Aftermarket skid plate recommendation?
Discussion in '2.5 Gen Tundras (2014-2021)' started by AK 6.7PSD Replacement, Jan 19, 2018.
  1. Jan 19, 2018 at 6:58 AM
    AK 6.7PSD Replacement [OP] New Member
    IL, MO, KS, DE, IL, AK, SC...
    2018 SR5 DoubleCab 4x4
    Can anyone recommend a good skid plate replacement for my OEM? I'd like a thicker one, fewer mounting bolts and, if possible, oil filter access to allow me to change the oil without having to take the entire plate off (don't even know if this is an option). I've got 1,600 miles on my 2018 SR5 so I figured I'd make the swap at the first change.
    Thoughts? Thanks...
    T-Rex266 likes this.
  2. Jan 19, 2018 at 7:00 AM
  3. Jan 19, 2018 at 7:00 AM
  4. Jan 19, 2018 at 7:02 AM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    Just to name a few, RCI, Budbuilt, and P&P. All those manufactures make a door for oil filter.
    I think Pelfreybilt will be making some in the near future as well.
    Sunnier and NewImprovedRon like this.
  5. Jan 19, 2018 at 7:12 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Did someone awaken me from my slumber? Oh. OK.
    Yeah, @RCIoffroad skids. The one I have is the old 2 piece skid. They have now I believe a 1 piece that is even better. You can buy them @ToyTec Lifts. Sorry I don't have better pics; only this one when being installed. And you are looking at the aluminum one BTW.
  6. Jan 19, 2018 at 7:18 AM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    i've got budbuilts in steel, full coverage front to rear.
    Black Wolf likes this.
  7. Jan 19, 2018 at 7:27 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I'm quite pleased with my RCI skids. I saw yesterday that they've taken some good hits and have held up well.
  8. Jan 24, 2018 at 5:44 AM
    HBdirtbag
    HBdirtbag New Member
    Walnut Creek, CA
    2017 limited cm
    i put my RCI on yesterday, happy so far...
    geno0506, MotoTundra and Black Wolf like this.
  9. Jan 24, 2018 at 5:51 AM
    Cfincke
    San Antonio
    If you plan to lift your truck and install a diff drop spacer, avoid the TRD pro skid, you will have issues and have to modify the skid plate - look at RCI or the other mentioned above. If you do not plan on lifting amd adding diff drop spacer, then you should be able to find a used TRD pro skid for $200-250.
    iRenaissanceMan and Sunnier like this.
  10. Jan 24, 2018 at 5:54 AM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    If this thread doesn’t ensure RCI is the winner on skids for Tundras then I’m not sure which one will
    ...RCI is my vote also
  11. Jan 24, 2018 at 3:25 PM
    Slickdick24
    Slickdick24 New Member
    Richard
    2017 black trd tundra
    4" lift,
    Would the RCI skid plate work with a Tundra with a 4 inch lift? After my truck got lifted, the OEM plate did not fit anymore and I have been searching for a skid plate ever since
    Sunnier likes this.
  12. Jan 24, 2018 at 5:26 PM
    wh4x4
    wh4x4 New Member
    Just took advantage of some warmer temps, and got under my Tundra spraying Fluid Film all over...found a mess of an OEM skid plate already rusting all over after just 3 years, much of which spent in a garage, blah. I've been eye'ing the RCI skid for some time, and finally pulled trigger. I'll post pics up when it arrives and can get it installed.
    MotoTundra, Sunnier and T-Rex266 like this.
  13. Jan 24, 2018 at 5:38 PM
    I'm going with RCI skids soon. It doesn't hurt that they are local either.
    geno0506 likes this.
  14. Jan 24, 2018 at 5:42 PM
    Sunnier
    Sunny
    San Diego, CA
    Sean, can you share reason(s) you chose budbuilts?
  15. Jan 24, 2018 at 5:44 PM
    I’ll answer for him. MGM Tundras are an odd bunch so it lines up.
  16. Jan 24, 2018 at 5:46 PM
    Sunnier
    Sunny
    San Diego, CA
    :bananadead:
    MotoTundra and T-Rex266[QUOTED] like this.
  17. Jan 24, 2018 at 6:16 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Curious if you live near the ocean or somewhere where they salt the roads?
  18. Jan 24, 2018 at 6:45 PM
    wh4x4
    wh4x4 New Member
    I'm down in the Outer Banks, NC Summer months -- though haven't driven on the beach with the Tundra. Rest of the year in DC area, where we get some snow and ice, maybe 2-3 times each winter, so there is some occasions when I drive through salt and brine. But really nothing I think is anywhere near extreme for 3 years already showing rust. I'll take some pics
    geno0506 and Sunnier like this.
  19. Feb 2, 2018 at 11:39 AM
    cd121082
    cd121082 New Member
    chris
    Washington State
    2016 Silver Tundra TRD OffRoad
    none yet
    so i talked to the dealer about switching out my skid plate with an RCI one the next time i go in for an oil change a few months ago. and they said sure shouldnt be a problem, shouldnt cost anything since we have to take the OEM one off anyways. so i drop it off thinking this is the agreement. i get a call later that its ready and that i have a bill for $140 and im like why. they say oh cause we changed the skid plate. and im like yeah you did and its free you cant charge me for labor for something that you already have to do unless you havent been changing my filter. man now i have to deal with this crap. but yes RCI is probably one of the best you can get.
  20. Feb 2, 2018 at 12:04 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    That's some serious stealership chicanery there!
    geno0506, TheBeast and joonbug like this.
  21. Feb 2, 2018 at 12:16 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    Welcome!
  22. Feb 2, 2018 at 1:21 PM
    cd121082
    cd121082 New Member
    chris
    Washington State
    none yet
    yeah honestly how can you charge me for labor you already have to do when you change the oil on a stock skid plate. :crapstorm:
  23. Feb 2, 2018 at 1:24 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    If they insist on charging you tell 'em to put the stock back on....lol. It only takes about 20 min. to install the RCI.
  24. Feb 2, 2018 at 1:26 PM
    cd121082
    cd121082 New Member
    chris
    Washington State
    none yet
    they actually told me that when i called them. so i going to talk to the service manager when i get there.
  25. Feb 2, 2018 at 1:31 PM
    Shaggypeach
    Shaggypeach New Member
    Do you guys think RCI would do a sale soon? I dont wanna pay for it if they are going to drop the price in two weeks
  26. Feb 2, 2018 at 1:34 PM
    cd121082
    cd121082 New Member
    chris
    Washington State
    none yet
    i know toytec has a promo code for 5% off just dont remember the code.
  27. Feb 2, 2018 at 1:36 PM
    kicnit
    kicnit New Member
    14 Tundra TRD DC
    De-badged
    Anyone have any experience with the RCI, and a fisher push plate? curious if it could work.
    Kyle
  28. Feb 2, 2018 at 3:09 PM
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    No complaints w my RCI plate. What is a fisher push plate?
    Sunnier likes this.
  29. Feb 2, 2018 at 3:11 PM
    kicnit
    kicnit New Member
    14 Tundra TRD DC
    De-badged
    Sorry. I should have been clearer. For a fisher plow. The mounts are close to the area the RCI mounts to. Just curious if it will work or will trimming be required.
    Kyle
  30. Feb 4, 2018 at 12:06 PM
    OBXTundra
    OBXTundra Member
    Southeast USA
    2018 Nissan Armada, 4x4
    A skid is on my short list right now. I want aluminum because I live near saltwater, the less steel the better, especially low to the ground. How are your aluminum plates holding up? Mild wheeling, can they take some abuse?
    Sunnier likes this.
