook up the 'permanent' connection.
    If you did a deep descale you might want to disconnect the battery, but a trickle charge is fine.
    I did it twice and it charged my AGM, but the battery had other issues.
    There is a link here to download the manual..
    CTEK Multi US 7002 – smartercharger.com
    The little snowflake with the Optima icon is the AGM mode.
    Wallygator likes this.
  16. Sep 11, 2022 at 9:09 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
  17. Sep 11, 2022 at 9:10 PM
    619Tundra
    619Tundra New Member
    San Diego, Caifornia
    2017 Black Tundra Double Cab SR5
  18. Sep 12, 2022 at 8:27 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    I don't have an AGM battery anymore, so I don't need a charger..
    619Tundra[QUOTED] likes this.
  19. Sep 12, 2022 at 5:46 PM
    Wallygator
    No there is a pigtail attached to the battery that came with the charger.
  20. Sep 12, 2022 at 8:56 PM
    619Tundra
    What are you using now?
  21. Sep 13, 2022 at 7:16 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    I had a 27F Interstate MTP, it was only 20 months old when my cats were stolen in November.
    Toyota replaced my battery with a Trustart 84-month battery when they replaced my cats.
    They had the truck for 8 months and replaced the battery at their expense.
    I had Interstate test the MTP when I got it back and they said it still held a charge.
    I ended up giving it away to someone that needed it.
    I have no need for 2 27F batteries..
    WVI and texasrho83 like this.
  22. Sep 14, 2022 at 4:33 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Haha thanks for the nice little bonus sticker pack @1lowlife
    HulkSmurf14 and Wallygator like this.
  23. Sep 14, 2022 at 7:01 PM
    1lowlife
    DADA
    2014 MGM DC SR5
  24. Oct 7, 2022 at 2:33 PM
    Mr. Moto
    Eastlake, OHio
    Update:
    I tried to buy an Odyssey OBC-20A and they are not being made anymore. Odyssey engineering recommends charging my ODX-AGM27F with 40% of the battery's C10 rating, so for the 27-PC1750 class of battery (my ODX-AGM27F) rated at 65Ah it should be charged at the rate of 26A, still more than the OBC-20A output. I was told by the sales engineer at Enersys that the 40% of C10 charging rate specified by their engineering department is unrealistic, and the OBC-12A should be adequate.
    I ended up going with a NOCO genius pro 25 which works the same as the Odyssey charger and puts out 25A if needed. I consulted the Enersys (Odyssey) sales engineer and was told that the NOCO charger should work fine since it has an AGM setting. The NOCO also charges LIFeO4 batteries and other lead-acid types as well.
    So, I went for it. I charged all my car batteries first to try it out, then charged my AGM in the truck while connected. It puts out 14.8 charging volts for the AGM which is about 1V higher than lead-acid types. It ramps up the charging while monitoring the vitals and then goes through an "optimization" sequence until the battery is fully 100% charged. There was no ill effect to my truck's electronics, and I fell confident now that charging this way every couple of months should keep my AGM battery in peak condition. I did inquire about the charging diode mentioned in an earlier post, and neither the Odyssey people nor Toyota had ever heard of this, so I avoided going down that road, seeing this was not necessary if I just applied a periodic maintenance charge every few months to keep the AGM battery happy.
