Aftermarket Tow Mirrors & retaining BSM funtion
Discussion in 'Sequoia 2nd Gen (2008-2022)' started by ScorchedTaco, Feb 1, 2025.
  1. Feb 1, 2025 at 6:44 PM
    ScorchedTaco
    ScorchedTaco [OP] New Member
    Az
    2012 Sequoia platinum 2012 Tacoma trd or
    Is anyone running aftermarket tow-mirrors that actually retained the blind spot monitor funtion?
    I installed a pair from A-premium Auto that looked promising. Heater function worked , blinker worked , power mirror movement worked and even a backup light all worked . However BSM would not work.
    After doing some digging ( in an 800 page wiring diagram manual) I found out that since I have “ mirror memory “ I had to repin the wire harness connector as the wires are different with this option . Still getting a BSM system error.
    This is on a 2012 Sequoia Platinum w/ mirror & seat memory option.
  2. Feb 1, 2025 at 7:13 PM
    ScorchedTaco
    Az
  3. Mar 4, 2025 at 12:26 PM
    Divineazn716
    Divineazn716 New Member
    Kitto
    2017 Toyota tundra platinum crewcab
    None
    Hey I just bought one and am in this situation. did you ever get it figured out?
    i have a 17 tundra platinum
  4. Mar 4, 2025 at 1:55 PM
    ScorchedTaco
    Az
    No luck , had to return them . So I’m going with mirror extensions & a camera on the back of the RV .
    For whatever reason the memory mirror function setup doesn’t play well with others…..They must be really sensitive to the circuit resistance I guess . My multimeter didn’t read a measurable difference in resistance between the stock & aftermarket mirrors….
