Aftermarket tire air pressure
Discussion in '3rd Gen Tundras (2022+)' started by Silver23, Mar 15, 2023.
  1. Mar 15, 2023 at 5:04 AM
    Silver23
    Silver23 [OP] New Member
    2023 Silver 1794 TRD
    I'm sure it varies but was wondering what pressure ya'll are running with aftermarket tires. I just had some Toyo OC AT III LT275/65/20 tires installed on Monday. The ride was a little more firm, as expected. I checked the pressure and it was over 60 pounds in each tire (My gauge only goes up to 60). I kicked the sidewall and it was like kicking concrete. The heaviest thing I tow is a 19ft Xpress aluminum boat. Probably don't need 60pounds do I?
  2. Mar 15, 2023 at 5:07 AM
    Moe2o4
    Moe2o4 New Member
    Corey
    2020 Tundra SR5 Extended Cab TRD Offroad Package 8ft. Bed
    Bilsten 6112's with 2.5" Front Lift w/Bilstein 5160 Rear Shocks
    Way too much around 40psi is good to run! Also check the door to see what it says too, not sure what the new 3rd gen specifies!
  3. Mar 15, 2023 at 5:53 AM
    Doxiedad
    Doxiedad Distinguished Member
    James
    Charleston, SC
    2020 Tundra SR5 TRD Off Road Cavalry Blue
    Use this to figure out new pressure
  4. Mar 15, 2023 at 6:11 AM
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    2022 SR5 TRD Sport Crewmax White
    You can go to Toyo tires contact us page and submit a ticket asking for correct tire pressure. I did it when I went from OEM tire 265/60R20 to 35x12.50R18 D load range. I was told to run 32 psi as correct tire pressure but 35 psi is good too.
    I tried using the tire size.com pressure calculator but it didn’t have the oem size.
  5. Mar 15, 2023 at 7:01 AM
    SirSwish32
    SirSwish32 New Member
    Nick
    North Carolina
    2022 Tundra SR5 XP 4X4
    1.75" Rough Country Level
    I have those exact same tires/size. I run at 45 when it's warm because then they will stay between 45-50. I run them at 50 when it's cold out because they will drop down all the way to 42 overnight when it's really cold.
    Silver23[OP] likes this.
  6. Mar 15, 2023 at 7:43 AM
    nodak67
    nodak67 New Member
    JR
    or you could read the sidewall and see what the max tire pressure is for that tire for the highest rated load for that tire.
    something along the lines
    max xx psi @ xxxx lbs
  7. Mar 15, 2023 at 9:29 AM
    Coasty
    Coasty New Member
    Pat
    Oregon
    2022 SRS Crew Max 6.5 4x4
    You don't need to run max pressure for what your hauling. I have some load range E all terrain tires that I run at 45 psi and they are wearing fine and ride good. They put 80 in them when they mounted them and it was noticeable. I went to 60 psi and found that 45 is the sweet spot for me.
  8. Mar 15, 2023 at 10:04 AM
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    I’ll run 35 to 40 psi. If you’re going off road you want 35 to 40, if you’re towing that’s when you have to air up to a highway psi. Depends what you’re hauling. Sweet spot is 35 to 40.
  9. Mar 15, 2023 at 1:01 PM
    nodak67
    nodak67 New Member
    JR
    on the tundra i usually only run p rated duratracs at around 32-36 psi as we dont haul nothing but our fat a$$es 99% of the time.
    on my 4runner i run p rated at 32 psi since its only me driving to/from work and it get parked thursday night until monday morning for work. i work 4x10's
  10. Mar 15, 2023 at 11:12 PM
    the_midwesterner
    the_midwesterner New Member
    Luis
    None, yet....
    Sooo much bad info in here….
    @OP: no one call tell you what the best tire pressure is. Someone will say XX amount is best because their cousins boyfriends friends husband is a mechanic and that’s what he said. Only way to know for sure is to measure it for your truck. There’s really 2 options, maybe others but these are the most popular. Either the chalk test, which is the less scientific version. Or a pyrometer. If you use the chalk test, interco has a decent article here. It’s also all over every site and loads of YouTube vids. Effectively, you make a thick chalk line on your tire and keep adjusting pressure, either up or down, until you get full contact patch across the tread. The same is achieved with a pyrometer, but instead of wearing off chalk as you drive, you adjust pressure until the tire has a constant heat load across the tread. Then you’ve achieved your nominal pressure for that load and environment. This will vary truck to truck, and load to load. It will also vary winter to summer, as that pesky air tends to condense.
    Having done this on a myriad of vehicles, the chalk test is cheap and effective. I also have a pyrometer that I’ve confirmed the chalk test too and it’s close enough to not be worth the cost of one.
    BryMan83 likes this.
