Aftermarket Wheels: What Your Offset - Any Problems?
Discussion in 'Wheels & Tires' started by pollymath, Aug 10, 2018.
  1. Aug 10, 2018 at 10:07 AM
    pollymath
    pollymath [OP] New Member
    2006 Limited DC 4x4 "Chunky Salsa"
    I'm wheel shopping, as I'd like to ditch the 1.5" spacers I'm using on my 1st Gen with 17" alloys.
    People continually tell me that -20, or -30 offset wheels will ruin my truck, make it unsafe, and generally be a hassle.
    Has anyone that runs lower offset wheels had significant problems with wheel bearing wear, tie rod issues, or ball joints going bad more rapidly?
    jewsNbrews likes this.
  2. Aug 10, 2018 at 10:15 AM
    pollymath
    Holy smokes. That's on a 3rd gen right? I'd love to see pictures of that setup.
    GNTundra likes this.
  3. Aug 10, 2018 at 11:23 AM
    1999cutiger
    1999cutiger Top Flow Lifestyle
    2017 Toyota Tundra SR5 4x4
    RBP 67R AK-8 20x9 wheels General Grabber ATX 275/60/20
    -10 offset with 10,000 miles....no issues that I am aware of.
  4. Aug 10, 2018 at 1:21 PM
    -24 for 30,000 miles and -19 for the last 5,000 miles no problems.
  5. Aug 10, 2018 at 3:03 PM
    pollymath
    Looking for more responses on 1st Gens in particular.
    TexasTundra27 likes this.
  6. Aug 10, 2018 at 3:16 PM
    TexasTundra27
    TexasTundra27 Moby Dick
    Mark
    2011 Tundra CM 4x4 5.7
    Icon stage 3, Icon billet UCAs, 5.29s, ARB lockers F+R, Coachbuilder +2s and shims, Rago fab ditch light brackets and bed stiffeners, Rago Fabrication sliders, ARE camper, 17x9 XDs and 37/12.5/17 stt pros, DT long tubes, xpipe with dual magnaflows, Full skids, TrailToys front and rear bumpers
    My brother runs a +18 offset on his first gen with 2” spacers which bring it to -33 and he hasn’t had any issues. I think he’s had that setup for around 20-30k miles. He did replace the LBJ with OEM shortly before just because they had close to 100k on them. My honest opinion on spacers is that as long as you spend the money on a good American made brand that is hub centric you really shouldn’t have anything to worry about. I run spidertrax 1.25” spacers on my wife’s FJ and we’ve taken it off-road with zero issues for 30k miles.
  7. Aug 10, 2018 at 3:16 PM
    mart1nezdaniel
    mart1nezdaniel AZ
    Arizona
    Tundra TRD PRO 2017
    You will wear down your wheel bearings quicker compared to stock setup. This is due to the fact that the center of the tire is a farther distance away from the wheel hub.
  8. Aug 10, 2018 at 3:29 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Running 1.5" of wheel spacers? There is 26mm per inch. Not sure what 1st Gen stock wheel offset is, but you'll need to subtract 39 mm from that to get your 1.5" of spacer in the offset .so if +60 like 3rd gen, you'll need to look for +18-+25 offset to get similar stance with spacers now.
  9. Aug 10, 2018 at 3:34 PM
    pollymath
    Not positive. Negative.
    You did your math wrong.
    -20 would match my current stock setup. +18-38mm (1.5") = -20.
    That's only if I found a comparable 7.5" wheel. Which hardly exists in 17" format.
  10. Aug 10, 2018 at 3:36 PM
    pollymath
    In theory, yes. In practice? Debatable. I've heard stories of low offset wheels killing wheel bearings every 40k, I've heard other people put 100k on low offset wheels with huge tires who drove trucks hard.
    I want someone to say "yes, I ran -30 offset and within 20k had to do my wheel bearings, LBJ, and tie rods. I did them again 20k later." That to me would be good evidence that low offsets kill joints.
    Black Wolf likes this.
  11. Aug 10, 2018 at 3:38 PM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    -11 offset, 40000 miles.
  12. Aug 11, 2018 at 5:01 AM
    SgtNewundies
    SgtNewundies New Member
    Eric
    -12 offset for both of my trucks. I have 56000 miles on the -12 offset on my Tacoma and it drives beautifully. I couldn't be happier with looks and drive ability.
    YTThao530 likes this.
  13. Sep 27, 2021 at 4:48 PM
    JustFwed
    JustFwed New Member
    2015 CrewMax Limited
    I’ve been running -30 offset Enkei rims on my 2015 crewmax since 22,000 miles When I installed these rims I also installed Bilstein adjustables set at highest (2-3/4”) and ran 285/55/20. Never had a problem and as a matter fact the ride was even better than stock. Recently at 120,000 miles I installed a 4.5 inch Rough Country lift. Within two weeks of doing so I started to notice a shake in the frontend and in steering wheel and pulsing brakes when stopping above 50 mph. IMO my Tundra does not like the negative offset.
    I’m waiting for a delivery of method MR217 20” +18 offset rims with 35x12.5x20 Yokohama. I’d like to hear back from some of you folks who say that they haven’t had any problems with negative offsets of -20 or higher. I’m going to guess that none of them have a 3 inch or higher lift on their vehicles. I was told even if my -30 rims were made hub-centric it would still wobble less but still wobble. I’m willing to bet that my wobble goes away with my new +18 rims and 35’s. Will keep you posted if you’re interested
