Aftermarket Tow Mirrors
Discussion in '2.5 Gen Tundras (2014-2021)' started by Pcola-Yota, Nov 20, 2019.
  1. Nov 20, 2019 at 7:47 PM
    Pcola-Yota
    Pcola-Yota [OP] New Member
    2020 Tundra4x4 Sr5 CM
    Having a hard time finding tow mirrors listed to fit 2020 Tundra. I’m assuming the specs just haven’t been released to vendors at this point? Does anyone know if that is the case, and will 2019 mirrors fit 2020?
  2. Nov 20, 2019 at 7:53 PM
    Bulliesandtundras
    Bulliesandtundras New Member
    Motts
    2019 white CM limited
    Pretty sure they will fit
  3. Nov 20, 2019 at 7:55 PM
    Pcola-Yota
    Yes that’s my assumption too, just odd that there none listed as compatible yet!
    Thanks!
  4. Nov 20, 2019 at 7:56 PM
    DM 2018 Tundra
    DM 2018 Tundra New Member
    South Carolina
    2018 Limted Tundra
    6inch RC with upgrade struts. 295/65/20 Nitto Ridge grappers 20x9 fuel vapor with 0 off set
    The tow mirrors I got from the dealership said mine would fit 18 and 19
  5. Nov 20, 2019 at 8:01 PM
    Pcola-Yota
    Have read decent reviews here about Trail Ridge Tow mirrors from a1 automotive and are considerably cheaper than oem! Just trying to save a few $ but there not showing available for 2020
  6. Nov 20, 2019 at 8:04 PM
    DM 2018 Tundra
    South Carolina
    2018 Limted Tundra
    You might beable to call the dealership and see if they make one for the 2020. I m sure the 19 will work. Someone will check in will more information about. I did loose my BSM when my was put. My passenger mirror was took off 3 days after I got so the guy paid for them.
  7. Nov 20, 2019 at 8:08 PM
    Pcola-Yota
    Prob gonna make that call tomorrow just figured someone here would know and possibly have installed on 2020 already
    Thanks!!
  8. Nov 20, 2019 at 8:12 PM
    DM 2018 Tundra
    South Carolina
    2018 Limted Tundra
    Good luck and keep us posted. Sorry I couldn’t be more help.
  9. Nov 20, 2019 at 8:14 PM
    Pcola-Yota
    Yeah will do, thanks for the reply!
  10. Nov 20, 2019 at 8:22 PM
    TemujinNomad
    TemujinNomad New Member
  11. Nov 20, 2019 at 8:27 PM
    Blue Thunder
    Washington
    I’ve been watching for the same thing. I’ve had three dealerships tell me the ‘19 mirrors won’t work for the 2020. My dealership had a pair unboxed behind the counter they said they’d tried and none of the electronics worked.
    I’ve spoken to our OEM parts man here on the forum, Roman, and he thought they would work but hasn’t had anyone try it yet. So someone needs to step up and give it a shot. For my PRO, it doesn’t have the fold function or blind spot monitoring, so all I need is the mirror adjust and defrost.
  12. Nov 20, 2019 at 8:35 PM
    Pcola-Yota
    I will call local Toyota dealers tomorrow and get their input! That’s discouraging yours said no, was just hoping the info hasn't been given to aftermarket vendors yet... the only functions my stock mirrors have is heat and adjust. Other posts have said will gain turn signals hoping that holds true
    Blue Thunder likes this.
  13. Nov 20, 2019 at 8:45 PM
    Blue Thunder
    Washington
    I don’t understand why it wouldn’t work. Some voice is telling me the dealerships are saying “no” because the tow mirrors don’t work with the blind spot monitoring. They either have a lawyer telling them to say “no”, or they might not understand that some trims only have power adjust and heat.
  14. Nov 20, 2019 at 8:52 PM
    Pcola-Yota
    The rep I spoke with at a1 said no, however he did mention just maybe they don’t have the specs from Toyota yet to verify.. Maybe my local dealer will give me some useful info tomorrow, I will post what they say..
