Aftermarkets wheels/tires and TPMS
Discussion in 'Wheels & Tires' started by brttnorman, Sep 14, 2018.
  1. Sep 14, 2018 at 9:03 AM
    brttnorman
    brttnorman [OP] New Member
    Middle TN
    2018 SR5 Tundra
    6" rough country lift 22" fuel wheels 35" nitto trail grapplers Blacked out badges TRD rear sway bar
    Hello all. Ever since my new 35-inch tires and 22 inch fuel rims were installed my tire pressure monitoring system has been not working. When you look at the on dash computer it appears as though there is no system installed at all. The place that install the tires can't seem to figure it out nor can the dealership. Anyone with this experience or thoughts?
  2. Sep 14, 2018 at 9:12 AM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
  3. Sep 14, 2018 at 9:15 AM
    brttnorman
    Middle TN
    2018 SR5 Tundra
    I will try this!!
  4. Sep 14, 2018 at 9:25 AM
    bsavoir
    bsavoir New Member
    Killeen, TX
    2016 Tundra Limited CM 4x4
    Gibson Metal Mulisha Exhaust, Replaced bulbs w/ LED's, AFe intake, Bullydog Tuner, Aftermarket Audio system, Rhino Bed Light sports bar, Tonneau Cover, Spyder Auto Headlights and Taillights, Recon 3rd Brake Light, Kensun HID's, Fender Flares, Custom Leather Interior, Heated Seats, 5% Tint on the Rear Windows, Pod light Foglights, 31" light bar behind the grille, linex spray bedliner, linex sprayed grille, ditch lights w/ dual 3in LED pods, 60" Tailgate LED strip.
    Did you switch from steel wheels?
  5. Sep 14, 2018 at 9:27 AM
    brttnorman
    Middle TN
    2018 SR5 Tundra
    Yes they are now aluminum. Fuel contra .
    I tried the reset and it would work.
  6. Sep 14, 2018 at 9:31 AM
    bsavoir
    bsavoir New Member
    Killeen, TX
    Did you get new sensors with your rims, if so you will need to have Toyota set the system to pick up the sensors.
  7. Sep 14, 2018 at 11:09 AM
    brttnorman
    Middle TN
    2018 SR5 Tundra
    I had assumed they were moved from the OEM wheels, I think the issue is that the dealership didn't re-register them. It's as if the truck doesn't even recognize they are there.
    I have the service manager supposed to call me about it.
  8. Sep 14, 2018 at 1:29 PM
    danz75
    danz75 New Member
    Everett, WA
    18' Cement SR5
    OEM LED headlights, Rigid SAE foglights, Go Rhino RB10 running boards, ARE Classic CX
    The sensors for the steel wheels are different from the ones for aluminum due to the different angles. If the dealership reused the sensors and flipped them, then you should be able to use the reset button. If new sensors were put in, then the dealership will need to register the new sensor IDs in the ECU before it can be read.
    equin likes this.
  9. Oct 2, 2018 at 9:58 PM
    Xyleff
    Xyleff New Member
    NorCal
    ‘16040CMSR5
    Not trying to thread jack but if I got aftermarket tpms with new wheels, do I have to take it to dealership to register or can any tire shop do it?
  10. Oct 2, 2018 at 10:44 PM
    gdiep
    gdiep I like cookies
    Syracuse, New York
    2014 Red Tundra CM SR5
    Not all tire shops can program them into Toyota’s ecu. Most likely a dealership thing. Some guys here have been able to get a hold of techstream software to do this themselves. I tried but couldn’t get the software to work.
  11. Oct 3, 2018 at 8:34 AM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    Some tire shops know how to program and some don’t. The dealer isn’t mandatory unless you don’t wanna deal with the bullshit of finding a shop that can do it. My experience was one Discount tire knew how and another didn’t...
  12. Oct 3, 2018 at 8:48 AM
    Xyleff
    Xyleff New Member
    NorCal
    ‘16040CMSR5
    Cool thx guys
  13. Nov 1, 2019 at 4:51 PM
    WVTundra1794
    WVTundra1794 New Member
    Has anyone been able to purchase TPMS aftermarket sensors that are compatible with Toyota Tundra?..just purchased new fuel assault rim package from custom wheels, they were able to program the sensors but they are not sending signal to truck, dealer advise me to purchase new Oem sensors which I did but now sensors were to thick to fit the rim, I am back to square one. Any advice would be greatly appreciated, thanks! 2020 Toyota Tundra 1794.
    Killahill likes this.
  14. Dec 3, 2021 at 3:16 PM
    Killahill
    Killahill New Member
    2015 Toyota Tundra
    Did you get this figured out? I have 20” Fuel Assault wheels and need to replace the sensors. I’d rather not pay the tire shop a premium for their sensors, and instead simply pay them to install. Recommendations on sensors that will work with the Tundra and the Fuel Assault wheels?