  15. Nov 21, 2019 at 5:36 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    If body styles haven’t changed what’s the problem with mirror fit?
  16. Nov 21, 2019 at 6:15 AM
    Blue Thunder
    Washington
    I think the fit is fine, it is the wiring that’s (possibly) changed.
  17. Nov 23, 2019 at 11:46 AM
    And1
    And1 New Member
    Andy
    2019 Silver tundra TRD
  18. Nov 23, 2019 at 12:22 PM
    DM 2018 Tundra
    South Carolina
    2018 Limted Tundra
    Just have to see how the wiring is probably. You don’t have heated mirrors?
  19. Nov 23, 2019 at 12:32 PM
    And1
    And1 New Member
    Andy
    Yes Sir I do...
  20. Nov 23, 2019 at 12:41 PM
    19greysport
    19greysport New Member
    2019 crewmax sport
    I got aftermarket tow mirrors with bsm that look like the factory ones.
  21. Nov 23, 2019 at 12:44 PM
    DM 2018 Tundra
    South Carolina
    2018 Limted Tundra
    I lost mine BSM don’t bother me.
  22. Nov 23, 2019 at 12:44 PM
    DM 2018 Tundra
    South Carolina
    2018 Limted Tundra
    It should work then.
  23. Nov 23, 2019 at 1:30 PM
    KMG
    KMG New Member
    Kevin
    Yacolt, WA
    2018 White Tundra Limited DC 4x4 TRD
    BFG KO2s, TRD Rear Sway Bar, Firestone RideRite Air Bags, B&W Gooseneck Hitch, Trail Ridge Extendable Towing Mirrors
    I installed Trail Ridge towing mirrors from A1. I ordered mirrors with BSM and turn signals even though my 2018 limited didn't come with the in mirror signals. The mirrors work great and the signals work with my truck too.
  24. Nov 23, 2019 at 1:37 PM
    Durania
    Durania New Member
    Crossville, TN
    2019 Cavalry Blue CM Ltd
    Here is the review I did of them after running them for just a few months:
    https://www.tundras.com/threads/rev...mirrors-from-1aautomotive.56564/#post-1478120
    TL;DR: they're good for the money but the studs rust and leave stains on the paint and the vendor told me "yeah, that happens."
  25. Dec 13, 2019 at 7:34 PM
    Pcola-Yota
    Finally bought the trail ridge tow mirrors and installed them on my 2020, even though they didn’t list them as a fit. Happily I can say they fit and work great! I gained the turn signals at the mirrors, the power adjustment and heat works great so far. They seem to be good quality. My only complaint would be minor imperfections in the passenger side gasket, but don’t think any real concern. The install was very easy, definitely recommend a trim/molding tool to make removing door panel easier.
  26. Dec 13, 2019 at 7:42 PM
    KMG
    KMG New Member
    Kevin
    Yacolt, WA
    I have a 2018 and installed the same mirrors. When I turn on the heat it works but the yellow mirror indicator doesn't illuminate. Do yours?
  27. Dec 13, 2019 at 8:12 PM
    Pcola-Yota
    No nothing illuminates on the mirror to let u know heat is on, just actually feel them get warm. Is their supposed to be a light that comes on?
  28. Dec 13, 2019 at 11:00 PM
    KMG
    KMG New Member
    Kevin
    Yacolt, WA
    I thought there was suppose to be a light similar to the blind spot light but in the upper inside corner. I'll look again in the morning.
  29. Dec 13, 2019 at 11:28 PM
    danz75
    danz75 New Member
    Everett, WA
    18' Cement SR5
    OEM LED headlights, Rigid SAE foglights, Go Rhino RB10 running boards, ARE Classic CX
    There is a symbol in the corner if the mirrors are heated but it does not light up. Its just there to let you know the feature exists. The button on the dash that you push to activate the mirror heat lights up.
  30. Dec 14, 2019 at 6:30 AM
    Pcola-Yota
    Yeah that was my thinking as well!
